Castle Creations discussion All things Castle
CC Phoenix 10 and Axi 2203/46
Old 12-20-2009, 10:13 PM
999flyer
Default CC Phoenix 10 and Axi 2203/46
I have a CC Phoenix 10 (micro2/F330) esc fitted to a Techone Gent epp shockflyer indoor model and have updated to v3.00 using my Castle Link. I am using a new Axi 2203/46 motor with a 8x4.3 GWS prop and new 20c 2s 480mah LiPo's and am not getting as much power as I expected to get.
Can anyone advise if the settings listed below are correct for the Axi 2203/46, particularly timing and PWM settings?
# Castle Link Data File
# Created: 19 December 2009
# Do Not Edit This File By Hand
Hex55: 85
Brake Strength: 50
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Soft Cutoff
Motor Start Power: 59
Direction: Forward (*)
PWM Rate: 12 Khz (*)
Vehicle Type: Airplane
Throttle Type: Auto-Calibrate Endpoints
Throttle Response: 8
Governor Gain: 15
Initial Spool-Up Rate: 5
Head Speed Change Rate: 5
Auto Rotate Enabled: False
Governor Mode Type: Simple
Cutoff Voltage: 60
Current Limiting: Insensitive
Motor Timing: 5
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*)
999flyer is offline
Old 12-21-2009, 10:25 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Id suggest changing the PWM to 8 and timing to low and see how that does.
In most cases, those are the best settings for outrunners.
Also. double check to be sure you're getting full throttle - the LED on the esc is on full at full throttle.
Id also ask how you determined you're having less power now than before. The new software is more efficient, so you may be drawing fewer amps but still getting the same rpm.
Its the rpm that matters
Larry3215 is offline
Old 12-24-2009, 01:27 PM
999flyer
OK, thanks for the reply Larry, I'll try those settings.
Defo getting full throttle led.
Hadn't used the motor or esc before as the're both new but I had hoped for more power from the setup. Maybe I'll try lightening the airframe a bit or using a smaller LiPo
999flyer is offline
Old 01-18-2010, 03:25 PM
999flyer
Changed the PWM to 8, timing to low and throttle response to high. it definately has more RPM now
Thanks for the advice Larry
999flyer is offline
jonesjj
01-07-2009 06:57 AM
sredev
07-31-2008 04:16 PM
Epowerreg
03-24-2008 10:20 PM
btomlinson
01-18-2006 02:03 PM
rcflyer11
09-30-2005 02:28 PM
Quick Reply: CC Phoenix 10 and Axi 2203/46
Page generated in 0.09595 seconds with 12 queries
