Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Seaplanes E-Powered
Seaplanes E-Powered Discuss electric powered seaplanes here
Old 06-04-2007, 08:51 PM   #1
Franny
Stupid Gravity!
Franny's Avatar
View Franny's Gallery20
Question Is a water rudder really needed?
Hi All,
I am adding a set of GWS floats to my Little Gasser 16oz 400 size airplane and am wondering if I need to add a set of water rudders. The Gasser's rudder is pretty affective in the air, but I don't want to have to retrieve it after every landing. I will be flying off a dock on a small lake. What do you think?
Thanks,
Franny
Franny is offline
Old 06-05-2007, 02:38 AM   #2
Jim Casey
Seaplane Nerd
Jim Casey's Avatar
Club: Florida Float Flyers
I have a granite slab engraved: "If your motor is running you can control the taxi with the rudder. If your motor is not running,...it doesn't matter. " SInce this is the electric forum there is a high chance your prop will turn enough to get you back unless you run completely out of juice.
Neutralize elevator and stop the prop. The plane will point into the wind.
Hold full up and go to a speed somewhere around fast idle. The noses of the floats will ride up and the plane will weathervane downwind.
Back off the throttle a little and it is possible to taxi crosswind, steering with the throttle and holding the upwind wing down with the aileron. However be advised that a crosswind taxi is tempting the demon of being blown over. Three-channel airplanes are just a blowover waiting to happen.
Or if you taxi fast while the floats are skiing atop the water, you can go pretty much any direction. Still: be conscious to use a little aileron to hold the inside wing down in the turns lest you tip to the outside, hook a wingtip, and make a big embarassing splash.
Jim Casey is offline
Old 06-05-2007, 02:55 AM   #3
Franny
Stupid Gravity!
Franny's Avatar
Thanks Jim! Sounds like you have done this before! The ailerons on the Gasser aren't the most agressive, but I will take your advice. I'm also thinking short bursts with the rudder in the direction I want to go might also work.
I won't bother with the water rudders. I bet the electrics will make it a bit easier than I remember it being with the prop always spinning...
Thanks,
Franny
Franny is offline
Old 10-20-2007, 02:42 AM   #4
Bub Steve
Bub Steve's Avatar
View Bub Steve's Gallery86
Club: Mullet Mauroders
Friends: (89)
Franny::I build BIG over-sized rudders on mine, Seems to do the trick, your bub, stevecooper
Name:	petty an red 075.jpg
ID:	45111   Click image for larger version
Name:	petty an red 248.jpg
ID:	45112   Click image for larger version
Monkey Minion'air
Bub Steve is offline
Old 10-22-2007, 11:46 PM   #5
cyclops2
I like Jim's logic.
No motor no go.
Prop blast should swing it around at a stand still. Water rudder is effective when some speed has built up.
cyclops2 is offline
Old 10-24-2007, 04:07 AM   #6
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery88
Club: rcg staff
Friends: (17)
Steve, that GWS float give ideas for hulls.
I have a GWS Beaver on GWS floats. It doesn't steer worth crap with the air rudder, and once you get it to turn, you usually over do it, and it swings around.
Bill G is offline
Old 11-16-2007, 07:14 AM   #7
Detroit Dave
I have to back up Bill G. They don't steer well with just the air rudder.
I have several planes that I fly off the water....none electric yet, but that is coming. I've found that even with the prop spinning, it can be a real challange at times to get back to the shorline where I'm standing.
I wouldn't even consider a floatplane without a water rudder. You only need one water rudder and it doesn't matter which float you put it on. Two water rudders look way more impressive, but I't just personal preference.
You can make the rudder out of thin aluminum or plastic and use 1/2A hinge. I run a control cable teo different ways. It can come from the rudder servo arm or loop back from the rudder control horn to the rudder.
If you haven't got a water rudder, make sure you have a rescue boat!!!
Have Fun, Fly Safe, Dave
Detroit Dave is offline
Old 11-16-2007, 10:03 AM   #8
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
WAA-08 Pilot  Globetrotter Pilot  AV Contest  AP Contest Winner
I couldn't get my E-Starter to steer at all with its stock rudder. I doubled its size, as Steve suggested above and it worked well enough and it was very easy to do. Would a water rudder be better? Yes, but the larger rudder worked well enough to keep me from wading out in the lake.
Frank
Murocflyer is offline
Old 11-16-2007, 04:29 PM   #9
Bub Steve
Bub Steve's Avatar
Friends: (89)
Detroit Dave:: "If you haven't got a water rudder, make sure you have a rescue boat!!!"got it covered my bub,, and thanks again for the thrust angle's, You are a smart guy an I think I'm gonna learn a few things from you! I glad you found this site, your bub, stevecooper
ID:	47059   Click image for larger version
Name:	petty an red 083.jpg
ID:	47060   Click image for larger version
Name:	petty an red 111.jpg
Monkey Minion'air
Old 11-17-2007, 12:15 AM   #10
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Steve,
I really like your rescue boat!!! So much in fact, I am going to make one for myself. Thanks for the idea!
Frank
Old 11-27-2007, 02:42 AM   #11
JRickey
I found with my SS that I can make it do tighter turns a slow speeds with full down elevator. It forces the front of the floats into the water and the plane pivots on them. My floats are home made flat bottom.
JRickey is offline
Old 11-27-2007, 02:57 PM   #12
CygnusX1
CygnusX1's Avatar
I just recently started lake landing my easy glider with floats and, no, it does not steer on the water at all with the air rudder. I found myself always trying to land the plane coming at me so that I could come straight in. THe problems with this are obvious. It's tough to judge the proper landing distance so as not to run ashore. The other problem is that if there is any wind, you restrict your landing direction.
Learning to fly.
http://dcerutti.smugmug.com/
CygnusX1 is offline
Old 11-28-2007, 01:00 AM   #13
Jim Casey
Seaplane Nerd
Jim Casey's Avatar
If one JUST tries to steer with the air rudder it can be disappointing.
It is almost always necessary to couple with the elevator.
No power: weathervane into the wind.
Full UP and enough power to ride up on the bow wave makes the tails of the floats dig in so far back that the plane pivots DOWNWIND around the tails of the floats. Any more power than that and the plane will hump OVER the bow wave and pop up on the step.
My experience has been that blipping the throttle for an air blast just makes more noise as I drift into the God-forsaken swampy briar patch.
No matter what, always have a rescue boat handy.
Old 11-28-2007, 01:49 AM   #14
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Jim,
Which guy is you???
Frank
Old 11-28-2007, 02:43 AM   #15
constantCrash
prefectionist
constantCrash's Avatar
Send a message via AIM to constantCrash
Is it me, or is that one REALLY big stump in that picture.
I wanna be a pirate. Arrrrr
AMA - 885997
constantCrash is offline
Old 11-28-2007, 07:43 AM   #16
Detroit Dave
I have three planes on floats and one seaplane. They all have water rudders. They all have only one, two looks impressive on a float plane but only one is usually necessary for good handling on the water.
It's almost no weight and it makes handling on the water as easy as a plane with wheels.
The bottom of the rudder only needs to be about an eighth of an inch below the floats. When you taxi slow, the rudder will be in the water, when you pick up speed and the floats are up on the step, the rudder will be out of the water since you will have the speed for the air rudder to take over.
But for now, around here anyways, it's too cold for float flying....the floats work great on snow and for that you don't really need a water rudder.
Well, maybe I'll go work on the bipe I have on the building table.
Dave
Old 11-29-2007, 12:02 AM   #17
Jim Casey
Seaplane Nerd
Jim Casey's Avatar
Originally Posted by Murocflyer View Post
Jim,
Which guy is you???
Frank
HeeHee! I stumble into these pics on the net from time to time, and I hold on to them for situations such as this.
Old 11-29-2007, 12:48 AM   #18
Franny
Stupid Gravity!
Franny's Avatar
Default Some photos of the Gasser
Hi Guys,
So, I thought you might like to see a few photos of the Gasser on floats and an E-Starter on floats at the lake up in Seattle this summer.
I have found that if the speed is low, then there is almost no authority of the air rudder, but if you get it up on plane then it works great! You have to keep your nerve up with the speed though... I do like coming to a halt and having it weathervane into the wind.
Flying off water is, some how, quite a bit different than flying off land. It should be about the same, but I tend to fly a lot slower with lots of low passes. Weird... Love greasing it in over glass and then full power and watching the water drip off the floats as it heads up. Very Zen...
Franny
ID:	48236   Click image for larger version
ID:	48237   Click image for larger version
ID:	48238   Click image for larger version
ID:	48239   Click image for larger version
ID:	48241   Click image for larger version
ID:	48242   Click image for larger version
ID:	48243   Click image for larger version
ID:	48244   Click image for larger version
ID:	48246   Click image for larger version
ID:	48247   Click image for larger version
Franny is offline
Old 11-29-2007, 04:27 AM   #19
RocketMan
What a Blast!
RocketMan's Avatar
Wow, those are fantastic pictures and great flying too by the looks of it! I'm having a hard time deciding if being the photographer or the pilot would have been more satisfying.
I'm dying to try my E-Starter on floats but 'common sense' is yelling at me to wait until next summer (or until I can try them on snow)...
RM
RocketMan is offline
Old 11-29-2007, 04:48 AM   #20
Franny
Stupid Gravity!
Franny's Avatar
Thanks RM! Those GWS floats take an entire hour to build I think. The E-Starter even has that rear slot all ready to go! It is a great airplane for floats and, as you can see, it floats!! I say Go for it!
That was an AWESOME vacation! I got to fly in the morning and afternoon each day right out in the back yard. It sure is great to have relatives that bought right may years ago right on a lake. God bless 'em!
f
Franny is offline
Old 11-29-2007, 05:49 AM   #21
RocketMan
What a Blast!
RocketMan's Avatar
f
Hi Franny, I keep seeing that picture of your E-Starter on its back and the fact that I don't have any kind of rescue 'boat' yet :-) I think maybe I should build that rescue 'boat' first and then if the lake hasn't frozen over yet have a go at it! I have the luxury of living next to a lake - the houses across the street from me are on the water and there is lake access from a small park about 100 yards away. Oh yeah I should have mentioned that there is a dam at the end of the lake near where I would be flying and the water flow over the dam is more than it should be this time of year. I can visualize my E-Starter drifting slowly but surely towards the model airplane equivalent of Niagara Falls. lol.
On the other hand the lake is going to freeze over by sometime in January and then I will have my own flying field within 5 minutes walk! I understand that the GWS floats work really well on the snow. I can hardly wait to give it a try after the first big storm. Cheers,
RM
Old 11-29-2007, 07:13 PM   #22
Franny
Stupid Gravity!
Franny's Avatar
Hey RM,... Sorry about that. I guess I wanted to show just how well it floats! Look at that! The leading edge is out of the water! It is a fabulous airplane for the lake. I would suggest that you use that CorrosionX on the electronics to protect them and if you have a mis-hap, just wait for the wind to blow it ashore. That E-Starter was powered with an E-flight 370 outrunner and a 900mAH Lipo. That was a great setup. Nice long flights, low cost and perfect balance. I was even able to make use of the stock motor and mount.
Well, I hope you decide to take the plunge - so to speak!
Franny
Franny is offline
Old 11-29-2007, 07:44 PM   #23
Bub Steve
Bub Steve's Avatar
Friends: (89)
Default done good, real good!
Franny:: you done good, real good! Your planes are So pretty! MINE ARE UGLY!!took me half the night to put my last 3-4 GWS floats togather ( micro ballons, cabasile , mill-fibers & epoxy, etc,) and I use um on most my planes ( tall grass but sometimes H2O) CorrosionX is the hot set-up no matter the high $, , your bub, stevecooperPS my fundango's gone after 12 years, BOO Hoo!
Name:	petty an red 001.jpg
ID:	48272   Click image for larger version
ID:	48273   Click image for larger version
ID:	48274   Click image for larger version
Name:	petty an red 077.jpg
ID:	48275   Click image for larger version
ID:	48277   Click image for larger version
Name:	petty an red 115.jpg
ID:	48278   Click image for larger version
ID:	48279   Click image for larger version
Name:	petty an red 300.jpg
ID:	48280   Click image for larger version
Monkey Minion'air
Old 11-29-2007, 08:08 PM   #24
RocketMan
What a Blast!
RocketMan's Avatar
Hi Franny I totally agree with stevecooper that your planes are beautiful and I really like that little gasser! I did have some problems preventing my GWS floats from leaking so it took me a lot more than an hour to put them together... lol.
I have a brand new bottle of CorrosionX ready to put in service.
Have you looked at the Capricorn flying boat?
http://www.wattflyer.com/forums/showthread.php?t=26120
I've been collecting materials to build one. It might be a good backup to push that E-Starter to shore :-)
Cheers.
RM
Old 11-29-2007, 08:54 PM   #25
Bub Steve
Bub Steve's Avatar
Friends: (89)
RocketMan::It might be a good backup to push that E-Starter to shore :-) heres my 10$ back-up! your bub, stevecooper
ID:	48284   Click image for larger version
Monkey Minion'air
Flying from water Nathan Seaplanes E-Powered 41 05-16-2009 05:23 AM
Up elevator needed for level flight trim help needed phupper General Electric Discussions 10 10-08-2008 03:17 PM
Flat wing with rudder rudder pointless? John Boy Hi-Performance and Sailplanes 26 02-08-2008 02:04 AM
Too much water simibill Humor 0 11-08-2007 10:57 PM
Water take off!! Airhead Off Topic Chit Chat 7 03-23-2007 08:45 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Page generated in 0.25010 seconds with 101 queries
