Multi-motor setup question.
Old 07-18-2008, 04:11 AM
Firestem4
inexorably eccentric
Firestem4's Avatar
Default Multi-motor setup question.
Hello. I was hopign someone could help me. I've asked around and felt i should ask in here to get a definitive answer.
How coudl you set up twin or quad-motor (brushless in/outrunner), 4 esc's, 2 to 4 batteries, on one channel? Is that possible?
I'm really into twin prop and possibly 4 prop (stratofortress.) or twin/4 ducted fan planes. (jetliner etc)
Firestem4 is offline
Old 07-18-2008, 05:18 AM
Dorsal
If it Flies, I love it!
Dorsal's Avatar
1) Setup with 4 identical motors AND 4 identical ESCs
2) Connect 2 ESCs to a Y-connector (let's say this is the left wing)
3) Connect the other 2 ESCs to a Y-connector (let's say this is the right wing)
4) Connect the male plug from both Y-connectors to a third y-connector and plug that into your throttle channel on the receiver.
Note:
AS LONG AS all 4 ESCs are identical, the output voltage from each should be within 0.1 volt of each other, so there will be no problem using the BEC circuit from all of them at once and you won't need to remove any red wires. Use a voltmeter to verify the outputs, it is important, as this will only work if the voltages are well-matched. Otherwise you WILL ruin at least one ESC.
5) Connect an identical battery to each ESC
Dorsal is offline
Old 07-18-2008, 05:50 AM
Bub Steve
Bub Steve's Avatar
Dorsal""ESCs are identical, the output voltage from each should be within 0.1 volt of each other"" are the cheaper ESC's more likely to be off more that that?on my twins I've never been able to get mine to match up and always have to cut the one red one out to get them right, I've been using Tower-pro 25ESC's and they don't work well together, thanks for the info my bub, steve
Name:	petty an red 539.jpg
Bub Steve is offline
Old 07-18-2008, 06:23 AM
Firestem4
Firestem4's Avatar
Thanks so much Dorsal!
Old 07-18-2008, 07:49 AM
Dorsal
Dorsal's Avatar
stevecooper, I've never really tested beyong the 2 twin setups that I have. I run Castle Creation ESCs on both of them (luck of the draw, really) and the output voltage differential was 0.02v on one and 0.03v on the other. A tech at Castle told me about the 0.1v threshold number so I was just looking to stay below that. I've got some pairs of HC ESCs (Turnigy 40A and Tower Pro 18A), so tomorrow I'll hook them up and see what I get.
Dorsal is offline
Old 07-18-2008, 11:13 PM
Bub Steve
Bub Steve's Avatar
Dorsal::I was gonna use those HC 18ESC's on my new twin scratch A-26 look'in plane, My other twins got the house brand HC 25 ESC's and they did'nt like share'in either, that info will be a big help on my new twin, bub, steve
Firestem4
Warbird Electrics
07-16-2008 02:58 AM
Lysander
03-07-2008 02:45 AM
Chip_Mull
01-17-2008 04:03 PM
BeaverBob
07-21-2006 03:45 PM
vax6335
02-28-2006 03:02 PM
Quick Reply: Multi-motor setup question.
Page generated in 0.06710 seconds with 12 queries
