Micro Yak18" is Born
Old 12-17-2009, 09:43 PM
tallflyer
Robert V
tallflyer's Avatar
Default Micro Yak18" is Born
After building and flying the mini yak from www.2dogrc.com I was hooked on building a small full 3mm epp yak style plane.
I took a bunch of pictures of the yak from 2dogrc and draged them into google sketchup.
After some trial and error here is what I came up with.
I call it the Microyak18"
I will post a complete parts list later.
The plane came in a only 1.3oz AUW with the battery pack
I used hot glue to bulid all the foam parts, and some foam safe CA to attach the carbon.
I think I can even save a little more weight if I cut the parts out different as i built the prototype in sections and use a little more glue as I was testing different methods.
The plane is small enough that you could cut the whole wing and middle section as one piece.
I built it using 1.3mm and some 1mm carbon braces and one piece of 3mm x 000.1 flat for the wing spar.
Video
[media]http://www.youtube.com/watch?v=kDs3ME9Hb64[/media]
ID:	115855   Click image for larger version
ID:	115856   Click image for larger version
ID:	115857   Click image for larger version
ID:	115858   Click image for larger version
ID:	115860   Click image for larger version
ID:	115861   Click image for larger version
tallflyer is offline
Old 12-17-2009, 11:59 PM
smokejohnson
smokejohnson's Avatar
Looks good Robert, I can't wait to build one .
smokejohnson is offline
Old 12-18-2009, 05:23 AM
lextek
Very, cool
lextek is offline
Old 12-19-2009, 01:52 AM
hankg
Robert,
You never cease to amaze me with your airplanes!
Regards,
Hankg
hankg is offline
Old 12-21-2009, 05:17 PM
tallflyer
Robert V
tallflyer's Avatar
Ok the basic plans will be up tonight! PDF that is I will offer to cut kits the first of the year for about $25.00 + Shipping so stay tunned for that.
Old 12-22-2009, 07:52 AM
tallflyer
Robert V
tallflyer's Avatar
Default Basic PDF Plans
Here are the Plans for My 18" Microyak18"
they were created with google sketchup and cutepdf.
File Type: pdf
Old 12-22-2009, 08:45 AM
dsmmike
pretty sweet i want a small foamy. Hows it handle a small breeze? do you have it in a pdf that is the full plan not tiled? and whats the set up? sorry for so many questions
dsmmike is offline
Old 12-22-2009, 08:55 AM
tallflyer
Robert V
tallflyer's Avatar
Default Parts list
Here is a complete parts list of whats on the plane
1 x GS 3G Motor And ESC Combo $59.00
This micro motor is the updated motor for the Raptor GS plane. The motor weighs a mere 3.1 grams with the wires. These also come with a 7A ESC presoldered to it which adds 2.5g of weight!
These motors were hand picked for this project and provide the best power for the small weight. We recommend a 2 cell 110 mAh battery to run with this. The receiver comes with a micro JST connector.
1 x EP5030 HD Propeller $1.20 each
1 x 7.4V 100 mAh 15C Li-Poly Battery $14.00
3 x Blue Arrow 2.5 gr Micro Servo, JST servos cost $14 each
* Torque: 2.78oz
* Speed: 0.13 sec/60
* Plug: JST/1.25mm
* Wire Length: 80mm(3.15in)/11x0.08/OD0.6
* Weight: 3.21g(0.11oz) including wire,and screw
* Size: 19.6mmx8.5mmx21.9mm (0.77inx0.33inx0.86in)
AR6300 DSM2 Nanolite 6-Channel Receiver
When it comes to lightweight 3D foamies and indoor slow flyers, every ounce you can eliminate means better performance and longer flight times. Weighing in at a scant 2 grams, Spektrums AR6300 with 2.4GHz DSM2 technology is the perfect receiver for these types of applications. $49.99
Old 01-04-2010, 12:08 AM
dsmmike
do you still plan on cutting and selling these?
dsmmike is offline
Old 01-04-2010, 12:21 AM
tallflyer
Robert V
tallflyer's Avatar
Default kits
I will offer to cut basic kits in about 2 weeks just have to finish some other projects
Old 04-16-2010, 09:28 PM
cliffh
I finished my build from 3mm epp foam and got the maiden done. My plane flies great, but does not have enough power to hover.
I used a 3 gram motor from Hobby City.
Maybe I'll try a 5 gram motor for a little more power.
At any rate, the plane does really fly nicely and is just a blast.
Very easy build, but a challenge to keep weight down.
Cliff
cliffh is offline
timocharis
Foamies
41
05-20-2009 06:07 AM
InfiniteMotors
Foamies
08-06-2006 04:08 PM
sloper steve
3D Flying
9
01-26-2006 10:27 PM
KenS
3D Flying
11-06-2005 12:54 AM
sylair
Foamies
10-15-2005 02:51 AM
Quick Reply: Micro Yak18" is Born
Page generated in 0.08349 seconds with 20 queries
