Castle Creations discussion All things Castle
Discussion Thunderbird 54 - low throttle stutter
Old 01-09-2010, 10:40 PM
dmytchak
Default Thunderbird 54 - low throttle stutter
Hi Forum.
I have a Thunderbird 54 running the 1.5 Firmware. When I plug it in to my PJS -1400ART and start at low throttle (ie first two or three clicks), the motor just stutters. When I push it past the 3 click mark on the throttle, it spins like a champ is is very responsive. If I decelerate from a higher RPM (started past the 3 click mark), it runs very well in the lower 3 click without the stuttering. So it seems that the starting timing maybe bad? I searched the forum and have read the following suggestions:
Bad Battery - I used another LiPo (btw: 3S1P) and same issue.
Cold Solder Joint - Agree with this but the logic doesn't add up to me. If it's a bad solder joint, wouldn't the problem exist throughout the entire throttle range?
I'm leaning towards timing and could upgrade to the latest firmware from Castle. It's beta though - is it safe to run the beta firmwares?
Any help/comments would be greatly appreciated.
Thanks,
David
dmytchak is offline
Old 01-10-2010, 06:12 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
The newest firmware runs much better than old versions on startup and in all other respects as well.
Im not sure on the TBird controllers how much of that you will see, but I think its worth a try.
Older versions of the software were not good at all for "sneeking up" on the throttle. Just go for it
Larry3215 is offline
Old 01-10-2010, 04:39 PM
dmytchak
Originally Posted by Larry3215 View Post
Just go for it
Did it - works like a champ. Was just being a little over cautious.
Thanks for 'push'
dmytchak is offline
Old 01-11-2010, 08:43 AM
Larry3215
Larry3215's Avatar
Good news!
goofeyfoot
Foamies
08-11-2009 02:51 AM
ministeve2003
8
07-10-2009 05:46 PM
Mike Freas
01-03-2008 10:39 PM
brnyrbbl
Humor
06-27-2007 02:27 AM
xrbeast
10-01-2006 12:36 AM
Quick Reply: Discussion Thunderbird 54 - low throttle stutter
Page generated in 0.05949 seconds with 8 queries
