Standard & Large E-Heli Talk Discuss all standard and large sized electric rc helicopters in here
kill switch
Old 11-28-2005, 01:52 PM
215 chief
Default kill switch
Does any one know if I can program my futaba 8u to use one of the switches for a kill switch.
Today on my electric raptor 50 I lost throttle control and had to reach under unplug on of the lipos to kill the motor. I dont know why I lost control but I am glad I was on the ground when it happened.
215 chief is offline
Old 11-28-2005, 09:28 PM
savydad
If you lost control from the tx, how would a kill switch have prevented your scenario? If control is lost, it's lost, a switch wouldn't help anything. Disregard if your esc just glitched, but I don't think it would help any if you could program it in.
Todd
savydad is offline
Old 01-30-2006, 02:20 AM
Tom Lambert
Thumbs up Kill switch
I added a mechanical switch to my battery positive line as an emergency kill switch. That was after my throttle servo ceased to function. I can now flip the switch with either my (not recommended) hand or with a long 6 Mill. carbon fiber tube or wood dowel.
I found it easer to use a switch instead of trying to unplug a battery connector. Especially with the motor running!
Tom Lambert
Tom Lambert is offline
Old 01-30-2006, 01:34 PM
215 chief
Thanks for replying, I thought it was a good idea but the other reply didn't seem to agree. It would also keep the Deans conn from getting carbon build up from arching when making the connection live.
Now the real question what kind of switch and how heavy (amperage wise) did you use. How about a automotive relay. My raptor is using 2
lipo packs a 3 cell and a 4 cell in series. and a 70 amp controller.
Do I need a switch to carry all 70 amps?
Brian
Old 01-30-2006, 02:22 PM
qban_flyer
Guest
Posts: n/a
Lightbulb
We used to have a paddle kill switch on our e-powered sailplanes back a few years ago. We also had an automotive fuse on the negative leg of the circuit so that if case things got a bit "hairy" and the prop would hit an obstacle while spinning it would blow the fuse instead of the ESC. Fuse size used depended on motor current draw.
I still use that set up on a few of my larger sailplanes, just to be safe. See attachment.
Old 01-31-2006, 05:57 PM
Gnome
Gnome
Back when I raced 1/4 scale cars I put in a radio kill switch so I would not have a 20 pound car running wild. When you lose radio usualy the servos jam full right or left. I mounted the kill switch so full right or full left would kill the engine that way I could kill it myself or it would self kill if the servos jamed from loss of signel.
Gnome is offline
max2112
Crash and Safety Forum
39
02-18-2009 03:56 AM
soundbound
E-Flite Helicopters
07-31-2008 01:40 AM
Glacier Girl
Electric Ducted Fan Jets
20
06-18-2008 05:08 PM
diverdon
Support & Suggestions
9
04-30-2008 01:11 AM
FlyingMonkey
Off Topic Chit Chat
25
11-26-2007 07:43 PM
Quick Reply: kill switch
Page generated in 0.06711 seconds with 12 queries
