fliton edge 540
Old 12-26-2005, 06:14 AM
HORNET FLYER
Default fliton edge 540
does anyone have anyinfo on this airplane???
thanks
paul
HORNET FLYER is offline
Old 12-26-2005, 03:55 PM
TManiaci
Stupid Contributor
TManiaci's Avatar
Exclamation Got One!
I got one of these for Christmas...
This thing is NICE. Way better than my Mini Funtana. What a class act from Fliton. The covering job is impeccable, the light contruction is amazing, and the control surfaces are HUGE. This thing is so light it blows me away, will easily be well under 20 oz's.
Planning to rig one of two setups:
A) AXI 2212/20, CC Phoenix 25, 3S 1500 mAH 12C lipo, APC 10x3.8 SF.
B) AXI 2808/24, CC Phoenix 35, 3S 2100 mAH 12C Lipo, APC 10x5E.
A would go light, B would be for Power. Depends on AUW. If I can get down to 17 oz range, A will be the rig.
TManiaci is offline
Old 12-28-2005, 07:12 AM
HORNET FLYER
cool....
im spying one for my hacker 20 20l ( e flights edge is to heavy) anyway....thanks for the weight info.
paul bingham
Old 01-23-2006, 08:35 AM
TManiaci
Stupid Contributor
TManiaci's Avatar
Exclamation This plane ROCKS!
Okay, so I finally got the maiden in on this, THE most beautiful mini out there. The good news, it flies better than it looks! Man, I am ordering a Fliton Extra 300. Retiring the Mini Funtana so I have gear to put in it.
I went for the light build, but unfortunatly my bird was out-of-the-box 2.2 oz's heavier than published. I managed to keep it slightly under 20 oz's, no too bad.
Flies like a BIG plane. Stable, well behaved, lands like a butteryfly with sore feet. On rails in the air, beautiful pattern flier for sure. Still working on trying some 3D. Phoenix 25 amp ESC is cutting out well below rating, will try to program a lower cutoff, something fishy though. Even with a fresh new Dymond 3S 1500 mAH 15C (22.5 amps cont.) and propped for 18 amps, it surges and power drops off rapidly at WOT. Did that with an 1800 12C and the 1500 12C too. It's not a battery problem. I'm sure I set LVC to 9V... will reporgram and test more when I have some free time (rare).
So, with the ESC misbehaving, I was prohibited from hucking it. Tried some harriers up high, seems pretty solid. Hover was good for about 3 seconds, then the power falls off and it rolls out. Rolling circles (my lame version) were smooth, and very easy to keep up with. KE had a bit of coupling with both aileron and elevator, but a little speed helps make it lock in. Loops are round and smooth, no tipstall tendencies at all.
Gang... this is a Must-Have mini.
Name:	IMG_0228 small.JPG
ID:	6378   Click image for larger version
Name:	IMG_0226 small.JPG
TManiaci is offline
Old 01-23-2006, 09:09 AM
Rugar
FAA# OUTLAW!
Rugar's Avatar
Thanks for the report. I'm also wanting to retire my M/F, but I cant decide on the 330 or the 540 to replace it with .
Rugar is offline
Old 01-23-2006, 12:35 PM
tashley
tashley's Avatar
Me too!
tashley is offline
Old 01-29-2006, 11:58 PM
6inchesinverted
Gravity Sucks!
anybody seen a video of the 540 or 330?
6inchesinverted is offline
Old 01-30-2006, 01:42 AM
TManiaci
Stupid Contributor
TManiaci's Avatar
I have looked EVREYWHERE trying to find Vids. Doesn't appear anyone has put any up. The FlitonUSA Site says they have vids, but they're not yet on these two models. Guess I'll have to make one... but it won't be very pretty .
TManiaci is offline
Old 01-30-2006, 02:18 AM
Rugar
FAA# OUTLAW!
Rugar's Avatar
Not a video, but here are some pictures of Andrew Jesky demo flying a Mini 330 at the AMA show in Ontario Calif. a couple of weeks ago.
Name:	Picture 020 (Medium).jpg
ID:	6762   Click image for larger version
Name:	Picture 021 (Medium).jpg
ID:	6763   Click image for larger version
Name:	Picture 022 (Medium).jpg
ID:	6764   Click image for larger version
Name:	Picture 023 (Medium).jpg
ID:	6765   Click image for larger version
Name:	Picture 024 (Medium).jpg
Rugar is offline
Old 01-30-2006, 01:56 PM
dogz
R2-D2 ROCKS
dogz's Avatar
Tmaniaci,there are vids in another site that I have seen you in!! I haven't started my edge 540 yet but almost finished the extra 330 mini.I couldn't decide on either one also so I got both
dogz is offline
Old 02-22-2006, 03:01 AM
Jeff Boyd 2
Jeff Boyd 2's Avatar
Looks great, Tman. Wish these came out a little earlier . . anyone want a Efite Mini Edge . . . CHEAP? . . hahaha
Jeff Boyd 2 is offline
Old 02-22-2006, 04:58 AM
hoppy
Watts up Doc?
Those C Ratings on Lipo cells are usually BURST ratings (10sec out of 60) . The Max Continuous Duty is about 60-70% of that. The one discharge graph I've seen of a Dymond cell showed overheating at 8C continuous. They are probably a good 8C cell.
http://www.rcgroups.com/forums/showthread.php?t=367578
hoppy is offline
Old 02-28-2006, 11:00 PM
budweiser
foamy89
what will be an insain motor for this plane.
budweiser is offline
Old 02-28-2006, 11:37 PM
TManiaci
Stupid Contributor
TManiaci's Avatar
AXI 2808/24 or Hacker A30-28S, running ~27 amps, pushing 300 watts... almost too much. (is there such a thing?)
TManiaci is offline
Old 03-01-2006, 12:04 AM
budweiser
foamy89
would a eflite 400 outrunner motor fly this thing
Old 03-01-2006, 12:35 AM
TManiaci
Stupid Contributor
TManiaci's Avatar
Yea, I'm sure that is the older 10C battery, saw that before. The 12C's I have (9-10 of them, various sizes) are VERY good. I run them all at or above capacity, all the time, no ill effects so far. Some of these get cycled 2-3 times almost EVERY DAY by my son, he's a flying nut. I have seen a number of evaluations on these batteries, they always seem to under-rate them. I'm fairly convinced the guys posting battery tests have motives to put up negative press on a good, low-cost lipos, to favor thier own interest in some other brand. I just don't believe what they say, when I have first-hand experience.
TManiaci is offline
Old 03-01-2006, 12:39 AM
TManiaci
Stupid Contributor
TManiaci's Avatar
BTW. Re-programmed my Phoenix ESC for 9V LVC, surging and power loss went away, all is well (and very strong). Was not a battery issue... sure puzzled though, it's like they were in some odd la-la land obscure setting that I can't program. I had two doing this... all better now.
TManiaci is offline
Old 03-01-2006, 12:48 AM
TManiaci
Stupid Contributor
TManiaci's Avatar
It will fly it, but not 3D real well. Only a 10 amp cont. rating, 13 amp burst. WOT would only make about 145 watts. You could prop up for more, and get up into the 160 watt range, but running seriously overloaded and requires careful throttle management. Save the full stick for "special" moments. Try it, upgrade later .
TManiaci is offline
Old 03-31-2006, 03:14 AM
TManiaci
Stupid Contributor
TManiaci's Avatar
Exclamation Video
Got a short Vid of the Edge last weekend. MY SON WAS A TERD, AND SHOULD HAVE FILMED MORE, SORRY IT'S SO SHORT.
Get the video HERE.
TManiaci is offline
Old 05-04-2006, 02:05 AM
RaycRay
Heli addicted
RaycRay's Avatar
Default Need Help On Motor Mount
I have the fliton edge 540 and a Hacker A20-22L and I would appreciate any pics or help on the mounting of the motor. Thanks
RaycRay is offline
Old 05-30-2006, 11:51 PM
Flitonusa
Great new Edge 540 Mini Video available for download at www.fliton.com (gallery section).
Video Direct Download Link: http://www.fliton.com/new_english/mo...ni_edge540.wmv
Flitonusa is offline
Old 07-25-2007, 07:05 PM
beewillis
I went to this link and watched the vid at fliton.com and noticed at the end when they list the gear they used that the axi 2212/20 is used with an 11x5 prop but when I looked at the manufacturer specs it is built for a 9x5 prop. would this damage the motor or shorten the lifespan of the motor? If you were to run this setup would you need to alter the other gear, esc , lipo mah etc...I am just getting in to 3d and would appreciate any feedback you have. thanks.
beewillis is offline
Old 08-31-2007, 01:38 AM
takeoeda
Default Edge540 Video
Here's my brother's
http://www.youtube.com/watch?v=rLVl7rOze6E
Looks like an incredible flying airplane so far. I want to build up a bit more skill before I get one of my own.
takeoeda is offline
Old 10-13-2008, 11:19 AM
bolts
Default good setup for edge mini
Hi I've got one of these on the way and I would like some suggestions for a motor, esc, and battery.
Some input please!
There are a couple of threads but they're a couple of years old and I assume the electricals have changed since then.
bolts
bolts is offline
bolts
3D Flying
10-12-2008 09:14 PM
pmikeyg
3D Flying
9
04-21-2008 02:44 AM
budweiser
3D Flying
01-20-2008 02:20 PM
hillbilly808
3D Flying
10-07-2006 04:15 AM
Jeff Boyd 2
05-12-2006 03:31 PM
Quick Reply: fliton edge 540
Page generated in 0.15312 seconds with 21 queries
