Scratch built DR.1 Foamie
Been raining for a week now so, what can you do with a trifold display and a CD rom case?
Oh yeah, you need a hot knife and gorilla glue.
Just getting started. Cutting and forming is the hardest part.
Starting to look like a plane!!!!!!!!!!
I forgot to mention, the other thing I needed was old floppy disks for hinges and some metal rod for stiffening the wings.
So far, all recycled stuff. So black plane is pretty green.
Starting to look like a DR.1 now.
So far only 12.75 Oz.
Electronics will add less than 3 Oz.
This thing should floooaaat!
These are the specs I'm aiming for:
Wing area: 575 sq in
Span: 36.5 in
Length: 30.1 in
Weight RTF: 21.0 oz
Wing loading: 5 oz/ft2
Span: 36.5 in
Length: 30.1 in
Weight RTF: 21.0 oz
No Pink!
...and Snoopy is already flying my D.VII. My poor Camel has Woodstock at the sticks, you would think a bird would know how to fly, but no. Darth Vader would look good in this, but that's already been done
I made the crosses in photoshop. Was it you who posted the "God of the North Wind" pic? Can't remember who but thanks!!!!!!!!!! I had to make him fatter in photoshop for the DR.1, his D.VII's art was same but thinner and longer than the DR.1's. Anyway, printed out everything on sticky-backed label paper.
Need to find wheels, guns and finish the gun platform cowling.I'll install a firewall once I decide what motor to use,Everything is going in the nose for CG. I added dihedral to the top wing and have ailerons on all wings. Getting close to finished.
My wife has a photo printer that only prints 4x6 inch sheets but they are high quality water proof. I print my decals on this printer then remove the paper from the back of the print which leaves a thin sheet like a piece of iron on covering. My "God of the North Wind" decal was longer than 6 inches so I made it in 2 parts. I have a collection of WW1 unit and personal emblem files.
I am starting on the aileron control links next. I realy should have cut the servo hole before I installed the top wing and middle ailerons. A little cramped now. Should I put the inter-aileron links in the middle of the ailerons for best tracking? Suggestions and ideas welcome! If I am the only one here who has done triple ailerons then I guess I'll just have to wing it.
Have hung this on the wall for now (Pretty but not flying yet). I need to figure out an aileron mechanism before I do much more. Taking a break to work on something less mind melting for a while. I opened up the SIG Bristol Scout box and have the fuse and cowl assembled (glue drying as I type this). Watch for new thread and pics.
