Fliton Edge 540 Mini, AUW?????
Old 10-07-2006, 01:46 AM
hillbilly808
hillbilly808's Avatar
Default Fliton Edge 540 Mini, AUW?????
Hi,
I have a Fliton Edge 540 Mini. I have flown it a couple of times now and I have noticed that it flies really heavily and will not perform 3D maneuvers as well as I thought.
I use:
Axi 2208/24 / 11x5 E Prop
Jeti 30 amp ESC
Hitec HFS-05MS Receiver
8g E-Sky Servos
11.1v 2200mah Mega Lipos (150g)
At the moment the plane has an auw of 720g (25.4 oz). I was looking at down-sizing the motor, esc and lipo, but im not sure this will benefit the planes performance.
This would be using:
Axi 2212/20 (or similar)
Hacker X20
Hitec HFS-05MS Reciever
8g E-Sky Servos
Thunder Power 11.1v 1320mah
I calculated the lightest I could get the plane was around 650g (22.93oz), with using the 2212/20 set-up.
Would this be too much weight for a Axi 2212/20, Hacker A20-20L or a similar motor?
If anyone else has a Fliton Edge or Extra Mini, could you please tell me your set-ups and weights?
Any Advise would be a Great Help!!
Many Thanks
Jon
hillbilly808 is offline
Old 10-07-2006, 04:15 AM
Ryguy
Anything in the 19-23 oz range for that plane is the norm. That alternative setup looks good. You should still have some good power with that one, and a much better flying plane. Go for it!
Ryguy is offline
HORNET FLYER
3D Flying
23
10-13-2008 11:19 AM
bolts
3D Flying
10-12-2008 09:14 PM
pmikeyg
3D Flying
9
04-21-2008 02:44 AM
budweiser
3D Flying
01-20-2008 02:20 PM
papasmurf
02-15-2006 03:34 AM
Quick Reply: Fliton Edge 540 Mini, AUW?????
Page generated in 0.09514 seconds with 13 queries
