World Models "Fun World - EP 400"
Old 03-22-2009, 04:17 AM
constantCrash
prefectionist
constantCrash's Avatar
wow, good job on the cowl. looks new.
constantCrash is offline
Old 03-23-2009, 11:52 PM
Kmot
Kmot's Avatar
Thank you, cc!
I have painted it full glossy white already. Now I need to try to find a match for the blue, and do the trim scheme.
The fiberglass has really strengthened this cowling up. Might even help the CG a bit.
Kmot is offline
Old 07-13-2010, 03:01 AM
constantCrash
prefectionist
Default My Funworld 400 EP
So, I finally got around to building the funworld 400EP.
In fact, I flew it, crashed it, removed the covering, fixed it, and re-covered it already.
I'm using a BP 2810-12 motor: http://www.bphobbies.com/view.asp?id...7&pid=D1748437
An e-flight 30A ESC
and 4 HXT 900 servos.
I built the elevator stock to begin with, but the split pushrods were very tight and didn't move smoothly. It also ended up slightly nose heavy. But it flew great. That is until I found out (during flight) that if I did full down and full left rudder, the two surfaces would bind together and cause a crash. Said crash blew the landing gear off, broke the rudder, a wing rib and a wing spar.
This is what resulted in me removing all the covering and re-covering it.
My wife picked out the color. This is that peal and stick covering that I hate. During the re-cover I decided to move the rudder and elevator servos to the tail end. This worked very well except I should have doubled up the balsa on both sides, not just the one.
It flys VERY well, except it has a stiff tendency to pull had left on up lines.
ID:	131759   Click image for larger version
ID:	131760   Click image for larger version
ID:	131761   Click image for larger version
ID:	131762   Click image for larger version
ID:	131764   Click image for larger version
ID:	131765   Click image for larger version
ID:	131766   Click image for larger version
ID:	131767   Click image for larger version
ID:	131769   Click image for larger version
ID:	131770   Click image for larger version
ID:	131771   Click image for larger version
ID:	131772   Click image for larger version
ID:	131774   Click image for larger version
Old 09-04-2011, 03:12 AM
Kmot
Kmot's Avatar
I just updated my FW400 to a brushless system. I bought an Exceed 400 size motor from Hobbypartz. It has a KV of 3700. The brushed motor I just removed had a KV of far, far less.
It should perk up this plane a bit I think. I will give a flight report next Tuesday.
http://www.hobbypartz.com/el4003brmo.html
Kmot is offline
Old 09-06-2011, 07:08 PM
Kmot
Kmot's Avatar
Lost my plane out in the sticks at Sepulveda Basin this morning.
Lost power after about 4 minutes and down she went.
I could not locate it.
Kmot is offline
Old 09-14-2011, 05:52 PM
Kmot
Kmot's Avatar
It was recovered for me by a super nice club member. Thanks Billy!
Name:	Fun World 400 Crashed 016.jpg
Kmot is offline
guapoman2000
Warbird Electrics
242
10-11-2021 11:59 AM
Daylight99
Warbird Electrics
11-30-2009 02:11 AM
panzerd18
Scale E-Powered Aircraft
12-19-2007 10:19 PM
bassmanh
Warbird Electrics
64
11-01-2007 02:45 PM
admin
ParkFlyers
11-01-2005 04:22 PM
Quick Reply: World Models "Fun World - EP 400"
Page generated in 0.09266 seconds with 33 queries
