Futaba FP-S28 Servos
Old 01-21-2009, 08:24 PM
Kilowatt
Kilowatt
Default Futaba FP-S28 Servos
These servos are left over from an old Futaba AM transmitter,model FP-T6FG/K. I'm thinking about getting a Futaba 6EXA transmitter.My question is can I use these servos with the new receiver? What are your thoughts on the 6EXA?Thank you
Kilowatt is offline
Old 01-21-2009, 09:11 PM
pilotpete2
Pilotpete2
pilotpete2's Avatar
You can use them, but it won't be "plug n' play". You may still find a source of adapter cables to convert those old style plugs to the current standard ones . If you're good with soldering, then just splice in a new servo lead.
Pete
pilotpete2 is offline
Old 01-21-2009, 09:22 PM
Twmaster
Registered User
Twmaster's Avatar
I wouldn't. By the time you make or cobble adapters together you have old slow and heavy servos. For about $10 each retail you can buy new full size servos or for that same $10 or less buy modern micro servos off the intartubes.
One area you really do not want to cheap out on is the radio set.
Twmaster is offline
Old 01-21-2009, 09:58 PM
Rodneh
These were (are) pretty good servos in their day and still work well for sport type planes and trainers. If you have a source of connectors, just cut off the old style and solder in the new connectors and they will serve you well for most purposes. I continue to be amazed by how well the old Futaba servos hold up and continue to work quite well.
Rodneh is offline
Old 01-22-2009, 02:29 PM
Kilowatt
Kilowatt
Thanks for the info.
Kilowatt is offline
Old 03-13-2012, 08:52 PM
Douglas Racer
Can these servos (FP-S28) handle 6 volts? I can't find specifications on them.
Douglas Racer is offline
Old 03-15-2012, 11:50 AM
A.T.
Yes, Futaba FP-S28 & FP-S128 servo specification sheets are attached.
NB: The output shaft was the last with square pattern.
Current Futaba servo horns do not fit.
Servo - Horn Arm Spline Count and Inter Brand Compatibility
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
ID:	158204   Click image for larger version
Name:	FP-S28 & S128_1.jpg
A.T. is offline
Old 03-15-2012, 03:41 PM
Douglas Racer
Thanks a lot I looked everywhere for the specs but couldn't find them. Do you also happen to have specs for the FP-S26?
Old 03-15-2012, 08:59 PM
A.T.
Futaba FP-S26 servo pictures and original specification sheet are attached
Alan T.
ID:	158209   Click image for larger version
A.T. is offline
Old 03-15-2012, 10:10 PM
Douglas Racer
Right on. Thanks a lot.
tmackel
09-04-2007 09:37 PM
dlabrie
12-31-2006 01:32 PM
DTB
10-06-2006 01:12 PM
wyatt
05-14-2006 10:15 PM
Twmaster
10-03-2005 04:22 AM
Quick Reply: Futaba FP-S28 Servos
Page generated in 0.09861 seconds with 17 queries
