Eflite Enticement
Old 12-30-2007, 08:28 AM
mannyh
Default Eflite Enticement
I just finished off this little indoor plane and am havin a ball!
Flying it with Axi 2204 on 2 s using flight power 400mah lipos!
Flies at a crawl, hovers like crazy, solid and smooth flier for sure.
ID:	50608   Click image for larger version
mannyh is offline
Old 12-31-2007, 08:16 AM
sgf323
That looks pretty fun! How much flying room does it need? What are the other specs?
sgf323 is offline
Old 12-31-2007, 02:14 PM
Airhead
Redneck Member
Airhead's Avatar
Hi manny,
I'm curious, Wingspan and weight. Is that a stage behind the plane? Are you in a school gym.
I don't think I've seen that plane in an E-flite ad. Is it new?
Airhead is offline
Old 12-31-2007, 05:52 PM
Joefly
I received the Enticement F3P for Christmas and will start putting it together today. Any problems/concerns during your construction? I also received the Park 250 outrunner with it. This is a very small motor. How does it compare to your AXI 2204 and do you think it will do the job? Also, did you glue the "drag break" on permanetly or should I try to find a way to make it removable?
Joefly is offline
Old 12-31-2007, 07:12 PM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
Dang that plane is full of holes
Alpea42 is offline
Old 01-01-2008, 12:50 AM
mannyh
Thumbs up enticement
Yes its flying in a "soccer pitch", We rented it for 3 nites and just had a blast. The brakes are glued on permanently, It seems to roll fine for me
so no concern there. This is a new model from Eflite and the shops around me are already sold out. I dont know enough about the eflite motors to make a comment about their performance compared to the AXI 2204.
Mine hovers at half throttle with an apc 8x3.8 slowflyer prop.
mannyh is offline
Old 07-10-2008, 12:25 AM
caspar21
9ouncr servos be good for this?
caspar21 is offline
Old 02-27-2009, 10:48 AM
Jaiwill
Jaiwill's Avatar
Awesome just received mine... Putting it together in the next couple of days..
I have Ewatts CF2810/900kv Flightpower 800mah (may be too big) and 8g servos... Looking forward to this...
Jaiwill is offline
Hugo
Electronic Builders Workshop
10-06-2008 03:41 AM
fly20
09-23-2008 02:43 AM
jamiekerr
Foamies
06-22-2008 06:17 PM
merctech
Batteries & Chargers
9
12-09-2007 03:12 PM
Munchee
ParkFlyers
12-17-2006 06:54 AM
Quick Reply: Eflite Enticement
Page generated in 0.06811 seconds with 12 queries
