Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Power - Batteries, Chargers, ESCs and More > Brushless Motor Construction
Brushless Motor Construction Discuss design and construction of custom Brushless motors
Old 12-26-2006, 03:19 PM   #1
trooper8
Keep 'Em Flying
trooper8's Avatar
Default Basics
I have a good background in electricity and mechanics but am new to RC.
What are the key features and benefits of a brushless motor in RC?
What does an ESC actually do? Is that a voltage wave chopper?
trooper8 is offline
Old 12-26-2006, 05:30 PM   #2
aethertek
aethertek's Avatar
No brush electrical losses or wear.
ESC is speed controler, uses PWM (pulse width modulation).
aethertek is offline
Old 12-28-2006, 09:56 PM   #3
pilotpete2
Pilotpete2
pilotpete2's Avatar
Hi Trooper8,
As Aethertek noted there is no brush wear or commutator wear. Basically much less maintenance. Another plus to brushless motors is less RF noise, as the arcing of the brushes/commutator has been replaced by electronic commutation performed by the brushless DC controller.
PWM is used both in brushed and brushless controllers as we are dealing with DC. Voltage chopping is used in AC applications such as light dimmers, or to reduce the speed of AC fan motors (only with high slip induction motors).
The second function of a brushless controller is to provide timed switching or commutation to the motor based on the detected back EMF of the motor, in effect the ESC is electrically part of the motor as they run in a closed loop environment. Many folks don't realize that "brushless" motors are in the commutated motor family and operate on the same principals as brushed motors, that's why they have Kv ratings, the higher the voltage, the faster it spins, till failure mode kicks in, also we can advance or retard the timing with brushless motors just as in their brushed counterparts (well the better ones, that is).
Welcome to the R/C obses-- er, I mean hobby
Pete
pilotpete2 is offline
Old 12-29-2006, 02:40 AM   #4
lshadow2005
lshadow2005's Avatar
What is the reason for advancing or retarding the timing of a brushless or brushed motor ,pluses/minues
I assume you need an ESC that will allow you to adjust the timing ?
Bob
lshadow2005 is offline
Old 12-29-2006, 01:35 PM   #5
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Club: www.rmvc-cumulus.nl
About motors and controllers
  1. Workings of a brushless controller:
    http://www.torcman.de/peterslrk/index_eng.html
    -> Speedy-BL self made brushless controller
  2. Several diy brushless controller designs and a few design discussions:
    www.rcgroups.com/forums/showthread.php?t=140454
  3. Online course on motors, magnetism and controllers:
    www.rcgroups.com/forums/showthread.php?t=200567
  4. Animations and simulations of brushless motors:
    www.rcgroups.com/forums/showthread.php?t=216928
Building your own brushless motors (20Watt-20kWatt)
  1. Brian Mulder's must read motor building articles, will prevent you from asking a lot of questions
    www.southernsoaringclub.org.za
    -> articles from Southeasters
    -> electric motors, part 1-5
  2. Do-it-yourself motor homepages, manuals/tutorials, checks and tests in the first message of this motor builders tips and tricks thread. The checks and tests may save you from frying your controller or motor. Thread is active, bookmark it for future reference and subscribe to it:
    http://www.rcgroups.com/forums/showthread.php?t=240993 (sticky thread, at top of subforum)
  3. Peter Rother's bible:
    www.torcman.de/index_e.htm
    -> know how
    -> English version
  4. Ralph Okon's motorbuilder bible:
    www.powercroco.de
    Don't let the German language deter you, a picture(s) is worth a thousand words, and you can use an online translation tool, e.g. http://babelfish.altavista.com
Vriendelijke groeten Ron
diy motor building tips & tricks
diy brushless motor discussion group
Drive Calculator download & discussion group
int. E fly-in & diy outrunner meet, Aug.26 2007, Nijmegen, the Netherlands
ron_van_sommeren is offline
Old 03-11-2007, 08:30 PM   #6
tennistal0n7
ummm, i think brushless is slower and more acrobatic? i think.
tennistal0n7 is offline
Old 03-13-2007, 08:44 PM   #7
ScubaSteve
Nope that made no sense actually.
ScubaSteve is offline
Prop Basics ... diverdon Power Systems 8 07-20-2007 09:43 PM
nimh basics?? babydoc Batteries & Chargers 1 07-02-2007 08:44 AM
more basics pap0007 Beginners 6 04-29-2006 07:53 PM
Need a little help with the basics please Grasshopper Power Systems 53 04-19-2006 01:17 AM
electonic basics? pace_likethesalsa General Electric Discussions 12 10-30-2005 01:49 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Page generated in 0.09699 seconds with 30 queries
