Build Your Own Transmitter Tray
Old 10-06-2005, 02:45 PM
hoppy
Watts up Doc?
Default Build Your Own Transmitter Tray
Here is an easy to make transimitter tray that is fitted for the Hitec Spectrum transmitter.
hoppy is offline
Old 10-06-2005, 02:48 PM
hoppy
Watts up Doc?
Tray is 9 1/2" x 12" 3/16" plywood. The Handle Holder is 3" x 3 1/2" wide plywood. The plywood projects about 1 1/4" out from top of tray.
Some scrap pieces of plywood were used to stiffer tray.
ID:	2262   Click image for larger version
hoppy is offline
Old 10-06-2005, 02:59 PM
hoppy
Watts up Doc?
The 1" x 1" pieces with the slot cut in them hold the feet and keep the transmitter stable in the tray. Place transmitter in tray and place stabilizers in place around rear feet. Glue in place. (Ignore holes - mistako)
hoppy is offline
Old 10-06-2005, 03:02 PM
hoppy
Watts up Doc?
Drill 1/4' holes for Strap holders. The holes are 4 1/2" in from each side and 1 1/2" from back edge. The strap holders are 7" long 1/4" eye bolts with a 30 degree bend about 3" from eye. I covered the bottom part with shrink tubing to dress it up a bit. Use 2 nuts and washers on each bolt. One under and one above board.
hoppy is offline
Old 10-06-2005, 03:05 PM
hoppy
Watts up Doc?
Varnish the Board at this time.
Pop rivet two 3" pieces of Velcro to the tray as shown. Postion so that they fall inside the bottom plastic extensions on the transmitter.
hoppy is offline
Old 10-06-2005, 03:08 PM
hoppy
Watts up Doc?
Attach the other Velcro piece to the bottom of the transmitter. I used self adhesive Velro for this purpose.
hoppy is offline
Old 10-06-2005, 03:11 PM
hoppy
Watts up Doc?
That's all folks -
Slip handle into handle holder on top of tray, set feet into feet holders, attach Velcro straps. Mine holds the Transmitter stable regardless of the position of the board.
hoppy is offline
Old 10-07-2005, 08:07 AM
mauilvr
If you don't want to build one here's another alternative that is made from acrylic, weighs only ounces and costs only $24.99. I've got one and have been very happy with it.
http://www.petalrc.com/petals.htm
One of the attached pictures shows the optional Pro Pads.
ID:	2293   Click image for larger version
mauilvr is offline
Old 10-07-2005, 03:02 PM
bigbobed
Here's one that I made using some thin cutting boards from Wally World. My son confiscated it and I couldn't find more boards, so I made a replacement out of some Lexan I had.
ID:	2305   Click image for larger version
ID:	2306   Click image for larger version
ID:	2307   Click image for larger version
ID:	2308   Click image for larger version
bigbobed is offline
Old 10-07-2005, 03:25 PM
Mike Parsons
Penguins still can't fly
Mike Parsons's Avatar
Hoppy,
Good form. Cheap and easy...two of my favorite things
I have the Pedal tray and love it. It isnt bulky and is light.
Mike Parsons is offline
Old 10-07-2005, 06:21 PM
ForestCam
Bad Influence
ForestCam's Avatar
I don't think your eye bolts are strong enough.:p
ForestCam is offline
Old 10-07-2005, 07:57 PM
hoppy
Watts up Doc?
LOL - Thanks, good eye.
bigbibed, I like your side supports and I was thinking of putting a couple pieces of firm foam on the sides. Will let you all know how it works and if it adds anything.
hoppy is offline
Old 10-07-2005, 09:44 PM
bigbobed
The supports make it real easy to use finger and thumb on the sticks. You probably know this, but a tray sure makes hand launching park flyers easy. I'm left handed so I launch with a hand already on the right stick. ROG is the most dangerous part of my flying.
bigbobed is offline
Old 02-02-2008, 11:29 PM
petes98
This is my five-minute made tray made from a plastic-clipboard and a locker organizer (the wire is just there for now but i will soon replace it with string or some type of rope). I know it looks weird but hey, it still gets the job done and i didn't have to buy any materials. (maybe i could sell these , maybe not)
ID:	54366   Click image for larger version
ID:	54367   Click image for larger version
petes98 is offline
Old 09-11-2008, 03:14 AM
up_ya_go
up is good
up_ya_go's Avatar
Default Home made tray
Thought I would like to try a tray so had a go at putting one together.
I'm in the minority here in Aus by using mode 2 , but also I feel more comforatble with the fingers and thumb rather than thumb only, so this should be a help I hope.
Used a cutting board from the kitchen and a couple of 1/4" eyebolts. I could not obtain 8" ones so got 6" and used joiners to connect a 2" bolt. Used some heat shrink to tidy up the threads.
Had a piece of aluminium sheet that was easy to bend to form a base "housing" and that is lined with duct tape to pad the transmitter. Used a paper clip with small nut and bolt to clip onto the handle when the transmitter is slid into place. Pinched my transmitter strap and bingo ... there it was.
It works fine on the computer sim, and feels comfortable. Have yet to try it out "in the wild".
Cheers.
Name:	IMGP6055 (Small).JPG
ID:	77765   Click image for larger version
Name:	IMGP6056 (Small).JPG
ID:	77766   Click image for larger version
Name:	IMGP6057 (Small).JPG
ID:	77767   Click image for larger version
Name:	IMGP6058 (Small).JPG
up_ya_go is offline
Old 09-11-2008, 04:44 AM
Mike Parsons
Great job guys!
Old 09-11-2008, 04:17 PM
up_ya_go
up is good
up_ya_go's Avatar
Smile that tray
Ta Mike .
Only a small point but I omitted to mention... have allowed enough room at the top of the board to velcro a timer and enough at the sides to mount palm pads if ever desired .
up_ya_go is offline
Old 04-01-2010, 06:46 PM
whattheheli
whattheheli's Avatar
What are the dimentions of the pieces. What did you use to cut the pieces? jig saw?
whattheheli is offline
userrc
General RC E-Heli Talk
12
11-11-2009 01:02 PM
wrpsr1911
09-21-2008 03:43 AM
kalel
01-31-2008 03:19 AM
watt_the?!
33
11-13-2006 07:44 AM
RCTrayManUSA
New Product Announcements
09-16-2005 09:06 PM
Quick Reply: Build Your Own Transmitter Tray
Page generated in 0.12895 seconds with 35 queries
