PZ Spitfire airframe
Old 10-11-2008, 07:30 PM
mgb
Default PZ Spitfire airframe
Hi all,
decided to take all the running gear from my t28 due to a painting experiment which went from bad to worse ! and thing of buying the spit airframe only.... wll this work ok any issues ? Does the airframe come with motor, will the sc wrk from the t28 or could I change th motor to the brushless one from the t28 ? do you get any instructions with the airframes ?
M
mgb is offline
Old 10-12-2008, 04:40 PM
Gohmer
Banned
Smile Spitfire
Replacement airframe comes with a brushed geared motor. It won't work with your T-28 esc, and it isn't much good anyway. It is less expensive to buy it this way than the seperate components. All your T-28 gear should fit with maybe some adaption mods. I can't speak from experience on this. I do have a PZ Spitfire with an outrunner motor and it flies very well.
The same instructions come with the replacement airframes that are included with the RTF.
Gohmer is offline
Larry G
Warbird Electrics
04-30-2008 05:09 AM
mikidymac
Warbird Electrics
01-10-2008 11:15 PM
Larry G
Warbird Electrics
11-29-2007 02:47 AM
RandolphNav
Warbird Electrics
03-26-2007 01:10 PM
thunder1
02-12-2007 08:08 AM
Quick Reply: PZ Spitfire airframe
Page generated in 0.11793 seconds with 12 queries
