Castle Creations discussion All things Castle
BEC for a Castle HV 85
Old 04-17-2009, 02:30 PM
mofosheee
Default BEC for a Castle HV 85
Dear Bros....I just purchased a Phoenix HV 85. I intend to utilize a 6S2P A123 to power an eFlight 90 motor. Since the instructions indicate that the ESC is without a BEC, is there a BEC that somebody can recommend? I am new to electrics. Thanks all
M0f0sheee
mofosheee is offline
Old 04-17-2009, 02:38 PM
This is all I use. And since it is Castle as well it'll be a good fit.
http://www.castlecreations.com/products/cc_bec.html
Old 04-17-2009, 04:55 PM
mofosheee
Thank you!
Old 04-17-2009, 05:25 PM
Glad to help!
Old 04-27-2009, 09:40 PM
mofosheee
Hello
How'd you come out on that 6S2P A123 pack?
PS, I also use the Castle Creations BEC, second year now, its been flawless on my 2.4 Ghz Spektrum radio.
Old 04-30-2009, 12:25 AM
mofosheee
Hi Dennis:
Thanks for the recommendation on the BEC, your advice is very much appreciated.
I temporairly ran out of time for this project but still advancing more slowly.
I have read and studied the task of building the packs in probably too great of detail for my own good, yet I come away very informed. You might not expect from the questions that I have posed to you that I am an oil refinery technician with experience testing and troubleshooting 3 phase 480V and 4160V equiptment (probably to my detriment)
You might recall that I obtained a few "D" cells to practice soldering on. My completed work on these cells looked perfect and with this confiednce I embarked on soldering the A123's. My finshed product was less than acceptable.
So I hunted and read more coming upon a; "hammerhead" soldering tip for my 40 watt iron, aluminum flux, a solder that is better suited for aluminum and tabs ($0.99 each) that will be required since I had to purchase cells to make a count of 12.
I have a list of vendors and web site links should you desire. Gotta run now.
I'll get back to you soon and Thanks.......
Jerry
Old 04-30-2009, 04:28 AM
mofosheee
P.S. I believe that I over temped my A123's batteries when I soldered them. S*&^ canned them and bought two more "authentic" A123's.
Old 04-30-2009, 05:15 AM
MaxAdventure
AMA 198798
MaxAdventure's Avatar
I, for one, would love your list of vendors for the solder tabs. It was my original goal to power my e-conversion with a 10S A123 pack through my CC HV85 on a ZPower Z50-800, although I settled on LiPo as I didn't have a charging solution. I'd love to complete the switch to A123 this year sometime.
FYI, I hear great things about the CC BEC, unfortunately at 30V with my 8S pack I couldn't use it so I went with the Century ELECTRON SWITCHING BEC good for 11V - 37V at 3A.
MaxAdventure is offline
Old 04-30-2009, 05:33 PM
mofosheee
Here ya go............6 (ea) delivered to my front door within a week $6.64
http://aircraft-world.com/shopexd.asp?id=5085
Old 06-02-2009, 04:37 AM
mofosheee
Dear Brothers:
My hat is off to Kyleservicetech and Castle Creations for the; excellent advice, guidance and patience that they have extended to me (an individual who swore he would never own an electric) in building my first electric. Never thought that I would own one! I am impressed. Could not have done it with out Dennis. XOXOXO
P.S. Dennis the 18x12 turned it into an animal. Still awaiting minor parts.
Jerry
Old 06-02-2009, 04:47 AM
Hi Jerry
Good to hear! Let us know how it flys!
Old 06-02-2009, 05:19 AM
mofosheee
Will do sir..........photos to follow. Shame on you, it's past your bed time!
Jerry
Old 06-02-2009, 03:55 PM
Hi Jerry
What can I say, we are retired, now we can be night owls!
Old 06-02-2009, 05:01 PM
dogsheep
Banned
I'm guessing you noticed the hole in these battery bars: it makes attaching a balancing wire a snap!
And, I find the Castle BEC to be the best I've used.
dogsheep is offline
Old 06-06-2009, 01:02 AM
mofosheee
HI Dennis:
Although the 18x12 moves an impressive amount of air, the watt meter displayed 42amps @ 745 watts. I am not getting the amps and watts values everybody else is getting. I was not that impressed with the in air performance.
So I am building this 8S2P pack. More voltage = more umph. That will be 2(ea) 4S2P in series. I realize that is more weight is involved.
And upon building a 4S2P pack, I connect the balancer leads and hook up the blinky and find that no lights illuminate. All the voltages check good at the blinky connection. Can you explain why did the blinky fail to operate when the pack is 4S2P?
Thank you Jerry
Old 06-06-2009, 03:41 AM
Hi Jerry
Question, do you have the "A123" version of the blinky, and not the LiPo version which is about 1/2 volt higher?
And, that E-flight motor is rated for more voltage than the 6S2P A123 pack.
Old 06-06-2009, 03:44 AM
mofosheee
Yes sir, I have the A123 version and the Eflight 90 is rated for 28 volts.
Thank you
Old 06-06-2009, 03:56 AM
Hi Jerry
That's strange. If you have the proper polarity on your Blinky, looks like it somehow died?
I've had mine for two years, with no problems what ever, but that's just one of these. A club member had another brand that he plugged into the battery, with the other brand "Upside down". That blew out the balancer.
I mark both the balancer and balance cables with a piece of red tape to make danged certain to not insert the balancer upside down.
Good luck
Old 06-06-2009, 04:01 AM
mofosheee
Good polarity. Same display when I disconected the two similar wires on my 6S2P to simulate a 4S2P. Blinky still works on reconnection
Thank you
Jerry
Old 06-06-2009, 04:42 PM
Hi Jerry
Do you all ready have the four extra A123 cells for the 8S2P? If not, have you considered putting in a Hacker A50-12S motor? That would cost more, but this motor is a few ounces less than your Eflite 90. And you will not have to mess with trying to get the extra batteries to fit in your model, and the extra work to charge the two packs.
My Hacker A50-12S motor turns a 14X10 APC-E prop at 7900 RPM, and takes an 8 pound model rather fast. I've also got a Hacker A50-16S on my Showtime 50, works well, and I get 8 minutes flying time, taking about 60% capacity out of the battery.
And I assume you are using an Electric APC-E 18X12 prop, and not a prop for a glow/gas engine?? These electric props are far more efficient for electric motors.
Old 06-06-2009, 05:29 PM
Hi Jerry
If you decide to go with your existing Eflite 90 motor with 8S2P cells, that would increase your wattage from 700 or so to about 1200, and still be within the rating of the Eflite 90 motor and batteries.
Did you say you are using the CC HV (High Voltage) ESC. You need the HV version for the 8S2P A123 cells.
That 8S2P A123 pack along with your Eflite 90 will run your power loading up to 150 Watts per pound. That's quite a bit more than you would get from good 70 Class 4 stroke glow engine!
Old 06-07-2009, 03:27 AM
mofosheee
Hi Dennis;
Yes I am going with the 8S2P and have been using a Castle Creations HV-85 ESC with the 18x12 APC-E prop. 150 Watts per pound is what I was shooting for.
To reach these power levels with my ESC and Eflight 90, it looks like my only option is to increase voltage by going form a 6S2P to an 8S2P.
I was wondering why my, when I turned my 6S2P into a 4S2P the blinky stopped working, yet works when I connect it up to the 6S2P configuration.
Different connector required.
Thank you
Jerry
Old 06-07-2009, 05:30 AM
mofosheee
Hi Dennis
Surgery complete........2(ea) 4s2P in series giving me 26.4 volts. After I tidy things up will I will do another amp/watt check.
Cruised around the discussion boards and found out how to BS the blinky into working again by shifting the blinky over a couple of pins to coincide with the new pack configuration. All OK
Thank you!
Jerry
Old 06-07-2009, 05:39 AM
Hi Jerry
That sounds much better than what you had before with the 6S2P A123 and the Eflite 90. Adding those two extra series cells gives much more power output than one would expect, using the same prop.
That's why using the whattmeter is so critical, as you are doing.
FYI, the other thread on this subject now has 1270 readers, so many modelers have gotten information on this thread!
Old 06-07-2009, 06:45 AM
mofosheee
Hi Dennis:
68 amps and 1550 ish watts pulled at burst with the 8S2P pack!!!!!!!!!!!!!
Thats what I'm talking about! This witch oughta fly good.
I am going to try the 16x12 again. Gut feeling tells me that I should probably hang out in this prop ranger. Your thoughts please.
1270 brothers receiving information on the other thread!
For continuity, I should have remained posting there in the spirit of helping a fellow modler as you have helped me.
Talk to you soon
Jerry
Quick Reply: BEC for a Castle HV 85
Page generated in 0.12326 seconds with 11 queries
