Castle Creations discussion All things Castle
hv 85 goveror problems
Old 12-27-2007, 06:13 PM
adwb
Default hv 85 goveror problems
Hi I have raptor 30 that I converted to ep with a z-power motor KV600 10s and a CC HV85 esc which I got from Garry at TT
If I set it all up as a fixed end point all is well and at about 75 % throttle software adjustment [not 75% lever position] I get 1800 rpm which is fine for my gentle flying about style.
I have been flying around using the end point setting ok but I want to try the governor mode and am having all sorts of problems.
Since I have established the 75% throttle setting = 1800 I changed the setting to governor low and with a flat 0% throttle curve I set the throttle lever at point 3 [Futaba 7chp] and slowly increase the percentage to get to 1800 rpm but I find I caní t get anywhere near the 1800 rpm, so I change to governor high and using the same method at 6% if I stop adjusting the percentage, the motor slowly ramps up to 2100 and stops there. If I increase the % any further the revs climb even more!!<O</O
HELP please what am I doing wrong?? I have pasted below the setting that I am currently on
Best regards and complements of the season to you all
<?xml:namespace prefix = st1 /><st1:GivenName w:st="on">Alistair</st1:GivenName> <st1:Sn w:st="on">Barclay</st1:Sn>
ID:	50424   Click image for larger version
adwb is offline
jimweda
10-01-2008 08:35 AM
rickmartinez
9
06-17-2008 11:50 PM
Don McCullough
01-05-2007 03:06 AM
JimClark
12-17-2006 03:46 AM
adwb
8
12-03-2006 05:43 PM
Quick Reply: hv 85 goveror problems
Page generated in 0.06699 seconds with 16 queries
