CA Models FUNKY .40???
Old 12-14-2008, 11:16 PM
Default CA Models FUNKY .40???
After hearing too many "Nobody builds kits anymore. Check out this E-Flite ARF..." I have finaly found an old (laser cut!) but very dusty Ca Models Funky .40!!!! Giant wing and massive control surfaces. Going brushless and doing much lightening. Looks like a cool plane!
I found a E-conversion thread on a different sight but there is still some holes in it. I am wondering if any Wattflyers have any input on this kit?
Just ordered a coulpe rolls of covering and I am getting anxious!
Any input would be great, THANKS, Rob
Old 12-15-2008, 05:47 AM
Neet Plane Rob, here is some info that I found on it, Take care, Chellie
http://www.cerebus.co.za/ca/funky/Funky.htm
http://www.rcgroups.com/forums/showthread.php?t=556521
Old 12-15-2008, 06:41 AM
you may Like this motor for your Funky 40
50-55B 600KV motor
http://www.hobbycity.com/hobbycity/s...er_(Eq.4120/14)
80 AMP ESC this has a 3 amp BEC built into it
4900mah 5 cell 20C LIPO
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
Lipo 5 cell
http://www.hobbycity.com/hobbycity/s...00mAh_5S1P_15C
5 cell lipo
http://www.hobbycity.com/hobbycity/s...5C_Lipoly_Pack
13x6 Wood prop yea, you start getting this big and a nitro prop works well on larger electric motors.
http://www.hobbycity.com/hobbycity/s...13x6_propeller
TURNIGY 50-55B
Steve Awesome. You can not, will not find a motor that can match this one for price for punch. Pulling 1500 Watts on a HC 5000Mah 6s swinging a 13x10.
Very good motor
Bigben I ordered two for me and ono of my friend. We use it on a Hyperion Super Chipmunk .70e with a 80 A ESC, a 5S 4000 LiPo and a 14*7 prop. Huge amount of power. Takeoff at 2/3 throttle and infinite vertical climbs. Really great motot for the price, compared to the recommended Hyperion combo ! I'll get another one soon for my Hangar 9 Piper Pawnee (2m).
Old 12-15-2008, 01:27 PM
Dang Chellie, You are awesome! Now if I can only find my Hobbycity login and password.... I read some other posts where you write about the Rhino lipos, I think I am going to have to bite the bullet and get a pile of them. That will be much nicer that my hodge podge of different brands and weights I currently run. I am pretty sure I can take your word for it, besides, can the Chino Renegades be wrong? I'll bet y'all log a lot of flight time with your weater. Thanks again! Will post some pics when she is all wrapped up!
Old 12-15-2008, 02:06 PM
gfdengine204
gfdengine204's Avatar
Rob,
That is a sweet looking flier. Where perchance did you find one?
gfdengine204 is offline
Old 12-15-2008, 11:19 PM
Hey Kev. I found her dusty and burried in a pile of arf's at THE GENTLE JUNGLE, in Alsip Il. Real cool place, more plane stuff than I have seen in one place anywhere. The owner (Mike) is a real nice guy. Interestingly enough, he has the RC planes covered and the other half of his store is birds, big ones little ones, all kinds. Amazing guy, he should have been born with wings.
The kit wasw made in Argentina but there is also a sheet of paper in there with US weights and measures: Fuse 54", wing 52",weight 3.75lbs, engine 40-50 2T. Also has some contact info: www.planesplus.com and [email protected] Ph#(630)904-5075, Plainfield IL. The website is more of a link page but if you drop them a line (Don Kanak), he might be able to hook you up.
Pretty light kit for the size, I am also lightening it up some myself. Should be a FUN fun flyer!
Old 12-15-2008, 11:54 PM
Default Hey Chellie.... Help???
Your suggestions at hobbycity are waiting in my shopping cart. I do have one small problem however. I have a couple chargers that will only support up to 4s packs. And don't really want to buy a new charger (unless it flies...) Do you think I might be ok with these: http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
and a little bit faster prop?
Old 12-16-2008, 05:15 AM
I dont think you will need this much prop but just know that you could with 4 cells I think you will be fine with a 4 cell, a 5 cell will give you hyper performance but a 4 cell will be fine too, Take care, Chellie
(Use this motor with 4-6 cell Li-Poly packs and 11-12 inch props on planes up to 8 lbs flying weight.
Manufacturer suggests a 12 x 8 prop on 6 cells or 13 x 10 on 4 cells. )
Customer Rated 11/14/2008
Phil I install this motor on my hyperion chipmunk , i use it with 4s batterys 4000 mah with a 80A controller swinging a 14x7 prop , its one of the best motor ive been using . It so powerfull , but dont use a 6s it too scary ....well overpower for the airplane .
Old 12-16-2008, 05:21 AM
Perfect Lipo read what other Pilots are doing with there planes with this motor, they are using 4 to 6 cells, I suggested a 5 cell, because the KV was a little on the low side being a 600kv motor, but with a little more pitch, you can make up for the lower KV, Take care and have fun, Chellie
Old 12-16-2008, 12:51 PM
Thanks a million! Being that I just started rc at about this time last year, I think the Hyper Performance can wait a little while.
Old 12-27-2008, 06:08 AM
She is coming along nicely (Terrible weather). I am estimating a little under 5lbs with a 4s 5000mah. Nice big light kit.
Old 12-27-2008, 06:12 AM
Thats Looking Nice, I want to fly it too Take care, Chellie
Old 12-27-2008, 06:14 AM
Basically you will be LOL. You picked out the power system!
Old 01-01-2009, 09:22 PM
Default The PAINFULL wait for servos
Starting to look like a plane. Built a magnet/dowel battery hatch into the top which also gives me access to bolt the wing on from the top. May have to change the hatch around a bit to acomidate the battery, not much though if any.
Kit also comes with a clear cowl to set-up and a white fiberglass one to finish. I may just paint the firewall and motor mount and use the clear cowl! Most of the motor mounts I found were 5-6+ ounces so I decided to box one at about 1-2 ounces. Much cheaper too! Should not be long now! Biggest concern, my roll of blue covering is getting pretty thin
ID:	88731   Click image for larger version
ID:	88732   Click image for larger version
Old 01-01-2009, 09:51 PM
Hi Rob That Motor fits and looks nice in there Good Job, that will look neet to have the cowl clear, showing the motor, Keep up the great work, Chellie
Old 01-01-2009, 10:08 PM
And Now, For my next Trick, Rc Plane Building Trick that is I am going to attempt to make a bi Plane with a 72" W/S, it will look something like these 2 planes, a combination of the 2, I bought some cowls on ebay, 3.99 each, some 8.5mm carbon fiber square tube, some 6mm depron, I have the 9mm depron, the 6mm depron will be for the fuselage, it will be a boxed fuse, with flat 9mm wings, wish me Luck, Chellie
WEIGHT 305g
MAX EFFICIENCY 93%
BATTERY 4 cell Li-poly battery
KV 670
PROPOLLER 13*8/14*7APC-E
CURRENT 1.2A-50A
VOLTAGE 14.8
I think i should be able to use a 15x 4 or 5 prop Chellie
Old 01-01-2009, 11:02 PM
Ahhh, The Christen Ultimate! Sweet! I found my Axi2820/12 and am thinking of a giant 3 channel Blu-cor AP platform my next adventure!
Thanks again for the power system input. Got me some deep 14-15 and 16" props ordered. I will get some wattage form the 4s if it kills me, or puffs first. Let me know how the hybrid goes?
Old 01-01-2009, 11:30 PM
Kewl I found some great Prices on props at, A Main Hobby, I ordered 2- 15x4 apc props and 2- 12x3.8 props from them, lowering the pitch on the prop should let me use the bigger diameter prop, i will be using a 4 cell lipo, so I think I should have enough thrust, the bi plane is not going to weigh very much, I am Guessing the plane it self at 32oz and it might be less, thats with out electronics, Take care, Chellie
http://www.amainhobbies.com/
Old 01-06-2009, 02:31 AM
Default Funky 40 cleared for take off.
DONE! Not much of a build thread, but you should definately have a few (quite) builds under your belt, if you can even find one of these.
Save for a few finishing touches(adding springs to the stressed landing gear) I think she is ready to maiden. Partialy charged (4.00vpc) 4s 5000Mah, 14x7apc and it lifts up out of my hand. Whew. I can't wait to see the regular at the hobby shop where I bought it, out at the field. I will remind him about when he scoffed and said "Have fun with your box of sticks!". Ohh, I will.... I will.....
I will report back with prop/amp numbers and AUW after I borrow my mother scale again. Out
ID:	89396   Click image for larger version
ID:	89397   Click image for larger version
ID:	89398   Click image for larger version
ID:	89399   Click image for larger version
Old 01-06-2009, 03:03 AM
guapoman2000
Space Ship 1
guapoman2000's Avatar
Default BirdDog!!!
BirdDog!!
Very nice project and with 4S Li-POLYs that will be a Rocket Ship on take-off!!! Do not forget to Throttle Back!!!
Carlos
guapoman2000 is offline
Old 01-06-2009, 04:57 AM
Wow Super nice Job Rob It looks great, Just keep it under 100mph for the first few flights I found a biplane that i want to make, it will have the tappered back wings like a Ultimate, I Like the longer fuselage that the super skybolt has, it will have wider wings, and larger rudder and elevator, wish me luck Take care, Chellie
Old 01-07-2009, 01:04 AM
Default Finished
Well that's about it for this one. Rigged the LG with some steel fishing leader and some stainless springs. Should hold the weight pretty well. The whole LG rig is held to the fuse with 3 10-32 nylon bolt and nuts (don't want to use t-nuts, never get the broken bolt out).
She's pulling a hair under 600watts at just over 40amps with 14x7e prop and 4s lipo. Should be plenty to get her airborne. I will worry about balistic power at a later time. Thanks for looking, hope I may have helped someone out here! Rob
Old 01-07-2009, 04:06 AM
Hi Rob Glad you got it done, How is the weather out your way, are you able to fly, or is the weather bad right now for you, would love to see some video and pics of your creation flying, Take care, Chellie
Old 01-07-2009, 10:13 PM
FTE Sales
Banned
Default ca Models Funky 40
Hello All,
We have one of these kits NIB if any one is interested in it let me know what your willing to pay for it Thanks ~JOHN~
email john @ franktiano . com
863 607 6611
FTE Sales is offline
Old 02-13-2009, 06:59 PM
ENUT
ENUT's Avatar
Default funky40 part 2
Rob,your funky40 looks great.Here a couple pictures of mine.I have had this plane built since 2005 and just hung it up in my bed room. I'm just doing the finish sanding now.My color scheme will be of the Fosters Beer Can! I will post pictures as I get the covering done.My power will be AXI 4120/18 Here are a couple of the plane framed up.
ENUT
ID:	93557   Click image for larger version
ENUT is offline
Quick Reply: CA Models FUNKY .40???
Page generated in 0.12501 seconds with 23 queries
