A Scratch Builder (Trying to do the "Nasty")
Old 07-09-2008, 07:18 PM
TylerJCooper
TylerJCooper's Avatar
Default A Scratch Builder (Trying to do the "Nasty")
Hey WF,
I really have been wanting to learn to build foamies and after spending a few months on WF I think I am ready to give it a shot. Therefore, this thread is more about a "scratch builder" then a "scratch build". I would love everyone's help to walk me through my first build. I have read quite a bit, but there is two questions that come to mind. First, what should I build? I would like to do something 3D, that could be powered by a 370 or 450 e-flight brushless motor. I will also need to know where I can get plans. Secondly, what foam and where do I get it? My LHS doesn't carry foam. I have asked this question before, but I am going to need more specific answer please, such as, website, store names, and the name of the foam. Lastly, I don't have much money, therefore, I don't need the best performing products, but most reasonable.
Thanks for all you help and support,
Coop
TylerJCooper is offline
Old 07-09-2008, 07:54 PM
aero_k
aero_k's Avatar
Hey Coop. I did my first scratch build in the Winter and it was a lot of fun, and was certainly a learning experience. One thing you should be prepared for is the inital cost for all the tools you need: Xacto knives, various tapes and glues, a cutting mat, soldering iron, etc. I found that everytime I'd make a little progress, there was something I needed to go buy because I didn't have it. Once you have everything, you can build a plane for close to $20. I'm still in school and in a ton of debt, so keeping things cheap is essential for me.
Have a look here for plans: http://www.wattflyer.com/forums/showthread.php?t=14868. My first build was the NASTY 3D by waterdog at RCG. It was pretty straight forward to build. Too bad I crashed it 5 seconds into the first flight and ended up tossing it in the garbage. There were a lot of things wrong with it due to my inexperience, but my next build, the Infineon i3D, went much better.
As far as materials, I have been using Elmers Foam board from Michaels craft store. There are also similar types form Dollar store and Walmart I think. You can get it for $1 or $2 a sheet, so its pretty cheap. Its about 5mm thick with paper on each side. Removing the paper will reduce the weight by more than half, but will need some stiffening. Remove the paper by putting it in a big garbage bag with some rubbing alcohol and water, enough to soak it. Let it sit for a few hours, then remove and let completely dry. The paper should just peel off. You can do several sheets at a time.
Others use Bluecor, Protection Board III, or Fan Fold Foam (FFF), which is blue insulation foam. Sometimes it can be hard to find, but a lot of people use it and its fairly cheap as well I think.
For glues, I use low temp hot glue, Gorilla glue, and foam safe CA. Hot glue is heavy, but its cheap, and dries quickly. Gorilla glue is great and holds things very well, but takes a few hours to set. Others may have other suggestions, but this is all I have ever needed for foam builds.
For powering your plane, HXT 9g servos are great, and TowerPro or Turnigy brushless motors are usually pretty cheap. Look at HeadsUpRC.com or Hobby City for these. Loong max lipos work well and are cheap as well. I would avoid the Mag8 escs though. I bought some 'Turnigy Basic' escs that seem pretty good, and were also cheap.
I hope thats enough to get you started. I'm also pretty new to this, so I'm just sharing my experience and its worked for me so far. Just keep reading threads on here and you'll learn a lot. Good luck!
aero_k is offline
Old 07-09-2008, 08:38 PM
TylerJCooper
Aero K, that was great. Filled with a great amount of info. It was really helpful to hear your advice on the foam. It also makes me feel better to know that this hobby doesn't always have to cost an arm and leg. It appears that I have most of the supplies needed. Just need to get some foam, glue (possiby glue gun), and a plan. Can't wait!
Old 07-10-2008, 05:28 PM
TylerJCooper
Well, I have picked out a design today. I am going to go with the Yak54. http://www.eflightwiki.com/eflightwi...p?title=Yak-54. I have drooling over Yaks for sometime now. Will 6mm cellfoam be sufficient?
Old 07-10-2008, 06:35 PM
King Cobra
Permanently Banned
I just happen to be scratch building a 3-D Nasty. If all works out. I will go to my 6' wingspan scratchbuild of the same plane..The proto type of my design can come later. I will disclose the name of the plane I designed later and try and put printable plans for all to use as did the fella that designed the Nasty/Big Nasty. Matt
King Cobra is offline
Old 07-10-2008, 06:37 PM
TylerJCooper
Default Change of Plans
After consulting some people at my LHS and looking around here. I have decided to us the Nasty plane design. I plan on using 5mm Cellfoam and a slow glue gun. Before starting, I would like to make sure that I have a motor that will power it. I have two eflite brushless motor. The 450 and 370. Will one of these work?
Old 07-10-2008, 06:44 PM
King Cobra
Permanently Banned
My foamy is quite simular to the Nasty.But I will build the Nasty first( see photo to come). I will be using a Zagi 400 I believe. A 400 should be just fine if you pay attention to weight. Here is a photo of my cut-outs. I am using white foam (very light) and will be using light weight carbon 'Arrow'rods. Matt
Old 07-10-2008, 06:46 PM
King Cobra
Permanently Banned
Default My scratch build
Sorry, here it is. It is a mess to sand with all that stuff sticking to ya. But, very easy to form. I will be coating the foam with a skin also for strength, etc. etc. Matt
Name:	My 3-D Foamy.jpg
Old 07-10-2008, 06:49 PM
King Cobra
Permanently Banned
If you have the 450, by all means use it! The more power the better. If you happen to go a little over weight, you won't have to worry about it. Matt
Old 07-10-2008, 10:35 PM
TylerJCooper
Thanks Matt. It sounds like a plan. I am spending most of my day off organizing my hobby room (garage) to get everything in order. I plan on trying to start working on it next week and will start a thread to get all the help I can get.
Here are the plans for the plane:
http://www.rcgroups.com/forums/showthread.php?t=390003
Old 07-11-2008, 12:07 AM
King Cobra
Permanently Banned
Cool, I look forward to seeing that. I will do the same. I will be using HS-55 servos, and I will identify the motor when I get to it. I may have a 480. I hope I have a 480 because my plane may be a bit heavier because of the carbon reinforcements I need to do to my white foam. Thanks for showing me the plans. Matt
Old 07-11-2008, 03:17 PM
aero_k
aero_k's Avatar
Good choice on the Nasty. I'd like to try building another one, but I don't have the time at the moment. I agree, go with the bigger motor. I used a Towerpro 2409-12 I think with a 1047 prop and it took off almost vertically right out of my hand. Unfortunately I think I was tail heavy and didn't have enough throw on my elevator, so it stalled and nose dived into the ground, breaking the stick mount and bending the motor shaft.
Anyway, good luck with the build! Try to keep it as light as you can. Its easy to go crazy with the glue gun, but it can add quite a bit of weight. Think of how much one glue stick weighs and how many you go through to build the plane. It adds up fast.
aero_k is offline
Old 07-11-2008, 05:53 PM
King Cobra
Permanently Banned
I agree about the glue sticks weight. I gave up the glue gun long ago. I either use 5,10 or 20 minute Hobby Poxies,and it doesn't take much to get a good bond. 5 minute is usually good and quick for all foam planes and can get you in the air almost just as fast as using a glue gun. It is less weight and, I believe worth the wait to get a lighter plane. Like most say, don't rush it. For balancing, I imbed BB's into the foam. For my white foamy, I will be starting out with a 40 grit sanding block on my leading edge and fuse and eventually finishing with a 120 grit. I don't advise anyone using white foam but I had a 4' X 8' sheet laying around. I will have some extra reinforcements to do, but it will work fine. Matt
Old 07-11-2008, 07:11 PM
aero_k
aero_k's Avatar
I agree, 5 minute epoxy works well. I find it a little messy and I don't like stinking up my apartment with it, so I don't use it as often.
aero_k is offline
Old 07-11-2008, 07:35 PM
TylerJCooper
I currently don't have epoxy and my RC fund is depleted until mid next month. I am hoping that the 450 will power the extra weight that is added by the glue gun.
Old 07-11-2008, 07:55 PM
aero_k
aero_k's Avatar
Looks like that motor should be fine for the Nasty. I think you should be able to keep it under 20oz, so you'll have plenty of power.
Specifications
Type: Brushless Outrunner
Size: Replacement for 370 or 400
Bearings or Bushings: Ball Bearings
Recommended Prop Range: 9x6 to 11x3.8 Slow Flyer or 10x5 to 12x6 Electric
Voltage: 7.2 - 12
RPM/Volt (Kv): 890
Resistance (Ri): .20 ohms
Idle Current (Io): .69A @ 8V
Shaft Diameter: .16 in (4mm)
Weight: 2.5 oz (72 g)
Diameter: 1.1 in (28mm)
Length: 1.3 in (33mm)
Continuous Current: 14A
Maximum Burst Current: 18A for 15 seconds
Cells: 2-3 Li-Po or 6-10 Ni-Cd/Ni-MH
Speed Control: 20A Brushless ESC
The Park 450 is ideal for 3D park flyers 15- to 25-ounce and scale park flyers 20- to 30-ounces using 2S - 3S 1200 2100mAh Li-Po battery packs. It will provide sport 3D performance for a Mini Edge size plane and great performance on the new E-flite P-47
aero_k is offline
Old 07-11-2008, 08:23 PM
King Cobra
Permanently Banned
Not to worry. Many folks use the 380 and 400 and they say that they get great results. They also used the glue gun. I am sure that the glue gun material is calculated in the flying weight of the models that they build. Give us the link to your build when you get it going. Matt
Old 07-11-2008, 08:40 PM
TylerJCooper
Sounds good. I am going to just keep this as the building thread. I did the cut outs last night and going to be the pics up soon. The only problem is that the foam I have is 1/2 inch too short for the width of the wing. I think I am going to use it and adjust the fuselage to fit. I will put some pictures up to get a visual.
Old 07-11-2008, 08:47 PM
King Cobra
Permanently Banned
Very nice. Will be watching. Matt
Old 07-11-2008, 09:53 PM
aero_k
aero_k's Avatar
I assume you mean that your foam is not long enough to do the whole wing span in one piece. Do the wing in two halves and just glue it in the middle. Its plenty strong enough, if not stronger. If its not wide enough (chord is too large for the foam) you can try cutting the wing and the ailerons separately to reduce the width of the wing. You'll just have to make sure you make smooth, straight cuts to the ailerons will fit well to the trailing edge of the wing.
Or, scaling down the plans works too, but it sounds like you have already started cutting...
aero_k is offline
Old 07-11-2008, 10:21 PM
King Cobra
Permanently Banned
If you lose 1/4" on each wingtip, you will be ok. Take a ruler and measure from the fuesloge to each wing tip to see how well centered you are. And as Aero K says, two piece main wings are fine because you will be using a carbon rod and the seam will be at the fuse. Be sure to use the balsa braces against the fuse carbon rods for added strength. Matt
Old 07-12-2008, 08:09 PM
TylerJCooper
Here are a couple pictures of what is going on. You can see that I have finished the cutouts an taped them together. You will notice that the length of the wing is alright, but I am going to have to shorten the width of it. I have not begun cutting the cellfoam, so we still have some time for some adjustments. Tell me what you think.
ID:	72374   Click image for larger version
ID:	72375   Click image for larger version
ID:	72376   Click image for larger version
Old 07-12-2008, 10:04 PM
King Cobra
Permanently Banned
Tyler: Looks very nice. I am off to start my 'Nasty' build thread and after I start it, may I put the link here for you and others to follow. I understsnd that this is your build thread and I was just wondering. I will be using the Zagi 400.Thanks. Matt
Old 07-12-2008, 10:48 PM
TylerJCooper
Matt you are more then welcome to link the thread. I also encourage you to use this thread. It is titled "Trying to do the Nasty", therefore, if it is a Nasty, you can do it here.
Old 07-13-2008, 12:39 AM
TylerJCooper
Well the outline is made and now time for some cutting. You can see how much width I am losing on the wing outline. However, I don't foresee it being a huge problem.
ID:	72416   Click image for larger version
Quick Reply: A Scratch Builder (Trying to do the "Nasty")
Page generated in 0.12881 seconds with 18 queries
