Seaplanes E-Powered Discuss electric powered seaplanes here
Brushless motors and saltwater
Old 12-12-2008, 06:38 AM
philbel
Default Brushless motors and saltwater
Hi everyone,
Next week I will be on vacation in the Dominican Republic and I will bring along my Minimag on floats for a little early morning fun. I am using a Turnigy 2835 2200kv and a Hexctronic 36a esc. I soaked the esc in Corrosion X and I sprayed the servos with Max-Wax (same company) as I do with all electronics for floatflying. But I am wondering if I should do the same with the brushless motor...
Can saltwater really damage the brushless motor?
Any advice?
Thanks,
Philbel
philbel is offline
Old 12-12-2008, 07:49 AM
groundrushesup
groundrushesup's Avatar
Originally Posted by philbel View Post
Hi everyone,
Any advice?
Thanks,
Philbel
Prolonged exposure, sure. Saltwater can be a powerful electrolyte and some of the alloys that are often used in the bell housings of most outrunners can be attacked readily by corrosion - but mechanically - I bet if you bring it home and do a top-down scrubbing of the bearings, bushings, etc. you will be alright.
Or you could wire a chunk of zinc to the stator - its called a galvanic or 'sacrificial' anode. The corrosion attacks it intead of your steel alloys.
That's how they keep steel boat props from disintegrating.
My $0.02.
GRU
groundrushesup is offline
Old 12-12-2008, 09:01 AM
philbel
Do you know by any chance if Corrosion-X can be applied on brushless motors? I know it works very well on escs and receivers but... on motors??
As for wiring a chunk of zinc to the stator, I don't think I have sufficient knowledge to do that. I've been in this hobby for a little more than a year and I admit I would not even know where the stator is located!!
Well, I'll just try not to drink too much rhum & Coke before taking off...
Thanks.
Philbel
philbel is offline
Old 12-12-2008, 09:32 AM
Hi, After running the motor in salt water, just rinse it with fresh water, shake it out, and spray it with WD 40, or something like it, inside and out, no need to take the motor apart, if the motor does get eaten up after a while, dont worry about it, they are cheap like me LOL Take care, Chellie
http://www.hobbycity.com/hobbycity/s...idproduct=7993
Old 12-12-2008, 04:17 PM
philbel
Thanks for the suggestion of the Turnigy 2836... Quite stronger than the one I'm using. Looks like a perfect fit on those brushed speed 400 mounts. I will try it on my Multiplex Twinstar next Spring.
Philbel
philbel is offline
groundrushesup
Thanks.
Philbel
LOL I was kidding about the galvanic anode Phil - sorry bout that.
As far as the corrosion-X goes - if it doesn't damage PCB's I dunno why it would bother a motor - unless it attacks the varnish on the windings or the glue on the magnets...
Sorry chief, never used it before so I guess I should just clam up.
Have fun down in the Caribbean - last time I was there I ended up staying twice as long as I planned and I came back a lot poorer but it was worth every penny lol
Old 12-12-2008, 07:51 PM
phupper
Flyin' Phup
phupper's Avatar
"just rinse it with fresh water, shake it out, and spray it with WD 40"
Chellie is correct (as usual), I've dunked my BL motor in salt water probably 6 times in the last month. It still works fine.
(you wanna do that rinsing ASAP)
phupper is offline
Old 12-12-2008, 08:32 PM
philbel
thanks guys,
You had me on this one (the zinc on the stator...).
Never make fun of a handicapped person!!
Cant wait to fly that Minimag with local Dominicans looking at a rc plane for the first time. Last year a guy wanted to buy my whole system for a fortune... He had brand new $100 bills in his pocket... Wonder where he got all that money.
Merry Christmas.
Phil
philbel is offline
Old 12-13-2008, 06:51 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
CorrosionX is safe to use on motors. I dunk all my water plane motors in the stuff and it works great.
It should help keep the motor from rusting but Id still rinse in fresh water after each flight and re-treat with CorrosionX often.
Same thing on the electronics - rinse and re-treat.
Larry3215 is offline
Old 12-13-2008, 03:39 PM
philbel
Thanks Larry,
I'll do just that!
Last question: can the salty breeze of the Carribean dammage the transmitter? Is there any way to protect te transmitter from it?
Phil
philbel is offline
Old 12-13-2008, 05:35 PM
Larry3215
Larry3215's Avatar
The tx is more dificult.
I have used large plastic bags when flying in the rain. Stick the antena out thru a hole in the end. Its clumsy though and you still get it wet.
I would NOT treat the entire tx with corrosionX. It would probably mess up all the pots inside and kill any LCD screens.
t_low37
9
03-14-2009 02:17 PM
swapdaddyxx1
06-28-2007 02:54 AM
Hornetman
03-05-2007 08:45 PM
p901
11-21-2006 02:04 AM
ms08
03-22-2006 07:56 PM
Quick Reply: Brushless motors and saltwater
Page generated in 0.09887 seconds with 11 queries
