Nicad TX batteries life span
I just noticed that my Hitec Laser 6 TX nicad battery pack is 7 years old. It still performs well but just curious how long you keep them.
Dick
Edit: Are Nimh's better than Nicads for TX?
Dick
There are advantages and disadvantages to both.
NIMH have no memory like NICAD
NIMH have higher capacity for any given size so you can go longer between charges.
NICAD last longer - about twice as long in the same application.
NICAD can be charged faster if thats important.
NICAD have a lower self discharge rate
LIPOs on the other hand have a much larger capacity than either.
Lower self discharge rate than either
No memory
Can catch fire and burn up your radio, house, car etc.
Are risky to use if your tx cant handle the voltage difference.
Need a special charger.
No memory
I personally observed that so called "memory" effect on Nicads we used where I worked before retiring. We were shipping 600 24 volt Nicad batteries for our circuit breaker controls every month. (That was for 30 years) And, working in the Service Department, I tested a lot of them before giving the customer warranty credit.
And, I did see memory effects on these batteries. What we ran across is a depressed voltage on the battery during discharge milliampere hour tests. That voltage on the batteries we used dropped down to about 1.05 or 1.1 volts per cell during the discharge test, rather than the normal 1.2 Volts.
And, discharging and recharging these batteries several times removed the problem.
But, because these batteries were backup power for 38,000 Volt 800 Ampere three phase power circuit breakers, we could not take any chance with them, and simply scrapped and replaced them. (Those breakers were rated to clear 16,000 Ampere faults)
Our customer recommendations were to replace these batteries every five years. But, that is for an application far more critical than for the radios we use for our models. (Even those flying wet turbines!) In recent years, we went to gel cell lead acid batteries for backup power, to gain more ampere hour capacity for the microprocessor operated circuit breaker controls.
For transmitter use IMHO, if you test them at least once a year for milliampere hour capacity, using something like the West Mountain CBA battery test equipment, and every thing passes OK, you are good to go. Nicad batteries generally slowly wear out, and don't normally suddenly quit, at least as how they are used in our transmitters. Things to watch for though, is cell leakage, visable as a white deposit around the cell seals. Any battery that has any cell leakage should be replaced. Period. These batteries that have had cell leakage can continue to work OK for a long time. But that stuff is corrosive. Not a good thing to have inside your transmitter. That internal chemical can also eat up the battery leads them selves!
As for the receiver batteries, I'd be inclined to replace them every few years in glow/gasoline models. They are subjected to far greater variations in battery current. And, they are subjected to vibration issues that can lead to problems after five years or so. If you ever crash a model, be especially careful about the receiver battery. They can check OK, but have broken spot welds on the individual cell connections under the shrink wrap. Not good.
Good morning,AL and thank you very much for your input......this is a very "busy" forum......does anyone out there have any "concrete" evidence on this one???....either way, i'm sure we'd all like to know......in my 25+ yrs. of flying, i've alway's heard that they did develop a memory
No memory
No memory
No memory
No memory
Thanks for all the replies. At the beginning of each flying season I will charge them, fly for a while, then check the voltage on each cell. Also, at least twice a season I will run them through a charge/discharge/charge cycle and so far haven't had a problem.
I prefer the Nicads over Nimhs for my transmitter just because of the decay rate since I sometimes make sudden decisions to go out flying.
Thanks again,
Dick
Thanks again,
Dick
Here is what I am using in old 8 cell TX's these days. The LiFePO4 packs. 3s voltage is 9.9v nominal volts. They have about zero self discharge and hold voltage wonderfully. Cycle life is supposed to be 1K+ and they do not have the thermal runaway of LiPoly. Nice...
http://media.hyperion.hk/dn/fg3radio/
Those that say NiCad do not suffer from memory problems are correct. What those who say they do are confused by the voltage depression effect. Now this also effects NiMh as well as NiCad, just not as extreme. As one who has had to deal with the reliability of batteries and other electronic devices for some 40 years, I participated in tests covering several months of data proving that NiCad's do NOT the so called "memory effect". If you check into some of the manufacturer's more elaborate tests, you will find they found the same results; i.e. no memory effects and that most reports that started this erroneous fact based there finding on miss interpreting the voltage depression which does occur in both NiCad and NiMh.
People are calling that voltage depression a memory effect. If you have a properly designed electronic control, that voltage depression will not affect your device, and you'll never know you had the voltage depression issue.
If you run discharge tests on your airborne radio system Nicad or Nickel Hydride cells at least once a year, you even reduce or eliminate that voltage depression effect. (And, you should be testing those batteries at least once a year!)
The 2s version can "likely" be used with no regulator. If you servos are OK with 6.6v you are good to go. I don't know if any receivers that will have an issue with that.
A fully charged 5 cell Nicad pack is about 7v but it drops to around 6.2v or so under load. So they are about .4v higher than a 5 cell flight pack.
I had to go do some searching on my own because I was SURE you were WROOOOONG!!!
But, turns out you are quite correct.
Its always a bitter sweat thing when one of your cherished, long held beliefs is shot full of holes.
The sweat part is you end up learning something new.
Thanks for that correction
