Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Sport Planes (Formerly I/C & Gas Conversion)
Old 03-17-2007, 04:28 AM   #1
Franny
Stupid Gravity!
Franny's Avatar
View Franny's Gallery20
Smile Balsa USA Taube 40 Conversion and Build
Hi All,
Well, I finally finished the Taube (German for "Dove"). I actually started this back before Christmas but when the Shoestring arrived I put off the completion. Anyway, this is the Balsa USA .40 size Taube kit. I have converted it to electric with the E-Flight 46 motor and a 4S 4000mAh Lipo. I don't have a ton of photos, but here are a few original photos to get started. There is a great replica in the Seattle Museum of Flight. The original used wing and tail warping for control. Take a look at those long bars under the wing to carry the control wires. Amazing really. The Seattle Taube is what I used as a guide. The Balsa USA version is a "sport" scale version designed for easy Sunday flying. It has a flat bottom airfoil and is only three channel - E/R/T. The larger sizes add ailerons, but I think that actually detracts from that great wing plane-form. The original was modeled after a bird and from the ground was quite hard to spot. I suppose it was the first "stealth" aircraft... The Taube was actually in service before WWI and was primarily used for surveillance as it had no mounted guns. They were phased out fairly quickly as technology changed but in their day, they were cutting edge. I love the lines and am always up for a classic.
Franny
Name:	Etrich Taube1.jpg
ID:	26279   Click image for larger version
ID:	26280   Click image for larger version
ID:	26281   Click image for larger version
ID:	26282   Click image for larger version
ID:	26284   Click image for larger version
ID:	26285   Click image for larger version
ID:	26286   Click image for larger version
ID:	26287   Click image for larger version
Franny is offline
Old 03-17-2007, 05:15 AM   #2
Franny
Stupid Gravity!
Franny's Avatar
Default The build...
The Kit is supplied with top quality balsa and lots of it. The construction is really pretty easy with the only built up structure being the horizontal stabilizer. I just had to make a decision as to how much detail I wanted to add. The kit is a bit thin on details but I think it doesn’t take much to make it sing. The field I fly on is grass and nose-overs are common (well, for me...) so I wanted to make the dummy engine removable so I could fly with or without it. It is attached with two pairs of very strong magnets as is the battery hatch on the underside. I decided to build up the elevator which I started from their solid slab. Same went for the fuselage sides. I cut out the pattern in the sides and then added 1/4"X1/4" strengtheners to the inside. The result is a strong structure with a vintage look. I didn't add the bottom sheeting to the fuselage. Instead, I added cross braces similar to the sides. I did leave the fin and rudders solid. Another area I addressed was the landing gear. The kit called for a single 5/32" wire gear so I added a few pieces to look a little more scale. The original gear is kinda nutty and actually attaches to the wing. Mine is a bit of a compromise. I did find a set of 4" spoked wheels which weigh a ton, but you can't beat those looks. For the motor mount, I used the nylon mount included in the kit as a spacer. It worked out just right! All I had to do was cut off the rails and I was in business. The cowl is removable to access the motor and is also secured with magnets. Here are a few construction photos...
ID:	26299   Click image for larger version
ID:	26300   Click image for larger version
ID:	26301   Click image for larger version
ID:	26302   Click image for larger version
ID:	26304   Click image for larger version
ID:	26305   Click image for larger version
ID:	26306   Click image for larger version
ID:	26307   Click image for larger version
Franny is offline
Old 03-17-2007, 05:18 AM   #3
Grasshopper
Some Assembly Required
Grasshopper's Avatar
View Grasshopper's Gallery48
AP Contest Winner  WAA-08 Pilot  100mph Speed Demon
Friends: (52)
Amazing work Franny! What is the wingspan on it?
Tom
Grasshopper is offline
Old 03-17-2007, 05:32 AM   #4
Franny
Stupid Gravity!
Franny's Avatar
Default Final Photos...
I used "Coverite" fabric covering for the first time and it was really great to work with. I was a bit intimidated at first, but it went on really well and shrank right up. The front part of the fuselage is painted a flat olive drab as is the top of the wing. Now paint and I generally don't get along and, of course, just as I started painting, it started to rain but I did manage to get a pretty good finish in spite of my lack of skill. I added a little rigging and the center rigging support. That is also removable for transportation. The actual thread is stretchy thin shock cord so it will always be taught. Oh, I did add a tail wheel. The original had the usual skid, but I though it would be easier to handle. For the prop, I started with a standard wood prop and sanded the trailing edge straight and curved the tips. I then sanded the entire thing to remove the finish and then stained it. It took like 30 min total and looks a million time better than what I started with. I'll probably fly with the usual thin electric gray plastic prop which doesn't look all that bad. Instead of control rods, I went with a pull-pull control on both the elevator and ruder. It was a little bit of a pain to set up, but looks cool.
I hope to get it in the air this weekend so I'll post some photos after it flies. Here are a few I took this afternoon.
Thanks!
Franny
ID:	26309   Click image for larger version
ID:	26310   Click image for larger version
ID:	26311   Click image for larger version
ID:	26312   Click image for larger version
ID:	26314   Click image for larger version
ID:	26315   Click image for larger version
ID:	26316   Click image for larger version
Franny is offline
Old 03-17-2007, 05:36 AM   #5
Franny
Stupid Gravity!
Franny's Avatar
Thanks Tom,
Good question... Let me look... Looks like 62" span... AUW is 5 pounds. That 46 motor is really strong so it should fly well. I sure hope so! Here is a link to the Balsa USA site: http://www.balsausa.com/store/proddetail.php?prod=439
Thanks,
Franny
Franny is offline
Old 03-19-2007, 03:27 AM   #6
Franny
Stupid Gravity!
Franny's Avatar
Default Maiden Today!
Well, the maiden went really well today. It really is a joy to fly! I think I am just a tad nose heavy, but thats better than a bit tail heavy! It turns like it has ailerons and lands like a dream! I couldn't be more happy with it. As you might imagine, it is way overpowered. I don't think I ever got above 3/4 throttle and flew between 1/3 and 1/2. Just a joy.
Thanks again to Ron (The Sharkster) for all his help and encouragement!
Here are a few photos...
ID:	26469   Click image for larger version
ID:	26470   Click image for larger version
ID:	26471   Click image for larger version
ID:	26472   Click image for larger version
ID:	26474   Click image for larger version
Franny is offline
Old 03-19-2007, 03:41 AM   #7
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Franny - it looks amazing! Very nice.
Yep I suspect half that motor would have done!
Old 03-19-2007, 03:45 AM   #8
Franny
Stupid Gravity!
Franny's Avatar
Thanks Mike... Those E-Flight motors don't mess around! It is really nice to be able to fly all day on the same battery!
Franny
Franny is offline
Old 12-25-2007, 04:15 AM   #9
Franny
Stupid Gravity!
Franny's Avatar
Default New Taube photos and Video!!
Hi All,
I have some new photos and Video!
I bumped into a friend of mine at the LHS a couple days ago and he slipped me a disk of video he shot of a Taube flight of mine from last summer. So, I put together a video and posted it to my site. There are two: A large one (20G): Taube Video Large and a smaller one (7G): Taube Video Small
This is my first attempt at a video and Movie Maker is weird...
I hope you enjoy it!
Thanks,
Franny
ID:	50194   Click image for larger version
ID:	50195   Click image for larger version
ID:	50196   Click image for larger version
ID:	50197   Click image for larger version
ID:	50199   Click image for larger version
ID:	50200   Click image for larger version
ID:	50201   Click image for larger version
ID:	50202   Click image for larger version
Franny is offline
Old 12-25-2007, 04:26 AM   #10
View CHELLIE's Gallery13
Friends: (326)
Great Job on the plane and video Franny Keep up the outstanding work, and Happy Holidays to You, Chellie
Old 12-25-2007, 07:57 PM   #11
Franny
Stupid Gravity!
Franny's Avatar
Thanks Chellie!
Hey, I like your tag line... Great wisdom that Scarecrow. Great writing in that... Everything the characters wanted they already had in abundance.
Merry Christmas!
Franny
Franny is offline
Old 12-25-2007, 08:57 PM   #12
jooNorway
Great video, and great pictures of an unusual plane I really love to see "Classic" scale kits airborne, not only ARF`s with glossy film on them.
When you mentioned Coverite I remembered I still have some rolls of it in my hobbyroom... think they are close to 20 years old now. That is what I grew up with... some time ago
Have used Solartex the last years when I want a strong and scale-like covering. As soon as I am finished with the Angel50 the building-table will be full of small parts which are supposed to be a school-glider (SG-38) from pre WW2. Covered with "Antique" Solartex.
Really enjoyed the video and the Taube!
Happy Holidays.
jooNorway is offline
Balsa USA Phaeton 90 Biplane shv2sail Sport Planes (Formerly I/C & Gas Conversion) 8 04-21-2009 04:27 PM
Balsa USA Foamies Ron S Foamies 4 10-28-2007 01:19 AM
For Sale: Fokker Dr 1 Balsa USA 1/4 scale CarreraGTSCS Airplanes - Electric For Sale & WTB 2 09-13-2006 05:05 AM
Balsa USA Taube skyvolt12 Sport Planes (Formerly I/C & Gas Conversion) 48 07-08-2006 05:46 PM
For Sale- Balsa USA 1/4 scale Fokker Dr1 kit CarreraGTSCS Airplanes - Electric For Sale & WTB 5 04-19-2006 08:39 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Page generated in 0.22069 seconds with 89 queries
