EFlite Deuces Wild build thread.
Old 08-07-2008, 08:40 PM
Liquidity
Combat Vet
Liquidity's Avatar
Default EFlite Deuces Wild build thread.
As promised, here is the much anticipated Deuces Wild build thread. I will write up a review later, but I wanted to document my build and all the useless banter that comes with a build.
I will start with the equipment being used.
Motors: 2 Scorpion 3026-12
ESC: Scorpion 70A
RX: AR7000
Servos: 6 DS821 servos, 1 HS322 (retract servo)
Retracts: Robart air up spring down
Props: APC 13x6.5 and a APC13x6.5 counter rotating prop
Lots and lots of servo extensions
Liquidity is offline
Old 08-07-2008, 08:51 PM
Liquidity
Combat Vet
Liquidity's Avatar
First thing I did was mount the motors in the nacelles. I went out of order because there is some dude on RCG crying about how hard it was.
It is not hard, it just took some time. I mounted the x mount to the motor, placed all 4 4-40 screws through the eyelets on the x mount, slide the nylon spacers in behind the x mount, then screwed it to the motor mount.
It took about 20 min to get both motors mounted. I do want to take them off and cut 3mm off of each spacer. There is a 5mm gap between the back of the spinner and the front of the cowl. I would rather it be 2mm max.
ID:	74734   Click image for larger version
ID:	74735   Click image for larger version
ID:	74736   Click image for larger version
Old 08-07-2008, 08:57 PM
Liquidity
Combat Vet
Liquidity's Avatar
Next I decided to follow the instruction manual and mount the rudder, elevator, and steering servos.
Once I did that, i went to check on the dog. He decided it was fun to play in the mud puddles that the rain left. I had to go hose him off so this is where I left the Deuces Wild.
More later.
ID:	74739   Click image for larger version
Old 08-07-2008, 08:59 PM
Liquidity
Combat Vet
Liquidity's Avatar
Ooops. Here are a few mock up photos
ID:	74741   Click image for larger version
ID:	74742   Click image for larger version
ID:	74743   Click image for larger version
Old 08-07-2008, 09:07 PM
Subscribed!
Old 08-07-2008, 09:29 PM
powerlines
I AM NO SHOES!!!
powerlines's Avatar
Can I hover it..
LATER
powerlines is offline
Old 08-07-2008, 09:31 PM
Liquidity
Combat Vet
Liquidity's Avatar
170W/lb should be able to hover for a second or 2
Old 08-08-2008, 02:50 AM
Liquidity
Combat Vet
Liquidity's Avatar
I went back out to relax and build a little more. I had a small headache earlier, I took a nap and woke up when I felt better. Wife said I was asleep for 2 hours. It felt like 20 min.
Anyway. I went out mounted the tail feathers and connect the pushrods to the rudder and elevator this time. Here are the pics to keep you all salivating.
ID:	74765   Click image for larger version
ID:	74766   Click image for larger version
ID:	74767   Click image for larger version
ID:	74768   Click image for larger version
ID:	74770   Click image for larger version
Old 08-08-2008, 02:52 AM
rcproptester
We the People...
rcproptester's Avatar
buy me one
rcproptester is offline
Old 08-08-2008, 03:43 AM
Slowjohn
Passed on
Slowjohn's Avatar
Thumbs up Subscribed
Okay I'm watching, drooling, scheming etc...& it is a beauty alright.
Standing By,
SJ
Slowjohn is offline
Old 08-08-2008, 04:26 AM
Liquidity
Combat Vet
Liquidity's Avatar
Servos are installed in the wings. I do have an opinion about this. EFlite has predetermine the area to epoxy the wood supports in. I believe it should be a little higher up and the slot for the servo arm needs to be a little wider.
I added a slightly larger servo arm to fix this problem. As is, I can reach the high rate throw on the ailerons, but no more. If I wanted any more, I will have to cut the slot bigger with a dremil. Not fun.
Pics tomorrow, it is late and I am tired.
Old 08-08-2008, 05:23 AM
Rabbitcreekok
Rabbitcreekok's Avatar
I'll watch this also. Thanks for posting the build.
Rabbitcreekok is offline
Old 08-08-2008, 07:00 AM
aviatordave
aviatordave's Avatar
looking good!
looking expensive!
aviatordave is offline
Old 08-08-2008, 04:03 PM
Liquidity
Combat Vet
Liquidity's Avatar
Here is the picture showing the aileron servo installed.
I can make the high rate throw, but just barely. If I need to, I will install a larger arm, again....
Old 08-08-2008, 04:59 PM
Angler-Hi
Angler-Hi's Avatar
Lookin good man!! I'm definitely subscribed my friend!
P.S. Heli's going out today.
Angler-Hi is offline
Old 08-08-2008, 06:49 PM
Liquidity
Combat Vet
Liquidity's Avatar
Thanks man. Here is todays update.
I completed the flap servo installation, main retract gear, and nose wheel steering. Nothing too complicated. Enjoy the pics.
ID:	74810   Click image for larger version
ID:	74811   Click image for larger version
ID:	74812   Click image for larger version
ID:	74813   Click image for larger version
Old 08-08-2008, 07:32 PM
Liquidity
Combat Vet
Liquidity's Avatar
After taking those pics, I went back and took the wrinkles out of covering.
Old 08-08-2008, 08:47 PM
Angler-Hi
Angler-Hi's Avatar
Lookin good man! What's the hose for on the retract?
Old 08-08-2008, 10:32 PM
Manta1
No Shoes is MY FRen
Manta1's Avatar
dude! looking awsome! you ARE bringing it to the electric fly in at Mr.Macs arent ya??i wanna see that jewel in action!!
Manta1 is offline
Old 08-09-2008, 12:06 AM
Rabbitcreekok
I believe the gear is retracted by air pressure and lowered by spring action. So those lines run from the silver air tank to the retracts.
Old 08-09-2008, 12:50 AM
Angler-Hi
Angler-Hi's Avatar
OK. Thanks Rabbit. I was wondering what they were for. Always learning something new around you guys.
Old 08-09-2008, 05:55 AM
Liquidity
Combat Vet
Liquidity's Avatar
Yup on both questions. The hose is for the air retracts and the DW is going to the Electric fly in. It will be sweet.
I am out of town now, but I will resume with the build when I get home
Old 08-09-2008, 08:22 PM
Liquidity
Combat Vet
Liquidity's Avatar
Ahhh I am going through withdrawl. I want to go home and finish building this plane.
Old 08-09-2008, 09:14 PM
groundrushesup
groundrushesup's Avatar
Lookin' sharp there man. And I also noticed you are a kindred spirit - I'm the guy who always manages to get a big honkin' toe in the shot
groundrushesup is offline
Old 08-10-2008, 04:32 AM
Manta1
No Shoes is MY FRen
Manta1's Avatar
several of us will be at the field in cochran tomorrow and monday..come on down,bring the duece!!
Manta1 is offline
Quick Reply: EFlite Deuces Wild build thread.
Page generated in 0.20179 seconds with 35 queries
