Thrust to Speed?
Old 02-23-2008, 03:12 PM
stinkweed007
stinkweed007's Avatar
Default Thrust to Speed?
Is there a formula for thrust to velocity?
ie, I have a motor/prop which, when at full throttle, produces 720 grams of thrust, what is the speed which that air is moving?
stinkweed007 is offline
Old 02-23-2008, 03:48 PM
fr4nk1yn
^_^
fr4nk1yn's Avatar
Thrust can't be directly converted to speed.
A larger prop can produce that much at relatively slow speeds while a small prop will need lots of rpm and pitch speed to produce that much.
Working backwards with prop size you could probably estimate.
Try badcock.nets calculator and using your prop, play with the RPM until you get your thrust. Pitch speed should be close.
fr4nk1yn is offline
Old 02-25-2008, 12:05 PM
Buck Rogers
Strangely I was thinking about this just a couple of days ago. I cant see why you shouldn't be able to come up with a formula that gives a good estimate. I will have a go at working it out when I gat abit of spare time.
Buck Rogers is offline
Old 02-25-2008, 05:45 PM
stinkweed007
mind you, I am in no way attempting to use grams of thrust to determine the speed of the end aircraft... but I can only imagine that so-and-so many grams of thrust must move at so-and-so speed regardless of rpm, volts, watts, prop and motor..
Old 02-25-2008, 05:53 PM
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Stink -- speed is determined by RPM and prop pitch.
Thrust is determined by RPM and prop diameter.
The above statements are very general, and there are other factors, but that's the easy way to look at it.
This is why smaller props, at high RPM, will push an airplane very fast, but have low thrust. Likewise, a 17x9 prop spinning slowly, will haul a Slow Stick straight up -- but not very fast.
Think of how a helicopter works: When a helicopter is hovering, the thrust is equal to the weight -- but there is NO SPEED.
There IS a formula to convert RPM into prop pitch speed, based on the prop pitch. If you are interested, I will be happy to share that formula with you.
Finally:
  • Think of THRUST as "low gear" -- like a tractor tread pulling a huge tractor through the mud, and over trees.
  • Think of SPEED as "high gear" -- like a formula 1 racer, flying down the track. Think about how those same cars must be PUSHED out of the pits! (Because they are built for speed, not thrust!)
Generally speaking, power systems have really good SPEED, or really good THRUST, or have a just a fair combination of both.
Old 02-25-2008, 07:54 PM
Sentertainment
Hobbyist/Web Developer
Sentertainment's Avatar
To my understanding, in small flyers you usually want more speed, in large flyers you want more thrust in most cases.
Thrust is pretty much just the strength. If the motor has very little thrust, that's not good either, it needs to have enough strength to move the prop(s).
Sentertainment is offline
Old 02-25-2008, 08:42 PM
Lieutenant Loughead
UNCLUB OWNER
Ahhhh -- not true, young grasshopper! It doesn't matter what size airplane you are talking about; what matters is the APPLICATION.
I can show you a 10-ounce flat foamy, which is designed to "3-D hover", and has 15 ounces of thrust at full throttle -- but only 29 mph of prop pitch speed.
I can show you another 10-ounce flat foamy, which is designed to be a "parkjet". It uses twin ducted fans, and only delivers 6 ounces of thrust at full throttle -- but creates 49 mph of prop pitch speed. (Jet airframes want to travel fast!)
Well, you need enough thrust to overcome the drag of the airframe -- not just the prop. I have had many test flights, where the thrust was not enough to overcome the drag of the airframe at increased speeds... :o
Remember -- the drag of the airframe increases EXPONENTIALLY, as the speed increases in a linear fashon. In other words, you need more thrust, the faster you want to go. You end up hitting a barrier at some point -- just after World War II, the barrier was the sound barrier. Now, the barrier is the speed of light.
Well, okay, the existing barrier is actually much lower than that, but it sounds cool...
Old 02-25-2008, 09:56 PM
Buck Rogers
Ok, I think this is possible, I managed to put an almost working spreadsheet together at lunchtime. All you need to do is to go back to the equation F = MA where F = Thrust and M is worked out based on the volume of air passed through the prop x air density x pitch speed and A will be the pitch speed.
The trouble comes when working out the air volume passed through the prop because it is not the same as the prop diameter - you need to apply a correction factor which you can work out using test data (eg from a motor test).
You can then work back to get prop pitch and RPM based on thrust and prop diameter.
I'll put the spreadsheet and equation up on the web if I get the chance tomorrow.
Old 02-25-2008, 10:06 PM
Lieutenant Loughead
UNCLUB OWNER
I look forward to understanding how you tackle calculating mass from the volume of air passed through the prop. I understand air has mass -- but what about altitude, temperature, humidity, etcetera?
Also, I really don't see how you can use pitch speed (miles per hour) to calculate acceleration (feet per second, squared). That's like me telling you my car can go 120 mph at top speed -- what's my best acceleration?
Old 02-26-2008, 12:13 PM
Buck Rogers
Well, I have a degree in Aerospace Engineering and I've done this sort of thing before - it was a few years ago though so I might need to look through my notes again.
You are right that to get an acurate result you must take into account altitude, temperature etc. Since we are only looking for an approximate value here I suggest that altitude and temerature (which ultimately effect air density) will be the dominant factors and we can ignore humidity.
Actually working out the the mass of air the prop moves will be very complicated. It should be possible to get a reasonably good aproximation using empirical data to derive a correction factor that can be applied to the prop diameter to take acount of the efficiency lost at the prop tips etc. Probably a different correction factor would be needed for different prop types and manufacturers but it should be easy enough to work out.
Once you have the effective area the prop works on it should be possible to work out the pitch speed needed to move the required mass to give the thrust (which we already know).
Of course all of this will only be relevant to working out pitch speed in the static test situation and wont tell you how fast the plane wil go.
Old 02-26-2008, 02:26 PM
fr4nk1yn
^_^
fr4nk1yn's Avatar
A lot of work instead of using a tach I think.
Wouldn't figuring out air mass be much harder than figuring prop speed?
Using thrust and prop size shouldn't be too hard. A given prop will have to turn at a certain speed to produce a certain thrust.
fr4nk1yn is offline
Old 02-26-2008, 03:38 PM
Lieutenant Loughead
UNCLUB OWNER
I've been considering going back to school for a Masters in Aerospace Engineering...
Old 02-29-2008, 06:26 AM
neonbjb
Isnt thrust related to both pitch and prop size? I've always figured it was something like kxvxp where k is a constant, v is air flow through the prop, and p is the total area that the prop covers. I mean, two 90mm fans can put out different thrust figures despite being exactly the same fan, so air speed has to make a difference.
If there was such a formula, given prop diameter and thrust, one could feasibly find the speed out of the prop.
neonbjb is offline
Old 02-29-2008, 08:39 AM
stinkweed007
thats kind of what I wasnt going for.. Im not worried, at this point about the speed of the craft, however in this instance, while the thrust is equal to the weight, I am wondering how fast the produced thrust is moving, not the aircraft.
I might have failed in my word useage, so here in my attachment is what I am trying to figure out.
I have a little brushless attached to a small RTF model replacement prop which pumps out a screaming 720g of thrust.. or at least force on the scale.. I just want to know, not how to produce that thrust (which I believe dives into the whole prop vs rpm vs everything) I am already at the thrust. just looking for the wind speed that is being produced.
I hope that made sense..
Old 02-29-2008, 03:23 PM
Lieutenant Loughead
UNCLUB OWNER
Stink, why not just buy one of these:
anemometer
Wind Meter
Old 02-29-2008, 04:21 PM
stinkweed007
geeze LL... didn't see that one commin... there has got to be a rule or formula for it..
Old 02-29-2008, 04:30 PM
Lieutenant Loughead
UNCLUB OWNER
LOL -- no need for the dripping sarcasm, Stink... I was just trying ot help... :o
Old 02-29-2008, 04:34 PM
stinkweed007
well, I did price one at amazon.. you can get em pretty cheap.
Old 02-29-2008, 04:59 PM
Lieutenant Loughead
UNCLUB OWNER
Exactly -- you have to figure what you time (and everyone's time on this thread) is worth, and compare that against the price of a wind speed meter.
With the wind speed meter, you get your answer -- no questions.
With this thread, you get a bunch of "maybe"s, and "unsure"s... :o
Old 02-29-2008, 06:21 PM
pburt1975
Hotel California
pburt1975's Avatar
Wouldnt the speed of the air leaving the blade have to match the inrush of air entering the blade? IOW
Put that prop in a 10" diameter tube (if a 9" prop) and run it up. If its pitch speed is 25mph at the given RPM, then the air leaving the tube is = to the air entering. I believe the only way that number would change is if the air expanded on the back side of the prop. Creating a larger volume of air to be pushed out.
Thats somewhere to start. Knowing how much the prop unloads or flexes in use will affect the equation some but I'd have to wonder how precise you need this to be?
pburt1975 is offline
Old 02-29-2008, 11:35 PM
Lieutenant Loughead
UNCLUB OWNER
I'm sure there are all kinds of vortices (eddie currents)...
Actually, I've got a new fog machine I'm supposed to receive very soon... Maybe I'll shoot fog into a spinning prop, and capture it on video...
Old 03-01-2008, 01:30 AM
stinkweed007
yall are just killin me...
Old 05-19-2008, 10:25 PM
Harry Lime
Default Thrust, Revs and Horses
There is a great and rigid formula expressing the connection between Thrust (static) Revolutions (dependent on propeller diameter and pitch) and Horsepower (generated by the engine at the crankshaft - glowplug or electric).
Unfortunately nobody knows what the formula is because there are too many practical variants like prop blade-width, section, thickness and helical geometry. This would be the Theory of Everything and it goes like this:
Start your elecric motor spinning and the more the volts, the higher the revs. Now stick a small diameter prop on the shaft and the motor slows down - but produces useful Thrust. If the prop is small the motor will only fly a small light model. Depending on the prop pitch it will fly that model at a certain airspeed called the 'Pitch Matched Airspeed' or somesuch and no faster, provided the model lets it. This is the Crunch. In other words the model has to be light enough and streamlined enough to allow speed to build up to the potential speed dictated by the pitch and no faster.
Fit a prop with greater pitch and the model goes faster, up to the matched speed allowed by the pitch, again assuming a 'slippery' model.
But there comes a point when increasing the pitch has no further effect on speed as the model's aerodynamic shape, size, weight, finish and drag predominates and won't allow it to go any faster.
Pitch is everything - assuming your motor has the reserve of power.
Measuring static pitch (with the model tethered to a spring measuring- gauge) is not valid as the model has to speed up to its matched pitch speed.
However you can do a weird experiment here, a bit like in a wind tunnel in fact. Have your wheeled model on a table with the spring gauge hooked up to the tail and run the motor. Let's say it reads 100 grams of static thrust. Now direct an electric fan at the model head-on. Lo and behold, the model moves forward towards the fan, magically converting blow into suck!
You can now take the true dynamic thrust tmeasurement.
There is more if anybody is interested,
Harry Lime.
Harry Lime is offline
Old 05-19-2008, 11:48 PM
Lieutenant Loughead
UNCLUB OWNER
That IS strange... Now I'm going to have to try that!
Old 05-20-2008, 01:29 AM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Guy,
I have to get clarification on this one.
Scott Stoops says "...lower pitch propellers create very high thrust at lower velocity, and higher pitch propellers create lower thrust but a much higher velocity."
That seems to contradict what you say above. Can you help us out here?
Thanks,
Frank
Murocflyer is offline
Quick Reply: Thrust to Speed?
Page generated in 0.19286 seconds with 12 queries
