RCPowers and FRCFoamies - Mossie and Lancaster
Old 01-08-2019, 12:07 PM
Default RCPowers and FRCFoamies - Mossie and Lancaster
Normally I do not pay for plans ... yes I'm a cheapskate !! My usual haunts are Hippocket and so on ... where thousands of plans have ended up.
But as many know - I have a particular love affair with two aircraft : Dh Mosquito and the Avro Lancaster.
Free plans for these are there - but all full fuselage and require a reasonable length of time and skill to build. Always on the lookout for simpler versions - I caught that RCPowers (under new 'management') had basically folded foam plan versions. The Lancaster having been shown in a recent UK RCM&E magazine. The Lancaster flying well on 2S and prop hanging !! on a 3S ..
I HAD to have some of this !!
So Paypal and both Mossie and Lanc are now on my hard-drive. Once I get started on them - I will post up the builds as they progress ...
I have to confess - folded foam I have not done before ...
​​​​​​​Nigel
Old 01-08-2019, 01:21 PM
I'll follow that
Old 01-08-2019, 04:55 PM
The Mossie flight vid is VERY SWEET !!
http://www.frcfoamies.com/dh-havilland-mosquito.html
I will be looking to see if retracts can be fitted ...
Old 01-11-2019, 07:51 PM
riverrat
circa: 1946
riverrat's Avatar
NICE!!!
riverrat is offline
Old 01-11-2019, 08:21 PM
The build is coming on of the Mossie ... my workspace is like a bombsite !! so excuse the mess !! Stuck for space until I get workshop done.
Ok ... basic fuselage as a flat plate and then spine and formers added ... wing is half sections glued to the flat plate fuselage. Imagine a profile model - then formers added ...
The engine pods 'nacelles' are created by using a spine and then 'folded' foam casing.
The same folded foam system will be used for the fuselage shell.
The folded system of course leaves the 'trenches' where foam is cut and folded ... so i will be looking at ways to fill without adding weight. I may cover the model with lightweight Nysilk with PVA ...
Wing ... best way to describe that ... again flat plate base .. with what is similar to a KM layer but folded and raised by a spar to create an aerofoil form.
Motors are to be the Turnigy L2210 1400kv bell motors with 7x4 3 bladers ... 30A ESC and 2S lipo with 3S on standby in case needed !
Retracts will be fitted of course ... the small 33x25mm Hobby King set that are sane as used in the HK Lancaster. Shame that I cannot get the Lancaster plastic legs to add to the metal rod ...
Interesting build ...
Old 01-16-2019, 08:27 PM
Well it all goes together !!
Wing spar etc.
Fitting folded fuselage shell
Starting to fit gear
Because I am waiting ESC's and motors ... I cannot glue on top wing panels yet.
back end controls
Yes - I have fitted retracts
Wing panels laid on to rough out the paint scheme ...
Plans indicate 8x4 3 bladers but eCalc shows that 6x4 3 bladers are more than enough to get this baby going on 1400kv .. and 3S
One panel in place now that ESC's arrived and I already had one motor (2210 Bell motor 1400kv)
Once other motor arrives and wing panel fitted ... the folds will be filled and final painting done. With an overall matt varnish to complete before decals applied.
Really looking fwd to this !!
Old 01-21-2019, 01:15 PM
Just waiting on that last motor - very frustrating ! ... then fit ... glue wing top on .. paint and then recheck location of gear to balance on the spar. I need to leave that top skin of so I can feed and fix motor wires / ESC in place.
Reason she leans is that the tail skid is not fixed and has collapsed !
She will have HE SuperII Stab, FrSky 8ch, Soloshot mount, arranged inside.
Retracts along with the usual ailerons, elevator and rudder.
Motors have 15% differential programmed in to give me better handling on ground.
Over-prop'd with 9x4.5 3 bladers contra props on the 2210 1400KV with 3S lipo ... but that's to keep the throttle lower and sound better. Originally I was going to use the 6x4 or 7x5 ... but that would mean higher throttle and high pitched sound. Not really in keeping with the Mossie !!
nigel
Page generated in 0.05047 seconds with 11 queries
