World Models UNI-JET
Old 07-25-2008, 06:59 PM
Sparky Paul
Sparky Paul's Avatar
Default World Models UNI-JET
Too cute to pass up.
Looks well built.
Extending the wires from the motor to the ESC, measure twice, cut once.
It does draw 30 Amps from a Common Sense 3C2100 Lipo.
I used Hitec HS-82MG servos for the rudder and elevator.
It took a little wire bending to get the nosewheel steering to operate properly.
Hitec HS-55 servos for the ailerons.
Weight came out right at the recommended 28 oz.
C.g. is right over the main mounts.
Wing loading is 18 oz/sq. ft.
Flying..
A long take off.
VERY active in pitch and roll!
Lands hot, with lots of skipping and bouncing.
Landed, moved the c.g. forward a bit, flew again.
Still needed more forward on the c.g.
Added some reflex to the ailerons to stabilize the roll a bit.
The nose gear mount broke out on the second "landing".
Glued that back in with lots of CA.
Added a 1/2 of lead in the nose.
Gets real small, real fast!
I wouldn't suggest hand-launching.
ID:	73681   Click image for larger version
ID:	73682   Click image for larger version
ID:	73683   Click image for larger version
ID:	73684   Click image for larger version
Sparky Paul is offline
Daylight99
Warbird Electrics
11-30-2009 02:11 AM
Trexzation
ParkFlyers
01-15-2007 03:28 AM
RCBobby
Warbird Electrics
11
01-09-2006 02:22 PM
Stolly
20
12-30-2005 08:00 AM
ragbag
08-19-2005 09:25 AM
Quick Reply: World Models UNI-JET
Page generated in 0.09462 seconds with 20 queries
