Castle Creations discussion All things Castle
Question Phoenix-10 rapid beeping, then will start?
Old 03-03-2010, 01:47 AM
Past President of PSSF
I have a Phoenix-10 hooked to a Little Screamer motor. I don't know exactly what model of motor it is, I was just told it was a LS.
I downloaded the latest Castle software for both my link & the ESC, and installed both.
Here's the problem; on 7.4 v after I arm the ESC, at absolute low stick, every thing is quiet, when I try to advance throttle, I get a series of very rapid beeps, and the prop just bouncing back and forth, about 1/2", then at 1/2 to 3/4 stick it suddenly starts spinning, sometimes it takes full throttle stick, then it starts.
On 11.1 it starts a little better but not like my other motors, still beeps, and takes 1/4-1/2 stick before it will start turning.
What do I adjust to make the motor start reliably? In the air I can't finger start it like I can on the bench, when it is beeping.
Wildflyer is offline
Old 03-03-2010, 06:09 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Your problem could be caused by several things.
Most likely is a bad connection between the esc and motor. Could be a bad solder joint or a bad connector or a short inside the motor or a broken motor wire. All of them will cause your problem.
It could also be your trying to run a prop thats too big for that motor. It would help a lot if you knew which LS motor you had. Different LS motors need to run on very different sized props.
The "jet" motors are designed to run on very small props - in the 4" range - and the denovo series on some what larger props - 8" max on 3S. What size prop are you running on it now?
It could also be a setting in the controller. What settings are you using for PWM and timing?
Your motor will probably run best on low timing and 8khz PWM.
Do you know how many amps its pulling at full throttle?
Larry3215 is offline
DKNguyen
12-11-2009 04:00 AM
punkindrublik
05-02-2009 03:51 AM
simibill
05-02-2009 03:20 AM
wilga12
Flight Simulators
06-26-2008 04:57 PM
wingswest328
05-29-2008 07:18 PM
Quick Reply: Question Phoenix-10 rapid beeping, then will start?
Page generated in 0.09452 seconds with 11 queries
