strange behavior from a new battery???
Old 08-09-2009, 09:52 PM
pilotmikey96
AIRPLANES!!!
Default strange behavior from a new battery???
i brought this new li-po 1250mAh 11.1V battery from the local model shop and ive charged it up but when i put it inside my aircraft (cessna ep 400 CML) it makes a strange noise, the rudder struggles for a while then everything jams to the right? the wheel is attached to the rudder so that jams right too, and after that, nothing moves , cant figure out whats wrong with it, it cant be the aircraft because it works perfectly on the origional battery so i thought id ask around before taking it back to the shop.
thanks
michael
pilotmikey96 is offline
Old 08-09-2009, 10:23 PM
Whathappened
It sounds more like a receiver problem than a battery problem.
Whathappened is offline
Old 08-09-2009, 10:28 PM
pilotmikey96
AIRPLANES!!!
Default reply
thanks for the reply
it works on the other battery just not on this one, dont see how it can be the reciever?
michael
Old 08-09-2009, 10:33 PM
mpotter187
mpotter187's Avatar
thanks
michael
Have you checked the battery with a volt meter? First thing I would do is check for low voltage on the pack, that could very easily cause it to go crazy, or maybe a short in the pack that would give a strange rating.
Is the pack puffed at all or damaged any way? Have you tried your old battery since you have used the new one does the problem still go away?
In any case I would store the pack outdoors in a fire proof container just in case there is a short or other damage since there is a chance the damaged pack could catch fire. Advise the local model shop that the pack is potentially damaged as well when you return it.
mpotter187 is offline
Old 08-09-2009, 10:36 PM
pilotmikey96
AIRPLANES!!!
Default reply
i did try the other battery straight after to make sure i havent broke my airplane and it works perfectly.
il check it with a voltmeter as soon as i can and i will store it in the shed for now.
michael
Old 08-10-2009, 02:32 PM
mpotter187
mpotter187's Avatar
michael
No problem, I would take your stuff to the hobby shop and show them what it is doing with the new and old battery, since clearly it is at fault.
They should replace the battery for you without much hassle, I would even test the new before you left.
Old 08-10-2009, 07:29 PM
pilotmikey96
AIRPLANES!!!
i have took it to a different model shop from the one i brought it from for volt testing and the voltage is unusualy low and it seems not to be charging, the person at this model shop said take it back to the shop i got it from and ask them for a new one, so im going to go there tomorow and get it replaced it should be coverd by warrenty
thanks for all your replys
michael
Ribcracker
08-09-2009 03:52 AM
FlyingViking
05-26-2009 04:20 PM
Murocflyer
Support & Suggestions
36
11-12-2007 10:34 PM
dashley
General RC E-Heli Talk
03-31-2007 11:24 PM
Ingy_FLingy
12-26-2006 10:14 AM
Quick Reply: strange behavior from a new battery???
Page generated in 0.08740 seconds with 12 queries
