Need Help with walkera 22E
Old 11-16-2007, 10:40 PM
Francescocmazza
Default Need Help with walkera 22E
Hi people,
I need some help with my new walkera. I am noobish in this hobby and this is the first hely I buy.
My problem is the following: I opened the box and put the battery immediately to charge for an hour and a half. In the meanwhile I studied a bit more how to fly it. After the light of the charger turned green I got rdy to try it. first of all I put the batteries in the controller. turned it on and all lights on the controller battery lvl were to the max. then I went to the heli. plugged in the battery and connected it to the receiver.
In the exact second in which I connected the battery of the heli I heard a sound, like a very quick puff. some stuff moved within the rotor, but without making it assume a flat position. from the moment I plugged in the battery a led started flashing at about 2 flashes per second. I went to the controller and tried first moving the cyclic controls, but nothing happened. Also, even after moving the lever which should have made the blades start to spin (I have a mode 1 controller, so by moving up from the down position of the little rudder on the left of the right controller) nothing at all happened. What coud it be ? Can anyone plz help me?
Francescocmazza is offline
Old 11-18-2007, 11:08 AM
kodiak101
You need to look up information about the gyro and what the LED light blinking means, I was reading earlier and it talked about the different signals that those lights make to mean something...
kodiak101 is offline
Old 11-18-2007, 01:56 PM
Francescocmazza
The light blinks as if it is not receiving signal from the transmitter, but the transmitter seems to be working fine. All the leds indicating the transmitter has energy correctly. I also tried checking the crystals and they seem to be inserted correctly and are of the same model :S
miru
Beginners - Helis
8
08-03-2008 06:33 PM
Chad
Standard & Large E-Heli Talk
06-14-2007 06:33 AM
PUCHOCOMETA
04-10-2007 05:32 AM
mdaddyrabbit
03-23-2006 03:56 AM
Quick Reply: Need Help with walkera 22E
Page generated in 0.07207 seconds with 13 queries
