Crash and Safety Forum Punch something in lately? Have safety suggestions? Tell the story, share safety tips, and show the pictures here.
Kyosho Intruder...Down!
Old 08-03-2008, 07:14 PM
Angler-Hi
Angler-Hi's Avatar
Default Kyosho Intruder...Down!
Well the wife and I hit the lake and did a little flying. The Intruder was the first thing I put in the air. I was having a blast when a small gust made her bank to the left...right behind one of the biggest trees I'd ever seen. My wife had a visual and I wasn't too worried because I was trusting my inputs, not what my eyes couldn't see. But when she never came back around the tree, I knew I was in trouble. I yelled out to my wife, "up or down"? She replied with "down". What I was asking her, was which way do I need to go...she thought I was asking which way was the plane going. Needless to say, I thought the plane was going up and was about to stall, so I gave her down elevator...into an already nose dive. She landed about 150 yards away in the brush. When I looked her over, she had damage to the nose and front of the fuse. Everything else was perfectly fine, including my battery. Here's a few pics of the damage. I'll have her fixed tonight...I'll be silking her this time.
ID:	74375   Click image for larger version
ID:	74376   Click image for larger version
ID:	74377   Click image for larger version
Angler-Hi is offline
Old 08-03-2008, 07:31 PM
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Daahhhh!!!!!!!!!!!! i guess no video today for the intruder then?
Sorry to hear that man
you gotta get a better navigator lol
The eagle is down!!! the eagle is down!
wait is the air intake/edf part suppose to be alittle like ovalish? or was it part of the resulting effects of the crash(as in it got smushed) ?
GreenAce92 is offline
Old 08-03-2008, 07:35 PM
Bummer Mike. You'll have fixed up good as new in no time though!
Old 08-03-2008, 08:17 PM
Angler-Hi
Angler-Hi's Avatar
The intake is supposed to be that shape Ace.
Thanks Bill. I'm going to use hot glue on her...works everytime. I'm also going to use some light spackle on her....she was needing a new paint job anyways.
Old 08-03-2008, 08:26 PM
That ougt to do it. Easy with the hot glue though, too much of it will add too much nose weight. Don't want to bog it down too much.
Old 08-03-2008, 08:40 PM
newjak
AMA Park Pilot Partner
newjak's Avatar
Mike,
Before you put her back in the air make sure the fan unit did not dislodge. Other than that you should be good to go in no time.
newjak is offline
Old 08-03-2008, 09:07 PM
Angler-Hi
Angler-Hi's Avatar
Thanks guys...
Old 08-03-2008, 09:09 PM
Angler-Hi
Angler-Hi's Avatar
Default The Repair
Well, I just finished gluing her back together and used light-weight spackle to fill the dents and beat up foam. As soon as she dries, I'll sand her smooth and remove all the decals. I wanted to silk her, but I think she's heavy enough up front.
ID:	74385   Click image for larger version
ID:	74386   Click image for larger version
ID:	74387   Click image for larger version
Old 08-03-2008, 09:11 PM
Angler-Hi
Angler-Hi's Avatar
I'm also gonna glue the plastic coating back together on the foam nose cone with CA and then use a little spackle to even things out...there's just scotch tape on there now holding it all together from the first crash.
Old 08-03-2008, 10:06 PM
Angler-Hi
Angler-Hi's Avatar
Just finished removing all the decals. Still waiting for the spackle to dry. I'm gonna go with some sort of desert camo scheme...we'll see.
Old 08-03-2008, 10:09 PM
Desert camo would look cool, Give it that Israeli look
Old 08-03-2008, 10:19 PM
Angler-Hi
Angler-Hi's Avatar
Thanks Bill...I'll see what I can do as far as getting a few pics of the Isreali look.
Old 08-03-2008, 10:21 PM
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Go hot glue go! love that stuff man
nice repair work
Old 08-03-2008, 10:24 PM
Angler-Hi
Angler-Hi's Avatar
nice repair work
Thanks Ace, but we'll see how she really turns out when I finish sanding her smooth. The paint job will only be as good as the plane itself. I bought her used from a fellow wattflyer...The paint job will definitely improve the look, but she'll still look a bit rough.
Old 08-03-2008, 10:28 PM
John Seidelman
John Seidelman's Avatar
Did a quick searc and found this in a sim application.
File Type: bmp
John Seidelman is offline
Old 08-03-2008, 10:35 PM
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Blue winter camo scheme perhaps?
Old 08-03-2008, 10:43 PM
Angler-Hi
Angler-Hi's Avatar
I think I'll go with a sand color base on top with a brown or camo green camo, and a light blue on the bottom. I'm also gonna give her a coat of water based Polycrylic for extra protection.
Old 08-03-2008, 10:51 PM
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Sounds good just make sure you use the right kinda paint lol or else you'll be disinegrating in mid air lol not cool
Old 08-03-2008, 11:45 PM
Angler-Hi
Angler-Hi's Avatar
I use water based acrylics on my foam planes.
I decided not to reglue the pieces of the plastic covering over the nose cone, but rather remove the plastic all together and just use spackle to fill in the dents and then I will paint it black. The entire plane will have a coat or two of WB polycrylic. Here's a couple pics of the plastic removed from the nose cone:
ID:	74398   Click image for larger version
Old 08-03-2008, 11:46 PM
Angler-Hi
Angler-Hi's Avatar
That looks sharp John, thanks for the pic. I don't have that color green, so I'm gonna go with what I already have. I really appreciate it though friend.
Old 08-04-2008, 01:40 AM
Angler-Hi
Angler-Hi's Avatar
The spackle on the fuse finally dried and it's been sanded smooth. I have a few minor touchups left but nothing major. I just applied spackle to the nose cone and it should be dry in a few.
ID:	74413   Click image for larger version
ID:	74414   Click image for larger version
ID:	74415   Click image for larger version
Old 08-04-2008, 03:14 AM
Looking good mike, she has her figure back now.
Old 08-04-2008, 04:11 AM
Angler-Hi
Angler-Hi's Avatar
Well I've finally got most of it done. I'm laying the base coat on top right now. I'll post pics when that's done.
Old 08-04-2008, 05:04 AM
Angler-Hi
Angler-Hi's Avatar
I thought I would have enough of the color for the base coat on top, but apparently not. I'll have to pick up some more tomorrow morning. Here's a few pics of the nose repair and what I got done on the base coat:
ID:	74433   Click image for larger version
ID:	74434   Click image for larger version
ID:	74435   Click image for larger version
ID:	74436   Click image for larger version
Old 08-04-2008, 05:08 AM
John Seidelman
Looking good so far.
Quick Reply: Kyosho Intruder...Down!
Page generated in 0.14680 seconds with 32 queries
