Slow Stick Goodies.
Old 11-10-2008, 06:44 AM
boomerace
Been there .... Done That
boomerace's Avatar
Default Slow Stick Goodies.
As promised here is the first of the Beta goodies sent to me by Dave Thacker at www.radicalrc.com.
First up is the adjustable Motor mount. This is adjustable for both right and down thrust correction. First pic is with no down correction and second pic is with maximum allowable down correction. As you can see it's a bunch. Next pic is the top of the mount and right thrust correction is set with various thickness laser cut washers which are furnished.
Next item is the control horns. The holes fit the furnished Slow Stick control rods. A snap to install and horn locks in place. A little CA and they are there forever. Next pics are the V-tail mount. I will be using 1-1/2" more than 1/2 the furnished stab as I want extra control surface. Normally the stab is just cut in two and both halves make up the V-Tail. Will build the Nose Wheel/tail wheel Mount next. Stay tuned. New LG mount is also on the way. BTW it looks like in a bad crash the motor stick would break at the front leaving enough stick to reverse for a new mount. The items are on the website with beta pricing. The SS Kit will arrive next week and I will be installing the items on the new plane. It will have the V-Tail, 30oz thrust brushless and tri-cycle LG.
boomer
Name:	Adjustable Motor Mount 1.jpg
ID:	83329   Click image for larger version
Name:	Adjustable Motor Mount 2.jpg
ID:	83330   Click image for larger version
Name:	Top of Adjustable Motor Mount.jpg
ID:	83331   Click image for larger version
ID:	83332   Click image for larger version
Name:	Control Horn bottom lock.jpg
Name:	V-Tail Mount.jpg
ID:	83334   Click image for larger version
Name:	V-Tail Mount 2.jpg
ID:	83335   Click image for larger version
Name:	Bottom V-Tail Mount.jpg
boomerace is offline
Old 11-11-2008, 10:14 PM
boomerace
boomerace's Avatar
Here is the nose/tail gear mount. I have ordered a K & S Mighty Wire Bender and Coil Machine tool from Tower for $24.49 along with some 3/32" wire so I can duplicate the coil spring in the DuBro 1/2A Nose Gear that is now installed. The DuBro gear is fine for the tail wheel use but way too short to use for my nose gear as the Brushless outrunner I am using swings a APC 11 X 3.8 SF Prop for about 30oz of thrust. Note the coil is not needed as the 3/32" wire has enough flex without it.... I just enjoy Moding the Mods.
boomer
BTW: The flight tests on the prototype indicate that 1/2 of the stock stab/elevator for each side of the V-Tail gives plenty of control so I will be using that for my build the end of the week.
Name:	Front of Nose_Tail Gear.jpg
ID:	83447   Click image for larger version
Name:	Rear of Nose_Tail Gear.jpg
ID:	83448   Click image for larger version
Name:	Side of Nose_Tail Gear.jpg
ID:	83449   Click image for larger version
Name:	Top of Nose_Tail Gear.jpg
Old 11-15-2008, 03:44 AM
Elfi Flyer
Elfi's, beauty in flight.
Elfi Flyer's Avatar
Boomer:
Many thanks for the update on tese beta items. Please keep up informed. I like that adjustable motor mount. Nice idea.
Elfi Flyer is offline
Old 11-15-2008, 04:45 AM
boomerace
boomerace's Avatar
Default More Goodies
Received another bunch of Goodies today.
Here are pics. Pics should be self explanatory if not just ask. Note battery tray is made so other items can be installed under it such as a wing mount. Mounting tabs are for attaching a drop box, camera or any other special project you can dream up. I also have a single Servo Mount for the steering nose wheel. (not shown) The servo trays can not seperate in a crash as there is a piece of ply tying then together.
Dave is sending me wing mounts that will raise the wing 1" 2" and 3" more than the stock mounts and also will be for 0, 5, 12(stock), 16 and 55 degree dihedral. I am using 1" additional height and 16 degree dihedral on my build for better control. More later............
boomer
Name:	Large Battery Tray 1.jpg
ID:	83806   Click image for larger version
Name:	Large Battery Tray 2.jpg
ID:	83807   Click image for larger version
Name:	Large Battery Tray 3.jpg
ID:	83808   Click image for larger version
Name:	Large Battery Tray 4.jpg
ID:	83809   Click image for larger version
Name:	Large Battery Tray 5.jpg
Name:	Large Battery Tray 6.jpg
ID:	83811   Click image for larger version
Name:	Main LG Mount 1.jpg
ID:	83812   Click image for larger version
Name:	Main LG Mount 2.jpg
ID:	83813   Click image for larger version
Name:	Main LG Mount 3.jpg
ID:	83814   Click image for larger version
Name:	Main LG Mount 4.jpg
Name:	Servo Tray 1.jpg
ID:	83816   Click image for larger version
Name:	Small Battery Tray 1.jpg
ID:	83817   Click image for larger version
Name:	Small Battery Tray 2.jpg
ID:	83818   Click image for larger version
Name:	Steering Tail Wheel Bracket 1.jpg
ID:	83819   Click image for larger version
Name:	Steering Tail Wheel Bracket 2.jpg
Name:	Steering Tail Wheel Bracket 3.jpg
ID:	83821   Click image for larger version
ID:	83822   Click image for larger version
Name:	V-Tail Top 2.jpg
ID:	83823   Click image for larger version
Name:	V-Tail Bottom.jpg
ID:	83824   Click image for larger version
Name:	Mounting Tabs for Special Projects.jpg
Name:	Heavy Duty Large Mounting Tab.jpg
Old 11-15-2008, 05:03 AM
boomerace
boomerace's Avatar
Originally Posted by Elfi Flyer View Post
Boomer:
Most are now available at www.radicalrc.com Look in Kits and then Slow Stick Hop Ups
boomer
Old 11-15-2008, 05:29 AM
boomerace
boomerace's Avatar
Here are some better pics of the servo trays.
boomer
Name:	Servo Tray 2.jpg
ID:	83828   Click image for larger version
Name:	Servo Tray 3.jpg
ID:	83829   Click image for larger version
Name:	Single Servo Tray 1.jpg
ID:	83830   Click image for larger version
Name:	Single Servo Tray 2.jpg
Old 11-15-2008, 05:42 PM
Elfi Flyer
Elfi Flyer's Avatar
Many thanks for the running update and expose. I note that most of the upgrade parts are plywood based. Were the original plastic parts all that bad? Also, interesting to see the upgrade favors a V-tail construction. I have personally had little experience with V-tail planes, and the "beginner" planes using this configuration usually have been difficult to adjust for newbie applications. Nice to see someone actually making modifictions that can be marketed directly to SS enthusiasts. Thanks again for keep us appraised.
Old 11-15-2008, 09:09 PM
boomerace
boomerace's Avatar
The plastic parts other than the wing mounts IMHO are junk and that includes the LG and tail wheel. The wing mounts are also not easy to change as far as dihedral and height above the fuse. If you ever noticed my Cul De Sac flyer movie and build the dihedral is about 20 degrees and it will just about turn and loop in it's own length. The stock Slow Stick has 12 degrees. Increasing the dihedral to 16 degrees and raising the wing an additional 1 inch will enhance the ability to roll, increase stability and correct the sluggish response to control input making for a much better flying plane IMHO.
boomer
Old 11-15-2008, 09:44 PM
Twmaster
Registered User
Twmaster's Avatar
{Mike shakes his fist toward the pacific northwest!}
Damn you Boomer!
I just went to Dave's web site and I cannot get the battery mount or V-Tail rig just yet. I have money in my PayPal and want to abuse it!!
Dave, if you're reading this thread PM me, I want those (and other) SS parts!
Twmaster is offline
Old 11-15-2008, 10:02 PM
Twmaster
Registered User
Twmaster's Avatar
Say Boomer....
I'm looking at these photos and the shots on Dave's web site. How are you controlling the steering on the nose wheel when you have V-tail mixing going to the tail?
The only thing I can figure is you've enabled elevon mixing and put the nose wheel on the rudder channel.
Twmaster is offline
Old 11-15-2008, 10:03 PM
Elfi Flyer
Elfi Flyer's Avatar
boomer
Hmmmmm....sounds exactly what my modified SS needs. Definitely will have to look into this.
Old 11-16-2008, 12:07 AM
boomerace
boomerace's Avatar
Originally Posted by Twmaster View Post
Say Boomer....
You got it! I also have mixed some (25%) aileron channel (in this case Rudder) with the rudder channel (In this case nose wheel ) for finite steering on ROG with the right stick. This allows me to use extreme turning on the nose wheel for tight radius taxing without nose wheel being overly sensitive during ROG. Is this clear as mud?
boomer
Old 11-16-2008, 12:13 AM
Elfi Flyer
Elfi Flyer's Avatar
Is this clear as mud? boomer
So why not cross mix a hysteris loop feed back between the individual elevators and sync it with about 42% positive exponential on the throttle end point adjustment? Just as easy.......
Old 11-16-2008, 12:22 AM
Twmaster
Registered User
Twmaster's Avatar
Oh that's slick Boomer.
Still can't find all the parts on Dave's web site...
Twmaster is offline
Old 11-16-2008, 12:23 AM
Bub Steve
Bub Steve's Avatar
Elfi :I think my brain just threw up out my ears a little, bub, steve
Name:	petty an red 865.jpg
ID:	83858   Click image for larger version
Name:	petty an red 866.jpg
ID:	83859   Click image for larger version
Name:	petty an red 872.jpg
Bub Steve is offline
Old 11-16-2008, 12:28 AM
boomerace
boomerace's Avatar
Sent you a PM and contacted Dave.
boomer
Old 11-16-2008, 12:30 AM
boomerace
boomerace's Avatar
For you maybe! It really doesn't get any easier than what I did.
boomer
Old 11-16-2008, 01:12 AM
HoaRC
HoaRC's Avatar
just what i need
HoaRC is offline
Old 11-17-2008, 07:26 AM
Twmaster
Registered User
Twmaster's Avatar
Default Wing Incidence?
Boomer (and others)--
Have you folks done changes to your wing incidence on your modified Slow Sticks? While I never had any issues with my relatively tame SS I'm curious how your much modded birds fare.
Twmaster is offline
Old 11-17-2008, 07:31 AM
boomerace
boomerace's Avatar
I always raise the back of the wing 1/4" with 1/4" Balsa shims on the rear wing support. Makes the plane fly better IMHO. Stock SS has too much for my taste. Doesn't seem to increase flight speed but makes it less mushy.
boomer
Old 11-17-2008, 07:54 AM
Twmaster
Registered User
Twmaster's Avatar
Thank you! That's big help.
Mike N
Twmaster is offline
Old 11-18-2008, 02:26 AM
boomerace
boomerace's Avatar
Last of the Goodies I needed to finish the plane arrived today. Thanks Dave!
The first pic shows the available parts to make a wing support with a stock riser, 1 inch more than stock, 2" more than stock and 3" More than stock. They are shown on the lower row from left to right in the pic. Top row shows the available dihedral wing supports left to right is 0, 5, 12 (stock), 16 and 55 degree dihedral supports. Second pic shows the setup I an using for this build. One inch riser and 16 degrees dihedral. The 3rd pic shows my assembled 16 degree wing brace that was made up before I received the parts today and look how great it fits Dave's wing support. Will start assembling the plane tomorrow.
boomer
Name:	Wing Supports.jpg
ID:	84126   Click image for larger version
Name:	Wing Supports Plus 1inch - 16 degrees.jpg
ID:	84127   Click image for larger version
Name:	16 Degrees Dihedral.jpg
Old 11-18-2008, 07:37 AM
Twmaster
Registered User
Twmaster's Avatar
Ah the 'coup de grace'
I'm sold. Just awaiting them to appear on Dave's website.
Twmaster is offline
Old 11-19-2008, 10:41 PM
boomerace
boomerace's Avatar
Not much time to work on it but here it is today. Need to install RX and adjust servos.
boomer
Name:	Plane with Goodies 1.jpg
ID:	84258   Click image for larger version
Name:	Plane with Goodies 2.jpg
ID:	84259   Click image for larger version
Name:	Plane with Goodies 3.jpg
ID:	84260   Click image for larger version
Name:	Plane with Goodies 4.jpg
ID:	84261   Click image for larger version
Name:	Plane with Goodies 5.jpg
Old 11-20-2008, 11:37 PM
boomerace
boomerace's Avatar
Default Finished!
Plane ready to maiden. AUW is 26.5oz. Power Meter shows [email protected] with 2000 3S 20C Lipo swinging a 11X3.8 Prop. 30oz of thrust per specs.
That will give me 91.57W/lb. Should be a blast. Tail feather aileron function set up with 20% less down than up.
boomer
Name:	V-Tail SS Front.jpg
ID:	84376   Click image for larger version
Name:	V-Tail SS Front Qtr.jpg
ID:	84377   Click image for larger version
Name:	V-Tail SS Rear Qtr.jpg
ID:	84378   Click image for larger version
Name:	V-Tail SS Rear.jpg
Quick Reply: Slow Stick Goodies.
Page generated in 0.15716 seconds with 64 queries
