please someone explain good balancing
Old 11-06-2008, 05:20 PM
dditch66
Default please someone explain good balancing
I was having a discussion in a thread on another forum about balancing.
I have a Mystery 50W charger as well as some cheap esky chargers for my helis.
http://www.dealextreme.com/details.dx/sku.15225
This charger has served me well to cycle my NiCd and NiMh packs as well as field charge Rx batteries in my Nitro planes when needed and fast field charge my 3S 2100mAh batteries. Been happy w/ it.
I"m looking at the fma cellpro 10S because my Mystery charger is only 50W which is no good for field charging a 6S 5000mAh pack at 1C.
I was told that the balancing my chargers do is to charge the entire pack of cells at once but to then "shunt" or "disconect" any cell that has already reached 4.20V (with a zenor diode type circuit across the cell to redirect the current going through the pack). The Mystery charger shows the individual cell voltage + the mAh put back into the pack (probably adds in the mAh dissapated by the zenor circtuit as well so the value might be a bit higher than what was really put in). I measure the cell voltage once and a while at the end and it's always 4.20V +/- .01V accurate.
My 3S packs I'll measure the cell voltage at the end of a flight to look for a damaged pack and they are usually within .05V of each other.
Now, I was also told that a cellpro 10S does not do it that way that it does it a different way but I could not get a good explanation. Nor could I get a good explanation of if my charger in the end result was really balancing the pack. I was also told that the mystery charger how it charges would affect the life of the battery and a better charger would make it last longer.
Now, I'm right now looking to just buy the 10S but I really want to have this explained to me till I understand it. I'm an electrical Engineer so make it simple for me
Questions:
So what I want to know is how the Cell pro does the charging differently than the Mystery charger (if it does).
If the Cell pro does charge it differently, then I also want to know, how that affects the life of the battery.
thx in advanced
dditch66 is offline
Old 11-06-2008, 06:49 PM
ministeve2003
Class Clown
ministeve2003's Avatar
Take a look at this charger, I just bought one for a buddy who needs to charge 6cell packs at 5amps, this charger will handle up to 6cells at 7amps and will do up to 8cell packs...
http://www.hobbycity.com/hobbycity/s...lancer/Charger
It is mor or less the upgrade of your old charger...
also I don't know if you have one of these for your old charger, but you can use it on this new one or your old one... you plug it in for charging 2 (3cell) packs at the same time...
http://www.hobbycity.com/hobbycity/s...ead_(2_x_3S)6S_
SK
ministeve2003 is offline
Old 11-07-2008, 01:37 AM
jcg1112
Here is the link to the 10S manual. I've got the 4S and love it and have just bought the 10S. The info is pretty good and should have what you're looking for.
http://www.fmadirect.com/support_docs/item_1266.pdf
jcg1112 is offline
Lieutenant Loughead
10-21-2008 04:47 PM
popriv
9
10-03-2008 03:03 PM
Glacier Girl
96
06-06-2008 04:29 AM
HeliG
E-Flite Helicopters
03-29-2008 07:49 PM
BlizzardBoy
Humor
09-01-2006 04:52 AM
Quick Reply: please someone explain good balancing
Page generated in 0.06998 seconds with 13 queries
