GWS P 40 Throttle Issues.. Whats going on? Any advice?
Old 01-18-2009, 08:09 PM
PCGamer
PCGamer's Avatar
Default GWS P 40 Throttle Issues.. Whats going on? Any advice?
As some of you may know, I've had some issues with landing my gws p40 this past fall without cracking it up on "final" just before touchdown.
The majority of you advised me to give a "touch" of power just before touchdown.
Here's where the problem lies. I am using zippy 2c 3 cell 2100 11.1 volt lipo pack, gws 6 channel receiver, towerpro 30 amp esc, a towerpro 2409-12 outrunner, and a 6 channel futaba conquest transmitter I bough new in 1994.
THis is whats going to not allow me to give the throttle just a "touch" you all recommend. The motor will "kill" when the throttle stick is all the way down, however I dont get any power until the stick is at 1/2 THROTTLE and at that point its spinning faster than idle (which is what I don't want). THe end result, I OVER SHOOT the runway and crash..
Whats the problem, crappy ESC, crappy batteries, or outdated transmitter, or WHAT???
Well i have you focused now, next question.
When Im as 1/2 throttle and GRADUALLY give it FULL throttle the engine responds nicely.. IF I RAPIDLY increase throttle to full then the motor CUTS OUT!!! Whats with this 2nd problem Im having???
PCGamer is offline
Old 01-18-2009, 08:25 PM
Twmaster
Registered User
Twmaster's Avatar
It sounds like perhaps your ESC is programmed for soft start.
Twmaster is offline
Old 01-18-2009, 09:23 PM
PCGamer
PCGamer's Avatar
Default ....
This is one of those knock-off esc's thru hobby king and is not programmable.
PCGamer is offline
Old 01-19-2009, 12:30 AM
Larry G
E-Pilot
I'd see if you can borrow an ESC to test with. I'm using Hobby City low budget stuff(Turnigy ESC and Rhino lipo, KDA motor) and can get a good idle and smooth transition with My DX6i.
Maybe even try plugging your RX unit into another plane with a known good idle and make sure your radio's throttle is working right.
Larry G is offline
Old 02-05-2009, 02:14 AM
PCGamer
PCGamer's Avatar
anyone else with suggestions?
PCGamer is offline
Old 02-05-2009, 02:39 AM
Twmaster
Registered User
Twmaster's Avatar
If it is a TowerPro as you said in the OP then it is likely programmable. I own a few TP ESC's of various capacity and every one has been programmable. Not many options but programmable to some degree.
Twmaster is offline
Warbird Electrics
185
04-23-2009 06:20 AM
PCGamer
Warbird Electrics
22
01-12-2009 09:43 PM
Bill G
17
11-27-2008 08:45 PM
hariustrk
Foamies
15
11-07-2008 02:58 PM
diablo
ParkFlyers
12
04-23-2007 05:50 AM
Quick Reply: GWS P 40 Throttle Issues.. Whats going on? Any advice?
Page generated in 0.09286 seconds with 13 queries
