Night Flying Discuss night time aircraft illumination, methods and equipment.
Watts up with night flyin?
Old 04-10-2011, 03:29 AM
flyboy_fx
flyboy_fx's Avatar
Default Watts up with night flyin?
Can any one please help me with night flying? I would really like to learn more on how to install LED strips. Can any also recommend and good LED strip brands? Thanks in advance- Alex
flyboy_fx is offline
Old 04-10-2011, 03:36 AM
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
Hi Alex
Heres an easy, inexpensive and most importantly lite weight solution
http://glowproducts.com/glowsticks/mini/
I use them on my all my aircraft from UM up to parkflyer size
The nice part is i can put them on most aircraft at a moments notice and with a mimimum of fuss
Take care
Yours Hank
kenchiroalpha is offline
Old 04-10-2011, 03:41 AM
gramps2361
gramps2361's Avatar
I just moved your post to the night flying section.
Myself I have bought my led strip lights at hobbyking.
Hobbypartz sells them now and it is cheaper to buy them there and you will get them sooner. They have been great so far to do business with
http://www.hobbypartz.com/ledlights.html
I soldered mine up and used a controller for the lights I bought it at a different vendor. I can plug in 3 separate strips of lights, with a 850mah 3 cell battery.
Look through the night flying section and you will learn how different folks have hooked them up, and the planes they are using.
John
ID:	146291   Click image for larger version
gramps2361 is offline
Old 04-10-2011, 03:53 AM
kenchiroalpha
Hi Alex
Also have some led night flyers as well
Do enjoy
[media]http://www.youtube.com/watch?v=G5bXVCluuW8&feature=player_embedded[/media]
[media]http://www.youtube.com/watch?v=L61_88bw9BM[/media]
Take care
Yours Hank
Old 04-10-2011, 07:31 AM
flyboy_fx
flyboy_fx's Avatar
Wow, very nice! I plan on riging them to the radian.
Is it possible to solder a basic connection of a few light strips to a connector and then just plug a Lipo in? I have also heard something about controlling the brightness with an ESC.
Old 04-10-2011, 12:20 PM
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
Check this out...
[media]http://www.youtube.com/watch?v=Ou29Vn8qKtI&hd=1[/media]
and this...
[media]http://www.youtube.com/watch?v=bw7ZESmDLRw&NR=1[/media]
FlyingMonkey is offline
Old 04-10-2011, 05:15 PM
flyboy_fx
flyboy_fx's Avatar
Ah. So they made a jumper that goes between the battery and ESC. Instead of using the remote switch, can I just connect the hobby king led strips right to the jumper?
Old 04-10-2011, 07:14 PM
flyboy_fx
flyboy_fx's Avatar
What I need is a Tut on how to set up the Light strips. THe only one I've seen after hours of searching that made sense is the FLight test one.
Old 04-10-2011, 07:48 PM
gramps2361
gramps2361's Avatar
Do a search on youtube there are some great ones that show you how to do the soldering and setups. I just goggled soldering led lights and a bunch of stupp popped up there.
John
Old 04-10-2011, 08:26 PM
flyboy_fx
flyboy_fx's Avatar
Found something! Looks promising.
[media]http://www.youtube.com/watch?v=gVBpPjcOkLk[/media]
Old 04-10-2011, 09:59 PM
kenchiroalpha
Question
Hi Alex
Did you read the pdf file i enclosed in my other post?
http://www.wattflyer.com/forums/show...42&postcount=4
Its quite an in depth article on how to set up a nightflyer
Take care
Yours Hank
Old 04-11-2011, 12:41 AM
flyboy_fx
flyboy_fx's Avatar
AH I missed that, will check out later. Thanks!
Old 04-11-2011, 01:10 AM
gramps2361
gramps2361's Avatar
The one you found is the one that helped me out he has a few of them on youtube.
Old 04-11-2011, 03:32 AM
flyboy_fx
flyboy_fx's Avatar
So will this work? Its just a On off design run of a separate flight pack. About 7 meters of LED strip from hobby king will be in there.\
Old 04-11-2011, 03:39 AM
FlyingMonkey
Flite Test Fan
7 meters? What size plane are you putting this on?
The diagram works for me. If you're going with a larger plane, absolutely use a separate battery. I think I used a 3s500mAh lipo for one of
mine.
Old 04-11-2011, 03:40 AM
flyboy_fx
flyboy_fx's Avatar
The radian. 1 meter is 39 inches yes? If so than yea 7 meters for this.
Old 04-11-2011, 04:04 AM
FlyingMonkey
Flite Test Fan
Are you going to face the lights into the foam?
the whites especially, will be so bright, you can't look directly at them. (there is no exaggeration here)
What I did with my supercub, was use a straight edge, and the soldering iron, and cut a trench for the lights part to face down into, and then used clear packing tape to hold the light strip in place. Worked great. The plane lit up from the inside. The whole thing glowed.
Old 04-11-2011, 04:20 AM
gramps2361
gramps2361's Avatar
That is a whole lot of lights you have going on that plane you will light up the sky with that many.
I have about 3 meters of lights and that is real bright. like the monkey said that will work. Now you have a lot of soldering ahead of you I don't envy that glad that part is over for me.
Old 04-11-2011, 04:34 AM
flyboy_fx
flyboy_fx's Avatar
Yea there will be white, GREAT Idea!!!!
Should I do that to all the colors or just the bright ones?
Old 04-11-2011, 04:35 AM
flyboy_fx
flyboy_fx's Avatar
So should I cut back to like 5-6m?
Old 04-11-2011, 06:52 PM
flyboy_fx
flyboy_fx's Avatar
I test flew it with the stock battery and a 3oz battery for the lights, flew great! I'm sure it can handle another 3-4 oz in wiring.
Old 04-11-2011, 07:28 PM
gramps2361
gramps2361's Avatar
I would have used more lights myself the plane I am doing up is covered so it limits me some. So use as many as you like sounds like the plane will handle that extra wgt. no problem.
Old 04-11-2011, 07:43 PM
flyboy_fx
flyboy_fx's Avatar
I Should so make them into a circle and than start the "UFO" Sightings. LOL
This will be a new experience for me with RC!! Can't wait!!!!!
Old 04-11-2011, 08:03 PM
texasclouds
texasclouds's Avatar
Big Bee night flier:
[media]http://www.youtube.com/watch?v=qOK0quntFt0[/media]
texasclouds is offline
Old 04-11-2011, 10:11 PM
flyboy_fx
flyboy_fx's Avatar
So what wire should I solder it all together with? The video said 26 AWG. What else do look for, copper wire, ect? I'm a newb at electrics.
Quick Reply: Watts up with night flyin?
Page generated in 0.19478 seconds with 15 queries
