Aircraft Reviews Member based Reviews on ARF's and Kits Open for Business!
Easytiger Models F-22 ARF Review
Old 12-23-2008, 01:03 AM
Build Review Easytiger Models F-22 ARF Review
Introduction
After looking for several weeks for a ducted fan jet, I noticed on RCU that http://www.easytigermodels.com/ was running an introductory sale on his F-22 70 mm EDF jet. According to his site, the F-22 was a decent performer and large enough to be able to easily track while flying. It came with the following pre-installed; servos, 70mm fan unit, brushless motor, speed control, and BEC. In addition to all that, the model was supposed to handle well in the wind which is something we have quite a bit of in West Tennessee. After numerous e-mails sent back and forth to Curtis (All of which he patiently answered.) I decided to spend my hard earned cash and order one. The model arrived via USPS within days in a plain brown box.
ID:	87557 Click image for larger version
ID:	87558 Click image for larger version
Assembly
As you could see from the photos, there really were not many parts to the F-22 so assembly went fairly quickly. As mentioned earlier, all the servos were pre-installed as was the ducted fan, motor, speed control and supplied BEC. The plane was pre-painted with flat paint and all decals applied. I used foam safe CA glue from ZAPP products throughout the build. http://www.zapglue.com
ID:	87560 Click image for larger version
ID:	87565 Click image for larger version
The first things that I attached were the control horns to the rudder and main wing control surfaces. Each horn only had two screws securing it to the foam so I added a little bit of CA to the foam for extra security. The hinge hardware was good quality but I still checked each hinge to ensure it was seated and glued properly.
ID:	87567 Click image for larger version
ID:	87568Click image for larger version
Once the control horns were attached, I put the landing gear in the wings. Unfortunately one of the brackets was missing so I got with Donnie Lyons who is a local pilot and excellent scratch builder. He helped me solve the problem by making a new one out of very thin ply. Curtis from easytigermodels.com offered to send a replacement part as soon as he read my email. Curtis also assured me he would bring the missing part up with the factory. The front nose gear assembly was also pre-installed and all that it needed was the front wheel put on.
ID:	87574 Click image for larger version
ID:	87693 Click image for larger version
Name:	F-22 set two (5).jpg
ID:	87570 Click image for larger version
ID:	87572 Click image for larger version
After the landing gear was attached to the F-22 all that was needed was to install the main wing, horizontal tail and vertical tail. Curtis from Easytiger models had mentioned in one of his e-mails that it was a good idea to pinch the ends of the ends of the foam slightly before installing so that they would slide into the fuselage easier. His trick worked great, I attempted to install them without pinching the foam and it was too tight a fit. The nose cone slipped on the front of the fuselage and the F-22 was ready to have its control rods installed and radio set up.
ID:	87581 Click image for larger version
ID:	87576 Click image for larger version
I used my old trusty Polks Tracker II radio and installed a Seeker receiver in the jet. The elevators and ailerons were linked together when I moved the radios stick so I set the plane up as a delta instead of a normal plane. I was curious to see how having them linked affected the flight characteristics. There was plenty of room in the compartment for the receiver and it seemed unnecessary to secure it. The F-22's center of gravity was listed at 660 mm / 25.98 in from the tip of the nose cone and it balanced a little bit nose heavy with the battery installed.
ID:	87577 Click image for larger version
Name:	F-22 set two (7).jpg
ID:	87683 Click image for larger version
Name:	F-22 set two (9).jpg
ID:	87578 Click image for larger version
ID:	87579 Click image for larger version
The cockpit was begging for a little detail work so I headed inside to do some research and skipped attaching the canopy until after I painted the cockpit. While the cockpit paint was drying, I hooked up my Power Analyzer Plus from http://www.medusaproducts.com to check and see what the motor was pulling static. 33 amps and 417 watts was the result at wide open throttle. Humm, I need some batteries capable of higher amperage. 2100-2200 20c packs may be better suited for this application.
Name:	F-22 set three (4).jpg
ID:	87940 Click image for larger version
Name:	F-22 set three (5).jpg
ID:	87941 Click image for larger version
Name:	F-22 set three (6).jpg
Name:	F-22 set three (7).jpg
ID:	87943 Click image for larger version
Name:	F-22 set three (8).jpg
ID:	87944 Click image for larger version
Name:	F-22 set three (9).jpg
Flights
It was a beautiful day in West Tennessee and I met Nick King, Donnie Lyons, And Dave Huff at the sod farm where we fly most Sunday afternoons at. If you're ever in West Tennessee on a Sunday afternoon, let one of us know and we can get together for some stick time.
Name:	F-22 set three (11).jpg
ID:	87946 Click image for larger version
Name:	F-22 set four (1).jpg
ID:	87947 Click image for larger version
Name:	F-22 set four (9).jpg
Name:	F-22 flights 12-28-08 (29).jpg
ID:	88250 Click image for larger version
Name:	F-22 flights 12-28-08 (1).jpg
ID:	88251 Click image for larger version
Name:	F-22 flights 12-28-08 (30).jpg
I maidened the plane and found out that I didn't have my radio set up properly. The F-22 took off quickly on hard packed dirt but was very touchy in the air. I had the expo set up improperly. So after trimming the plane out, I brought it in for a landing. As I was setting it up for the landing, I noticed the plane was missing a landing gear so I set it down as gently as possible without a gear. (Dave Huff sent me a photo of the gear falling out, see if you can spot that picture.) The landing didn't go too badly under the circumstances, pulled one of the elevator hinges out which stripped out one of the elevator servos, and got some mud on the underside of the plane. I had a Cirrus 9 gram servo handy and changed out the broken gears then fixed the hinge with some foam safe CA glue. Then fixed the expo on my radio and the F-22 was ready to fly again.
Name:	F-22 flights 12-28-08 (3).jpg
ID:	88256 Click image for larger version
Name:	F-22 flights 12-28-08 (21).jpg
ID:	88257 Click image for larger version
Name:	F-22 flights 12-28-08 (23).jpg
Name:	F-22 flights 12-28-08 (11).jpg
ID:	88253 Click image for larger version
Name:	F-22 flights 12-28-08 (13).jpg
ID:	88254 Click image for larger version
Name:	F-22 flights 12-28-08 (14).jpg
I don't want to talk about my next flight. Let's just say it went badly through poor battery preparation on my part. The F-22 took a very nasty landing without breaking any foam. It showed itself to be a tough bird. The only real damage was another stripped servo. It was time to turn the F-22 over to Nick and let him put the plane through its paces. Nick was kind enough to email his thoughts plus some flight comments about the F-22, following is what he had to say:
The plane overall is a smooth flier. It's not going to win any speed records, but it is faster than the typical parkflier. It's responsive, which could get you into trouble if you're not prepared for it. It seemed like a large plane for it's weight, and I was surprised at it's toughness. It's size makes it easier to see, but the overall gray scheme will keep one on their toes for the entire flight, especially with the rolls the F-22 was capable of. Although I am not fond of RTF setups, this plane performed admirably. If it were mine, it would have a hotter motor, and possibly a larger battery before too long...
ID:	88260 Click image for larger version
ID:	88261 Click image for larger version
ID:	88263 Click image for larger version
ID:	88264 Click image for larger version
The 2200 4s1p batteries that I ordered came in the day after we had done the maiden flights. The following morning I loaded up the F-22 and headed back out to the sod farm. Winds were around 14 mph with up to 22 mph gusts. The Power Analyzer was hooked to the new batteries and showed 37.6 amps with 530 watts, much better than the readings with the 1800's.
This gave me a lot more confidence even though the winds were quite breezy. Take off rolls were much shorter with the new packs. The F-22 handled the wind with no problems and there was plenty of power to fly it when heading into the wind. The plane rolls well as Nick stated earlier and loops are a hoot to do with the elevator tied into the ailerons. I tried hard to stall the plane but with the large wing area it just mushed along until I applied power, there wasn't even a need to drop the nose to pick up some speed. The feeling of the center of gravity being slightly aft was gone. It flew well inverted and I was very happy with the performance. Landings needed a long base because the plane wanted to just float in and if I applied power trying to land I would overshoot where it needed to hit the ground at. Nick was right, I needed larger packs.
I flew four times before it was time to go home for lunch and really hated to leave the field even when it was after time to head to the house. The F-22 has earned a place in the trailer I haul my planes in when driving my Valkyrie to the field!
Name:	SF 12-28-08-063.jpg
ID:	88277 Click image for larger version
Name:	SF 12-28-08-267.jpg
ID:	88278 Click image for larger version
Name:	SF 12-28-08-278.jpg
Name:	SF 12-28-08-295.jpg
ID:	88280 Click image for larger version
Name:	SF 12-28-08-277.jpg
ID:	88281 Click image for larger version
Name:	SF 12-28-08-292.jpg
A huge: "Thank you very much." to Nick King for photos and flying the F-22 while I videoed the flight, Donny Lyons for taking photos and Dave Huff for taking even more photos. I really liked how the plane flew, it was super responsive to control input and was easy to track because of the planes size. It moved along at a fast pace when given full throttle and slowed down nicely. My heart was still beating fast after turning the sticks over to Nick for our third flight of the afternoon!
Name:	SF 12-28-08-265.jpg
ID:	88283 Click image for larger version
Name:	SF 12-28-08-266.jpg
ID:	88284 Click image for larger version
Name:	SF 12-28-08-276.jpg
Video for Broadband:
[media]http://www.youtube.com/watch?v=R81kHW7Jozo[/media]
Video for dialup:
[media]http://www.youtube.com/watch?v=JjrRPS1Nkog[/media]
Pros
*Fairly sturdy plane, actually surprising for this kind of foam.
*Super quick build, instructions easy to follow.
*Nice performance on 4s1p 2200 cells.
*Good appearance overall.
*Large size plane for poor old eyes.
*Ability to handle wind, it flew quite well in brisk winds.
Cons
*Glue used by the factory on the control surface hinges. (Triple check these, then check before every flight.)
*Decals not as durable as they should be.
*Accessibility of servo gears when stripped out. (You have to pull the servo partially out of the foam.)
Old 12-24-2008, 08:49 PM
Joe 1320
Joe 1320's Avatar
just a FYI.....Curtis (aka easytiger) is a distributer, not the manufacturer.
Joe 1320 is offline
Old 12-24-2008, 11:20 PM
Thanks Joe, the template doesn't have a distributor option. How does the addition I made look?
BTW, the thumbnail editor is broken so all my photo captions aren't showing. Mike is taking a look at fixing it.
Old 12-30-2008, 08:58 PM
Just wondering if any of you have spotted the photo with the landing gear falling off on the planes maiden flight?
Old 12-30-2008, 10:54 PM
Joe 1320
Joe 1320's Avatar
Ah..... I just saw that.
Joe 1320 is offline
Old 12-31-2008, 02:26 PM
CAPMDON
CAPMDON's Avatar
Hi Don
Dave got a good action shoot with gear leaving the aircraft.
With all the cameras we had out their that day, nothing was going to get past us.
Something I'd like see, once you get a bigger battery, what will be it's slow flight charactorists into the wind.
The way the control surfaces are set up, I would assume it could slow done to a crawl with a nose high a attitude.
CAPMDON is offline
Old 12-31-2008, 03:41 PM
Hey Donnie!!! Welcome to Wattflyer!!! I guess that electric Stick you're scratch building is giving you the bug!! Another slimer pilot being reformed and seeing the light!!
I flew it yesterday with the larger batteries, it flew great in the wind. As you know, there is plenty of room to land at the sod farm and it kept floating past where I wanted to land at. If we get together tomorrow, you need to take it up a couple of times. It's not as fast as what you fly by any means but it does quite well.
Old 12-31-2008, 06:30 PM
max2112
max2112's Avatar
Default Super-Size me!
Don,
Thanks for the write-up. Well done with the presentation, pics etc. I have been bitten by the EDF bug recently and I think something like this may be my next step. I like the larger wingspan and 4 cell battery.
How sturdy is the foam? Do you have any plans to reinforce or harden the airframe? My foamies take a beating in transport and storage.:o
She definitely looks great in the video!
John
max2112 is offline
Old 12-31-2008, 08:12 PM
Jon, thank you for the kind words! The foam is fairly dense. I didn't charge my transmitter battery the night before and on flight two I lost contact with the plane on takeoff at about 20 feet altitude. Luckily the motor cut out too and she mostly flattened out when she hit the ground. The hit was hard enough to do a number on most foamies but the landing gear absorbed most of the crash. The only damage besides another hit to my pride was bent landing gear and a stripped servo for the front nose gear. I was lucky it didn't nose in and decided to quit flying while I was ahead and turn the sticks over to Nick when I charged the transmitter battery up.
And now you know the rest of the story.....
Will it take a beating on transportation and regular handling? Yep, even EPP's can look rough after a while. I considered spraying a light coat of Minwax on it because I usually transport planes in a small trailer but was concerned about performance being reduced by extra weight on the stock jet. The 2200's have made a difference in performance and I may spray it down with a light coat.
Old 01-03-2009, 10:05 PM
banthony
AJAX
Does one need to buy a radio in order to fly these EDF jet kits?
banthony is offline
Old 01-03-2009, 10:09 PM
With this particular kit you supply your own receiver and radio. If you are new to flying, get a trainer first then work your way up. There are many EDF kits that do come with a radio.
Old 01-04-2009, 07:09 AM
giddyuperic
What size battery did you fly with the first time? I just bought one from curtis very nice guy, Can't wait to get her up in the air. I have 4cell 2200 mAh 25c brand new bought just for her. I will post how she does out here is sunny warm southern calf. Thanks for all the good info. Eric
giddyuperic is offline
Old 01-04-2009, 12:09 PM
The first batteries were 4s1p 1800's, your 2200's will work great. Be sure to double check all your hinges and make sure they are securely glued in. Looking forward to your flight report! Welcome to Wattflyer!
Old 01-21-2009, 07:20 PM
rrp
Looks like a nice Raptor. Can anyone remark on the level flight WOT speed using the stock setup w/a 2200 4S batt? 70+ mph? Better? Thanks
rrp is offline
Old 01-22-2009, 10:00 PM
giddyuperic
Well after two weeks of wind and me having to fix the wing that had a crack in it, that turned into a full break with out any flying at all. So I took her out yester day and set her down on the run way with a zippy 2200 mAh 4cell 20-30c and away we went, She went up like a rocket needed major trim on the down used up all the trim and had to lean on the stick the whole flight, But she rips threw the air great and glide on this plane is unreal it just floats perfect landing and now she is all trimed out and ready to go. But as fate would have it my charger took a cr$p so I have to mail it out to be repaired or replaced. So she is a great plane and worth the time and money.
Old 01-23-2009, 05:07 AM
Sounds great Eric! Glad your maiden went well.
rrp, welcome to Wattflyer! I don't have a radar gun so have no clue on the speed of the plane. Mine had a horrible nose in crash and the front third of the F-22 was destroyed. I was able to fly the back 2/3 of the plane though the same afternoon!!
Old 01-23-2009, 05:21 AM
giddyuperic
Sorry to hear that, but that is funny Ha!!Ha!!!!!! How did she go in?What happen? Great little jet I can't tell you how well this thing glides. Not the fastest jet in the barn but is good enough. I am sorry to have to pass along this news http://www.legacy.com/newstimes/Obit...onId=123130097
Old 01-23-2009, 05:24 AM
giddyuperic
Sorry will be taking her out tomorrow and will have a gun to put on her and let you know what we get out of her. Flat out with the 2200mAh 4cell 20-30c
Old 01-23-2009, 05:28 AM
http://www.wattflyer.com/forums/showthread.php?t=40662 page four of this thread has the story.... my whining starts on page three.
Old 01-23-2009, 07:24 AM
giddyuperic
You could have told me that story tell you were blue in the face, But with the photo's wow!!! you have to send that in to someone or a magazine. Way cool.
Old 01-23-2009, 12:03 PM
LOL, I really hated that it happened, the F-22 was a lot of fun to fly. Donnie Lyons has the remains of the F-22 to scratch build something and Curtis made me a deal on another plane.
Old 01-23-2009, 06:45 PM
rrp
Great. Thanks. And thanks, Don.
My 12 year old son is the pilot of the family -- I buy 'em, build 'em and keep 'em flying (I occasionally take the sticks for a little while). He's at the point where he can fly about anything. I recently finished a Phase 3 F-16 (very nice flyer), which is our foray into EDFs, and now looking for a second aircraft. Since he is a F-22 and F-15 nut, this model is in the consideration, but don't want a slowpoke.
rrp is offline
Old 01-29-2009, 06:23 PM
giddyuperic
Well took her out on monday and she was flying fine then I lost right turning and then she went behind a mountain we have at are field very big hill too. She went it at about 70 MPH in a dive so I thought oh sh$t there she goes the plane is a pile of foam. So I get in truck and we drive down there and there she is just sitting there upside down. And with only some grass stains and I lost one of the main landing gears. I CAN'T SEE HOW THIS PLANE MADE IT!!!!!!! THIS IS ONE TOUGH BIRD. I WOULD BUY ONE JUST FOR THAT ALOAN. And to top it off the owner of Easytiger saw in one of the threads that I was going to have to send my charger off to be fixed. He wrote to me and said he had one. I said okay how much do you want for it? He say's I will just send it to you. WOW!!!!! Then it get's here in like three days and it is avery nice multiplex charger it does up to five cells. GREAT GUY WOULD BUY FROM ANY TIME. I plan on buying one more jet from him next month a nice SR-71. So if you want to buy something from someone who will back it up and go out of his way to help you then go to EASYTIGER RC. COM thanks Eric
Old 01-30-2009, 03:24 PM
rrp
Good for you, Eric. Maybe we'll call you "Lucky Lindy"!
rrp is offline
Old 01-31-2009, 01:44 AM
Wow Eric, what an adventure! Do you know what caused the problem?
Quick Reply: Easytiger Models F-22 ARF Review
Page generated in 0.19119 seconds with 12 queries
