SUPER Quick Delta Scratch Build
Old 02-17-2007, 06:39 AM
Default SUPER Quick Delta Scratch Build
Hi Everyone I went to Michaels Art & Craft store this Evening, and this Sheet of 20x30 foam board called out to me, and said, Make me fly
What Could I do, I was Powerless Ok, I said to the Foam Board, There is something wrong with me :p Well, Here is how I am going to make that foam board fly
I have a picture of some delta combat wing planes, I think I borrowed them from RCG
did some measuring, and started cutting, here are the results of that cutting on foam board, Enjoy. Chellie
ID:	24373   Click image for larger version
ID:	24374   Click image for larger version
ID:	24375   Click image for larger version
ID:	24376   Click image for larger version
ID:	24378   Click image for larger version
ID:	24379   Click image for larger version
ID:	24380   Click image for larger version
Old 02-17-2007, 06:45 AM
Airhead
Redneck Member
Airhead's Avatar
Chellie,
Looks like you are a busy girl.... I like those, maybe I could join you building from here...I always learn from you..
Have fun!
Airhead is offline
Old 02-17-2007, 06:49 AM
That will be cool Bruce, This will be my first delta wing, so its a learning process for me, if anyone knows where the CG should be at, please let know, I will add a long strip of velcro, to slide the battery back or forward to get the right CG, The wing is 20" wide, Take care, Chellie
Old 02-17-2007, 06:59 AM
Default Delta build
I will be using mixing on this one, elevons, but you can make it elevator and rudder if you want to, here are some more pics that inspired me, well back to work take care, Chellie
Old 02-17-2007, 07:29 AM
Default delta build
Hi Everyone Making the bottom skid, from foam, with foam board, you have to sand the paper with rough sand paper to take off the shine on the paper, so when you soak it, in the bath tub like i do, the water will get into the paper quicker, and it will peel off, the paper adds a lot of weight, so its better to remove it, the foam is soaking right now, so its time for a glass of wine ok lets make it a tall glass of wine Chellie
ID:	24384   Click image for larger version
ID:	24385   Click image for larger version
Old 02-17-2007, 09:14 AM
Airhead
Redneck Member
Airhead's Avatar
Enjoy your Wine chellie,
I am working on getting the CG info that you are requesting. Hopefully I'll have it to give you tomorrow sometime...
Airhead is offline
Old 02-17-2007, 10:02 AM
Kewl, Thank you Bruce
Old 02-17-2007, 10:21 AM
Hi Everyone I got a little more done, It will be a ARF before I go to bed tonight or this morning, here is what was done so far, I taped the elevators on to the body, I used a New Tape from Scotch, NOTE FOUND OUT IT DOES NOT WORK VERY WELL IN WARM WEATHER, it got to 88 degrees here and it was too spongy, OH Well, I TRIED IT, I tape the body to elevator with a 1/4" gap, then press the tape together at the middle/seam, that makes for a nice tight hinge, thats very flexable, I also I cut a 6" lenght of 3/8" X 3/8" bass wood to the front body for the motor mount, I left it sticking out about 1" so I can slide a stick motor mount to it, and I added a piece of carbon rod to the rear of the rudder to give it some strength, I need to cut the rod to length after the Epoxy dries, in 5 mins here are a few more pics, Take care, Chellie
ID:	24393   Click image for larger version
ID:	24394   Click image for larger version
Old 02-17-2007, 12:05 PM
Default Quicky Delta Build ----DONE----
Hi Everyone Its A ARF now Its Done, Except for the electronics, and it weighs a Whopping 2 1/2 oz Now that was Super Quick, I started on it at 8.00 pm friday night and finished at 3:00 am sat morning, now its time for me to get my Beauty Sleep hear are a few more pics of the plane, Enjoy,Chellie
ID:	24396   Click image for larger version
ID:	24397   Click image for larger version
ID:	24398   Click image for larger version
ID:	24399   Click image for larger version
ID:	24401   Click image for larger version
ID:	24402   Click image for larger version
ID:	24403   Click image for larger version
Old 02-17-2007, 12:13 PM
Found IT, Delta Wing CG Info
http://adamone.rchomepage.com/index5.htm
http://moleski.net/rc/WingMAC.htm
Old 02-17-2007, 03:42 PM
Airhead
Redneck Member
Airhead's Avatar
Morning Chellie,
Does this help too?
Warp info:
http://www.rcgroups.com/forums/show...2&postcount=511
Stubby info:
http://www.rcgroups.com/forums/show...6&postcount=423
Have fun..
Airhead is offline
Old 02-17-2007, 04:09 PM
GITech001
G.I.T. it...got it GOOD!
GITech001's Avatar
Wow Chellie,
Done! That was fast! 1 day! Amazing! I will post more latter. Time to go open my store.
TTYL
Jay
GITaHobby.com
GITech001 is offline
Old 02-17-2007, 09:54 PM
Originally Posted by GITech001 View Post
Wow Chellie,
TTYL
Jay
GITaHobby.com
Hi Jay I Challanged myself to build a delta wing, in one evening, well I burnt a little midnight oil doing it, but I did it it was fun, I wanted to take it out today with my DR1 Maiden, but its a little windy here today, about 10 mph winds, I dont want to try to fly a multi wing plane in the wind, and being a maiden, no way, take care and dont work to hard, Chellie
Old 02-17-2007, 10:25 PM
TeslaWinger
Love yer delta! Simple and quick has a lot going for it!
I finally got to see the FLYBOYS movie, about the Lafayette Escadrille - so that DR1 sounds interesting- but my heart belongs to a Neuport 17, since it was the first flying model (Guillows rubber power) I ever successfully built and flew- at 11 yrs old- so it left an impression!
Wishing you calm air and a frisky delta!
TeslaWinger is offline
Old 02-17-2007, 11:25 PM
Hi TelsaWinger Thank You, I want to go see that movie so bad too, I am installing the servos in the Delta right now, I was going to fly the DR1 today, buts its a little to windy, maybe tomorrow, Take care & have a great weekend, Chellie
Old 02-18-2007, 03:23 AM
Carjacker
The Doctor is in.
Awesome!
What kind of electronics will you be using?
Carjacker is offline
Old 02-18-2007, 03:51 AM
Kosh
Kosh's Avatar
Default Well Done :)
Looks great Chelle, That's the same way I made the first one but I never got to fly it because it was built for Susan. I was unsure of CG also so did the same long Velcro thing that way a lighter 2 cell can go forward and 3 cell back a bit.
From the short video I saw of Susan's in action it looked super stable with fair roll rates and good glide. Its the kinda plane you can kick back in a chair with and have all kinds of fun in close. The first photo is what she wanted a copy of but I made it larger and more stable like yours, Roll rate is VERY fast.
The next 2 photos are from Susan and part of her growing fleet of planes. Perhaps she has a photo of just where she puts the battery on hers. Heres a short video of what they look like in action.
http://www.cascadeap.com/DeltaDave.avi 16.6 MB
Best wishes on the maiden, Kosh
Name:	Kosh Delta.jpg
ID:	24454   Click image for larger version
ID:	24455   Click image for larger version
Kosh is offline
Old 02-18-2007, 04:49 AM
Hi Carjacker, Hi Kosh Thank you for the complements, this Delta is going to get a 2408-21 outrunner, with a cut down 7x6 prop, to make it a 6.250 X6 the 7x6 vibrated to much & the cut down prop is nice and smooth, with lots of pull, and a 30 amp ESC with a 1320mah 11.1v 12c lipo, a hitec reciver, 2 towerpro 9 g servos and a mixer, for elevons , I am getting a little braver, I am going to buy some night lights for it Take care, Chellie
ID:	24470   Click image for larger version
Old 02-18-2007, 05:13 AM
GITech001
GITech001's Avatar
That's great! How awsome is that! So simple and it has to be a blast to fly! I have to have one!
TTYL,
Jay
Old 02-18-2007, 05:16 AM
Hi Jay Keeping busy huh Thats good that will keep you out of trouble for a little while it was too windy today to maiden the DR1 so tomorrow maybe, did you send me those plans yet you rascal take care, Chellie
Ps I will send you one jay and have you got the Electronics for it
Old 02-18-2007, 06:18 AM
Hi Everyone , I threw all the electronics on top of the Delta to see how much the AUW is, and I surprised myself, only 11oz, it has 400sq inches of wing area, so it should be a kite very lite wing load, should be interesting to fly, I do not think I have anything with that lite of a wing load, I almost forgot how to calculate the area of a triangle, dont tell Mr Clean that hey I have been out of school/college since 74, and had a GPA of 3.89 ,oh oh ,showing my age now here are a few more pics, Chellie
ID:	24490   Click image for larger version
Old 02-19-2007, 01:36 AM
WOW !!!!! What a sweet flying delta Wing, it only needed a couple clicks of up trim and a couple of clicks of left trim, it does, I would say about 50 mph +, loops no problem, as this was the maiden flight I did not do any rolls, just kind of got use to it, It needs a little power to land, as it will stop in the air with no power, then cut power and a little up, and it just settles down, It only needs 3/8 " up and 3/8" down movement on the elevons, no rudder used, and I flew it for about 10 mins, still had power, but did not want to chance a dead stick Had a glass of wine to calm my nerves after the maiden Ok Ok just an excuse to have a glass of wine the CG is 7" some people are having good luck with the CG at up to 9 , from the nose of the plane not the motor, i added some carbon fiber tube on the leading edge of the wing for added strength, The way I fly, I need all the help I can Get I am looking into getting a digital, audio, video camera, Kosh & his friends gave me some great info on a camera with a 12X zoom, its a Cannon Powershot S3IS, so videos will be coming soon, here are some pics of the delta, I added some color to it so I can see it a little better, On the second flight, I moved the lipo a little further forward, that took care of the need to have power to land and glide problem, Just a minor CG adjustment, the CG is now at 7" and i am moving it back untill I find a sweet spot, I got it close the first time out Enjoy, Chellie
ID:	24544   Click image for larger version
Old 02-19-2007, 01:56 AM
Kosh
Kosh's Avatar
Glad it flew well for ya, Rolls should be very mild and controllable so you wont have any problems there next time out. It should slow down very nicely and still fly easy and with the motor in front you can hang it on the prop for a limited time. After a few more flights you can get pretty wild with the control throws for some more roll rate. This should also work well as a mid motor setup if wanted. I think Susan is working on one now.
I'm sure you will have lots of fun future flights with it and welcome to the world of Delta's.
Kosh is offline
Old 02-19-2007, 02:03 AM
Thank you Kosh, It was a very interesting flight, I was a little ready for it, as I fly those Hydro Foams, this delta is much nicer to fly than those hydrofoams but both have there own merits, Take care, Chellie
Old 02-19-2007, 02:21 AM
WingTips24
Mr. ExperiMENTAL
You go Chelli, Great Job
Tips
WingTips24 is offline
Quick Reply: SUPER Quick Delta Scratch Build
Page generated in 0.18410 seconds with 44 queries
