Acromaster Power Setup?
Old 02-10-2008, 11:54 AM
Eganwp
Default Acromaster Power Setup?
Hey guys, going to pick up an AM very soon here. Just waiting on the DX6i release before I make my purchase.
I've been heeing & hawing over for the past 2 weeks (read every setup/review there is on the web with regards to the acromaster, the best one being http://www.bungymania.com/acromaster/indexcontest3s.php ) and can't decide between these 3 motors:
TR 35-42D 1000kv (4mm shaft is a bit of a downside to this one)
http://www.hobbycity.com/hobbycity/...?idProduct=3884
TR 42-40B 900kv
http://www.hobbycity.com/hobbycity/...?idProduct=4912
KD 36-12L 1000Kv
http://www.hobbycity.com/hobbycity/...?idProduct=2128
I'd like to run a slightly larger prop (12x6 minimum, prob 13x7 or 13.6x6 I would guess most of you would recommend as ideal) as it probably gives better thrust. Would like to use my 3s TP 2100 Pro Lites but I'll also grab a couple 2500's too. Do note that I'm flying at 3800ft ASL, so a 10-12% "prop-up" equates the same performance & amp draw as at sea level for a good chunk of you.
Is there anyone out there who has experience with multiple motor & prop setups with this thing? I want loads of power & good efficiency (8-10+ min flights) while trying to stay under 40A if possible. I basically am looking for the best performing/efficient cheap power setup for it. Or maybe someone has motor comparison #'s out there? I'd like to hear other's power setup, prop, amp draw, flight times, flying altitude and your general favorite setups on this thing too!
Thanks guys!
<!-- / message --><!-- edit note -->
Eganwp is offline
Old 01-13-2009, 06:00 PM
imk629
ChicagoNewGuy
Default Which motor did you choose?
I am thinking about buying this as a second airplane. Obviously, my skills are primitive; I'll end up using this model more as a sport plane than a 3d acro plane.
Which motor did you choose? Did it work well? Also, what speed control and what servos did you end up using?
imk629 is offline
Old 02-01-2009, 07:32 PM
Eganwp
http://www.wattflyer.com/forums/showthread.php?t=35708
Eganwp is offline
celticflyer
Foamies
10-04-2008 03:30 PM
okayplayer
Electric Ducted Fan Jets
04-20-2008 01:43 AM
Dorsal
08-13-2007 02:20 AM
ForestCam
Warbird Electrics
18
06-13-2006 05:35 AM
RCBobby
3D Flying
12-18-2005 03:22 AM
Quick Reply: Acromaster Power Setup?
Page generated in 0.10696 seconds with 11 queries
