???What's the best E power sub for a Cox .020??
Old 04-07-2010, 05:57 PM
Ryan Flyer
K Close's friend
Ryan Flyer's Avatar
Default ???What's the best E power sub for a Cox .020??
Hi All,
I just started building a old tiger moth kit and it should have an .020 glow engine in it but I am going to go with E power.
Does anyone know what size motor would put out the same power and be the same size?
Thanks and happy landings,
Patrick Ryan
Ryan Flyer is offline
Old 04-08-2010, 02:48 AM
Sky Sharkster
Sky Sharkster's Avatar
Default .020 Electric?
Hello Patrick,
Depending upon the weight of the finished model, this would be my recommendation;
http://www.maxxprod.com/mpi/mpi-26.html (Top of the page, the 2208-1260)
I've used this motor in 3 mini old timers that were made for .020 glow and they worked perfectly. I followed the suggestions for props with 2S LiPo, and it flew an OT "Playboy" and "So Long" like it was made for the models!
I also used a slightly smaller diameter prop on the Playboy with 3S LiPo and it climbed like a rocket. We've had several Climb + Glide OT contests here (limited motor run) and it's won or placed high in every one entered.
If you need a much larger prop, they have a lower Kv version, also.
Weight of the motor (alone) is about one ounce. I used 450 mAH LiPos and a 10 amp ESC. The different models weighed between 5 and 7 ounces.
Good Luck!
Ron
Sky Sharkster is offline
Old 04-08-2010, 03:03 PM
Ryan Flyer
K Close's friend
Ryan Flyer's Avatar
Thanks Sky,
That is just what I was looking for and with a tiger moth I would go with the big prop for more scale like flight.
Pat
Old 04-09-2010, 03:55 AM
Sky Sharkster
Default Hope It Works Out!
Hi Pat,
Glad to help, hope everything works out!
Ron
Old 04-09-2010, 08:04 PM
Ryan Flyer
K Close's friend
Ryan Flyer's Avatar
I well keep you updated as I finish building.
flyingflipper
10-10-2006 12:45 AM
cyclops2
01-13-2006 03:06 AM
Twmaster
10-25-2005 01:13 PM
Heidelberg Germany Flyer
10-07-2005 07:10 AM
09-24-2005 11:05 AM
Quick Reply: ???What's the best E power sub for a Cox .020??
Page generated in 0.14790 seconds with 13 queries
