Parts for GWS Slow Stick
Old 02-04-2009, 01:44 AM
jkhpilot
Default Parts for GWS Slow Stick
I am wanting to buy a brushless Slow Stick but want to use parts from my destroyed Flyzone Cessna 182 RTF (not brushless). This will be my first "build" as I have only flown RTF electric planes.
My question is: Can I use the Transmitter, Receiver, Battery (1100mAH NiMH),and ESC from my Cessna on the Slow Stick?
I know I will probably need to buy new servos (mini ones) for the Slow Stick. How do I know if all these parts are compatible? HELP!!
jkhpilot is offline
Old 02-04-2009, 01:57 AM
Twmaster
Registered User
Twmaster's Avatar
I'm not familiar with the radio gear in the FlyZone plane. If it uses normal type radio stuffs like the servos and receiver I can't see why you can't just use them.
The ESC would likely not work unless brushless. (or you wanted to put a brushed motor on the stick)
The good news is the stick will fly with an un-believably broad range of gear and can even fly (and well) at 19 or 20 ounces. So you might even be able to use the battery from your Cessna. Of course all I've said is out the window if your radio gear is somehow goofy/non-standard. Even then you may still be able to make it work!
Twmaster is offline
Old 02-04-2009, 02:09 AM
jkhpilot
Thanks for the info. If I do need to buy a new ESC if I go the brushless route, will my transmitter still work on the plane as is? The transmitter is the 4ch Tactic TTX400 that came with the Cessna.
This brings up yet another of many questions I have. How can one transmitter be used on multiple planes? What do you have to make sure the plane has specifically to ensure that you can use the transmitter on it?
Sorry for the very beginner questions.
jkhpilot is offline
Old 02-04-2009, 02:14 AM
Bub Steve
Bub Steve's Avatar
Looks like it will work fine, bub, steve
Bub Steve is offline
Old 02-04-2009, 02:22 AM
Bub Steve
Bub Steve's Avatar
The receiver(RX) in the plane is on the same Ch as the transmitter, you can change the Rx crystal to change the Channel if need be, Theres alot to learn I know but the good part is you get to fly while your learn'in!!!Ask away,, thats what we do here! Here's my little Slow Stick, Bub steve
Name:	petty an red 685.jpg
ID:	92543   Click image for larger version
Name:	petty an red 695.jpg
Old 02-04-2009, 02:30 AM
jkhpilot
Cool paint job on yours!
How do you change the crystal on the receiver in the plane?
Are you able to change the crystal on the transmitter also?
jkhpilot is offline
Old 02-04-2009, 02:40 AM
flydiver
flydiver's Avatar
TX must talk to the RX-must be on the same channel. You can get more RX as long as they are on the same shift and channel. There are 2 shifts, positive and negative. I have no idea what the Tactic is. Some RX are auto shift so it does not matter. You still need to be on the SAME channel (crystal that plugs into the RX).
Legally you cannot change channels on the TX. If you fly around other RC you know you should check to make sure you aren't both on the same channel. To do so is disaster.
Better TX have 'model memories', storage for settings on the TX about different plane setups. Yours does not > 1 TX-1 model.
If everything from the Cessna still works you can likely use it all, even large servos. The SS is not terribly weight sensitive.
flydiver is offline
Old 02-04-2009, 02:47 AM
Bub Steve
Bub Steve's Avatar
Just some 49cent hobby paint!! Kids like funny look'in planes and all mine are "funny"!HaHaaa! your bub, steve
Name:	petty an red 8801.jpg
ID:	92545   Click image for larger version
Name:	petty an red 857.jpg
Old 02-04-2009, 02:49 AM
jkhpilot
Thank you! This is starting to finally make sense
My Tactic TX crystal says 72.55 Ch 38. So if I need to buy another receiver it needs to read the same correct?
jkhpilot is offline
Old 02-04-2009, 02:58 AM
Bub Steve
Bub Steve's Avatar
You buy the crystal you need, I think this is your 'sBub, steve PS go to heads up RC, Jeff will steer you right,
Corona UM-5 Receiver Crystal 72MHz Channel 38
Corona UM-5 Single Conversion Receiver Crystal
FM 72MHz Band: Channel 38
Old 02-04-2009, 04:21 AM
CHEECH
IN THRUST WE TRUST
CHEECH's Avatar
Good form Steve.
I still have to go chase mine after landing. It makes for a long day.
Cheech
File Type: bmp
CHEECH is offline
Old 02-04-2009, 04:35 AM
Bub Steve
Bub Steve's Avatar
Originally Posted by CHEECH View Post
Good form Steve.
Cheech
I know the feel'in! HaHaaa!
ID:	92564   Click image for larger version
Old 02-04-2009, 04:40 AM
CHEECH
IN THRUST WE TRUST
CHEECH's Avatar
So thats what kids are for. I'll get right on it!
Cheech
CHEECH is offline
Army Dad
ParkFlyers
130
01-23-2011 11:26 AM
htomnlinda
02-06-2008 04:20 PM
RCairplane.pilot
ParkFlyers
12-07-2007 01:18 AM
Army Dad
ParkFlyers
06-21-2006 10:05 PM
stafphoto
09-09-2005 04:50 PM
Quick Reply: Parts for GWS Slow Stick
Page generated in 0.11627 seconds with 19 queries
