Need Juice for a Jug---P-47 That is.
Old 04-08-2006, 02:53 AM
redgiki
redgiki's Avatar
For a brushed, non-ball-bearing motor this size (400-480), my break-in procedure is simple:
* Tape two "D"-sized batteries together end-to-end to create a 2.4V voltage source.
* Tape or solder (I prefer solder, even if temporary) wire leads to your battery. Many come with leads already attached.
* Tape a wire lead to either end of your two D-cells. Whether it's positive or negative doesn't matter; we're going to break this motor in both ways. The leads will probably require quite a bit of electrical tape to get a solid connection.
* The motor will start to run. Immerse it in a cup of distilled water (filtered works fine here, too). Some people say to avoid immersing the capacitors, if already attached. I just drop the whole thing in and tape the leads to the side of the cup. I'd recommend avoiding straight tap water, as I haven't had as good a result with my (very hard) tap water as with distilled or filtered.
* Let it run underwater about 15 minutes to a half hour. Don't run it much longer than that, as a three-hour-long water break-in can also do its share of damage and ruin the motor (don't ask me how I know... it involves a pillowed LiPo...)
* Reverse the motor leads and change out the water (the previous water will be all gray and gucky).
* Run it the other way around the same amount. You'll already have some wear on your brushes, so you won't develop as much gunk on the reverse run.
* Take it out, dry it thoroughly (I use a heat gun), use some 3-in-1 or sewing machine oil on the bushings. I let mine sit overnight to be sure the whole thing is totally dry inside.
I've run motors without breaking them in, and with. For lightly-loaded planes running at low voltage, it doesn't make much of a difference. For planes where I'm overvolting the motor (like a 400/480 motor on an 11.1V LiPo), it's the difference between lasting for many dozens of flights, or lasting maybe 10 before crapping out.
A burned-out brushed motor is a danger to LiPo batteries, too; over-amping the battery can heat it up too much and cause it to pillow out.
In other news, I blew up a second 2100mAh 3S LiPo today. I knew it was going 10 flights ago. It was one of the cheap ones without a balance connector. Though (after soldering on a balance connector) the thing balanced at no load, the cell damage was obvious 3 flights after the battery was new. I've already cut off the shrink-wrap, though, and I'm fairly certain that adding a balance tap to the pack (after seeing the initial damage) voided any warranty I would have had
I'm never buying LiPos without a balance connector again! Two packs dead in two years, even though LiPos are cheap that's $90 of $45.00 3S LiPos that I've converted to 2S LiPos. I still haven't found a good use for 2S, 2100mAh LiPos yet in any of my planes. Now that I have two, maybe I'll go 4S and find a small prop for one of my deltas, and turn it into a speed plane...
redgiki is offline
Old 04-08-2006, 02:58 AM
Twmaster
Registered User
Twmaster's Avatar
Yup water break in works great. Just one warning though. Do not do this to motors with replaceable brushes. Only sealed can type motors as they have very hard brushes. Motors with replaceable brushes have too soft a material for the brushes and the water trick will roach them. Also, for completeness sake. Don't do this to brushless motors either!
Twmaster is offline
Old 04-08-2006, 03:22 AM
redgiki
redgiki's Avatar
Nor to racing-type ball-bearing brushed motors. Although it will break in your brushes nicely, you'll destroy the ball bearings and the motor will last maybe six flights. Use with bushing-types only.
(Don't ask me how I know, please? I learn everything the hard & expensive way, despite reading everybody's advice first!)
The amazing thing about a water break-in is how much longer your motor lasts. I use Johnson J250 motors in some flying wings. On a 2S LiPo, without a water break-in the motors last maybe six flights (or less!) before giving up the ghost. With a water break-in, I've gotten fifty or sixty before burning them out. At $1.50 each, I don't worry about ruining them, but I hate soldering and attaching new motors to my planes. I prefer flying to fixing
redgiki is offline
Old 04-08-2006, 03:24 AM
Twmaster
Registered User
Twmaster's Avatar
Do'h! Forgot that. :/
Dude, were we like separated at birth or something?
Twmaster is offline
Old 04-08-2006, 04:35 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
So the way I understand this is that I can take the stock 480 motor that came with my E-Flight P-47, connect two D cell batteries in series, connect it to the motor leads and drop it in distilled water for 15 to 30 minutes? Again, I'm new to this electric stuff and if anyone would have told me before I joined this forum to do this, I would have thought they were insane. Motors, electricity and water? Not that 3 volts is going to knock your socks off but the thought of dropping a motor in water and running it....well.......
so can I do the same for my PZ P-51 motor?
Grasshopper is offline
Old 04-08-2006, 07:36 AM
redgiki
redgiki's Avatar
Originally Posted by Grasshopper View Post
connect two D cell batteries in series...
Note that D-cells aren't strictly necessary. AAA, AA, C, and D work equally well. I chose D because that's what I had lying around my house. They also have over 9,000mAh per battery. The pair I've been using have been used for, well, a bunch of brushed motor break-ins
I choose to run it at 2.4V (2 cells in series) rather than 1.2V as some recommend mainly for speed reasons. 2.4V still doesn't arc on most motors, and gets the break-in finished in maybe 15-30 minutes, rather than 2-3 hours. I've had bad luck with motors that had a break-in run that long; I figure if the brushes aren't seated in 15-30 minutes at 2.4V, then it was probably a bum motor anyway. My measure of "have the brushes seated" is "is there gray gook floating in the water yet?"
If you've already flown it, a new "break in" won't do anything. The purpose of breaking in a motor is so that the brushes seat evenly on the commutator, and so that the residue of this seating isn't left in bad places (like between your bushing and your shaft).
The goal is to reduce wear on the motor, and to forestall some of the arcing that happens at high amps.
If you've already flown your motor, you've already "broken it in"... it's just that the way you broke it in probably scarred your commutator due to arcing, wore the brushes unevenly, and put hunks of brush-dust in uncomfortable places. Fly the motor until it dies. Once it does, go drop $10 at the hobby store, buy a new one, and break it in properly.
I haven't seen any difference in the power level of broken-in vs. not-broken-in motors. Just longevity. The less time I spend fixing things at my workbench, the more time I have to fly!
Just be aware of how much power you're getting out of a motor whenever you fly brushed. There's a good chance that if your power seems to sag, it's probably because your bushing has worn out. This condition will destroy LiPos if you fly too long, because the amp draw is so high. It's wise to bench-test your aircraft for a short-duration run (like 30 seconds) to watch what happens to the voltage. Do this when the motor and battery are new. Use that as your baseline. If your voltage is way lower during a pre-flight check, the chances are good your amp draw is too high, and it may be worthwhile to tear things apart to get an amp reading.
I understand there are supposed to be some meters which can measure amp draw now without requiring to be placed in series in your power path, but I haven't bought one yet.
I usually do my voltage check the night before a flying day, if it's not a "daily driver" aircraft that I fly so often that any small power change is noticeable. I'm gradually replacing my brushed motor collection with brushless, though, and overall brushless seems to be much better for battery and motor longevity. Once again, less bench time == more flight time
redgiki is offline
Old 04-08-2006, 08:05 AM
redgiki
redgiki's Avatar
I've found that, within the R/C aircraft community, there seem to be a lot of us with thick skulls and thin wallets.
For instance, I received advice that I should seek out an instructor, join a club, and then begin flying. I received this advice about two weeks AFTER I tried to fly the first time! I took my new ParkZone J-3 cub to a local park (which was much too small, and with trees much to large, for me to consider flying in now), threw it in the air, and expected to fly like a pro.
You can just bet how that turned out
I rebuilt that Cub three times.
I'm now a member of a club, had some instruction time, and spend a good deal of time on a simulator when I'm not out flying the real thing.
Same story on motors. It takes so long to glean useful information from these kinds of threads, that I end up glossing over things. Some advice is junk, and some is worthwhile. It takes expensive mistakes to learn which is which.
As another "ferinstance", LiPo batteries. I've actually destroyed four of them! One in a crash. Two due to brushed motor over-amperages (exacerbated by being out of balance, I think). Another one seems as if it was probably defective from the factory.
The expensive lessons learned?
* Size your LiPo appropriately. Budget lots of spare "C" to cover up to twice your expected amp load. One of my blown LiPos was being run right at capacity limit: a 6C 1300mAh LiPo being run up to around 6-8 volts when things were "normal". Well, 6C * 1.3A = 7.8 amps. There was no room for error, and when the motor bushing wore out, the amp load went through the roof. I should have either put another pack in parallel, or used a different brand of battery than the cheap GWS 6C crap LiPos. They were cheap though! Learned my lesson when that one came down smoldering.
* Find a way to put lots of padding or other "slow down, honey!" method between the battery and potential impact points. Give it a "soft out". Sure, you want to build your planes to fly, not crash, but a good design will save your battery. One thing I did recently when I rebuilt a Stryker was to hog out a bulkhead, and line the sides of the battery compartment with Velcro. The battery itself received some opposing Velcro. Well, I dorked that one in due to servo failure, and despite going in hard, there was no battery damage. The battery had slid forward, catching on all the velcro, right up to the nose of the aircraft.
* Measure and write down your measurements. Use them to compare later. If you don't have a baseline when the item is new, it's tough to know when something's going wrong.
* A voltmeter is your friend. Use it all the time, even on your NiMH and NiCD stuff. It will alert you to potentially dangerous problems. Like if I'd paid attention to the fact my charger was shoving 48 volts into my NiCD receiver pack, I'd have realized there was a dead battery under that shrinkwrap, and not had that explosion in the garage! It made me glad for my battery bunker that day. NiCD and NiMH are just as volatile as LiPo. They just take more abuse before they explode.
(Note: this was a Triton charger. I'd had some problems with this pack, and was trying to do a charge/discharge cycle to troubleshoot it. The pack immediately prior to it, which I'd bought at a yard sale, recovered just fine and was able to hold full capacity within 4 cycles despite not being used for 5 years. This pack, however, didn't... when I looked at the battery after the explosion, it had leaked long since and had gone all crusty, crystalline, and rusty.)
* ebay is only your friend if you know exactly what you're doing, and exactly how much what you're trying to buy or sell is worth. (Hint: That "vintage" aircraft kit may be another word for "messed up"...)
* Don't buy items on eBay listed from people who live where there was recently a major natural disaster. (Hurricane Katrina, bought a Futaba flight pack... that's a tale for another time.)
* Learn who knows what they are talking about at your local hobby shop. Find out when they work. Only shop at those times. ("All our CA glues are foam-safe" my perky pink posterior!)
* When the GWS receiver says the range is 400 feet... they mean it! Don't believe what the forum-ites tell you on that. (One crashed and smooshy LiPo, coming right up!)
* Double conversion receivers really are better than single-conversion ones. I don't care that you can theoretically make a single-conversion that's just as good as a double. That doesn't mesh with reality. If you're not going to be the only one flying... go double. (Shot down in a blaze of glory by a guy turning on his transmitter 2 channels away while I was out really far away from my Tx...) Or else plan on flying very close to yourself, all the time.
* Don't pick your nose or rub your eyes while working with CA. Really, don't ask me about that one.
* You should wear surgical gloves while working with high-strength glues.
* You should remove said surgical gloves before attempting to urinate.
Oh, there are so many more!
Crap. I've really gone off-topic. Sorry about that.
Back to the E-Flite P-47! Got a few more flights on it today; we were at the field for nearly four hours. Good stuff. Blazing fast downwind runs. Life is maintenance-free on that bird now that I don't have those stupid wing covers on anymore.
redgiki is offline
Old 04-08-2006, 02:52 PM
Grasshopper
The PZ-P51 has not been flown yet so I can still break in the motor properly. It looks like I have to cut the decals to get the cowl off. Since I'm somewhat of a perfectionist, I'm sure I'll cry but I"ll do it in private and get over it.
Here's my set up for the P-47: Stock 480 (broken in) motor. Spektrum DX-6 system. I'm going to start with ailerons and elevator only and no landing gear or bombs. I'll be using a Castle Creations 20P ESC and CommonsenceRC 3S 2100mAh 15C Lipos.
See any issues here? I feel like I'm researching this thing to death but the last thing I want is one 5 second flight out of it.
Also, on using packing tape for reinforcements, do they make a tape with a flat finish? I just cringe every time I think of putting that shiney stuff on my warbirds.
Old 04-09-2006, 01:15 AM
Sky Sharkster
Sky Sharkster's Avatar
Default Ready?
Hi Tom, looks like you're getting plenty of good advice here. For break-in, I use two "D" cells also, run underwater about 15 minutes or until the water is solid gray (light gray). Only difference is I run it exclusively in the direction it's going to run, not both directions: Probably not a big deal. Then dry it with a heat gun or hair dryer (hold by the prop shaft with pliers) and oil front and rear bushings. Radio Shack sells a plastic holder for 2 "D"s that has short wires attached, ending in two alligator clips. Perfect! Costs about 4$.
Your setup sounds pretty good, double check the amount of throw (deflection) of the control surfaces, don't use more than recommended. The single biggest problem for new flyers is overcontrol. Second biggest problem is "Reversal", that is, when the plane turns from going away from the pilot, to coming towards the pilot. Now left is right and vice versa. "Up" is always "Up" though, until you fly inverted!
For the "shine" on the tape, try steel wool, very fine grade. This also will break the "gloss" on iron-on covering. It won't quite be "flat" but it won't make you wear sunglasses either.
Good Luck!
Ron
Sky Sharkster is offline
Old 04-09-2006, 02:32 AM
Grasshopper
Thanks Ron,
I'm getting ready to break in the motor this evening. I've been over the P-51 probably ten times to check everything. I think I'm going to wear the thing out before it gets in the air. As far as getting used to the controls, I've been flying a PZ J3 for the last few months to get back into the swing of things. I used to fly .40 and .60 size sport planes a few years back and it seems to have come back pretty well. The J3 probably has close to 50 flights on it now with no problems. I've gotten to where I can do loops, stalls and touch and goes with no problem so I think it's time to progress. The weather is suposed to be really nice tomorrow with light and variable winds. I've been putting off the P-51 maiden until I had a really calm day.
If it even looks questionable, she'll stay in the car.
Old 04-09-2006, 02:33 AM
Twmaster
Registered User
Twmaster's Avatar
Best of luck Grasshoppah!
Twmaster is offline
Old 04-09-2006, 04:15 AM
Grasshopper
Aahhh thanks Massa!
Old 04-09-2006, 05:27 PM
comets8518
I think you have a great set up to.
Just double check your Center of Gravity (I'm sure you already know this).
When maidening my Formosa about 2 weeks ago, my Cog known to be off by about 3-5mm and I think something slid upon the take off..and well the plane had a magnet for the ground or something. It broke into about 20 pieces, snapped my prop shaft in half, etc etc. It looked like a lost cause to fix but it turned out to be super easy.
Like you I come from flying .4 and .6 planes a while ago, so I thought it could be my flying ability.
Long pointless story short. I fixed the plane, added some tail weight and remaidened yesterday, it flew great and was a lot of fun.
I was even surprised how well the plane slowed for landing
-moral: Check your CoG, If your plane does crash within 5 seconds pick everything up, go home (or hte field if you got time and/or CA and start putting the puzzle back together and keep at it.
good luck and take videos.
My crash maiden is listed here http://media.putfile.com/mosa-crash (adults only as my peanut gallery couldn't hold back after seeing the crash)
comets8518 is offline
Old 04-09-2006, 09:50 PM
redgiki
redgiki's Avatar
The terrifying thing about the ParkZone P-51 is that the maiden has to be a hand-toss. And usually, you'll want someone else to throw it, and they'll screw it up, throwing upward at an angle rather than flat, or sideways or something.
Good luck I love maiden flights. I think that's part of the reason I have so many planes now... after the successful maiden, how do you top that?
Be ready for the P-51 to torque left if you launch full-throttle. I find the torque roll less scary than not having enough power going on the toss, though, so I always do full-throttle tosses and am just ready for the roll.
redgiki is offline
Old 04-11-2006, 03:58 AM
redgiki
redgiki's Avatar
One other one was badly out of balance, but other than the pack running about 95% capacity compared to my others (tracking mAh on my Triton), it seems that there are no other ill effects. I expect that pack to not last as long as the rest, obviously.
Just so y'all know, that "questionable" pack lasted exactly two more flight safter I wrote this. I flew its last flight in my E-Flite P-47, during a four-hour flying session. As I was concerned about the pack, I charged it for its second flight at 0.5C in the field, with balancer attached. It was badly out of balance after its first flight of the day. During the second flight, the third cell sausaged on me, and I'm now the proud owner of TWO 2S 2100mAh packs, converted from 3S.
(This is the pack that started showing problems 3 flights after purchasing it.)
I'm just glad it's not a total loss of the pack. Now like the GWS packs I bought. Those little 2S 1300mAh packs burned out within fifty flights each. They were only $25.00 each... and I got what I paid for, I guess.
The moral of the story? Be cautious with buying cheap LiPo packs to power your P-47D. At the very least, particularly if they are cheap packs, they must have a balance connector so that you can continue to gauge their health over time. With this pack today, had I not been aware that it was having a balance problem, I might have glibly field-charged it at full amps like my other packs.
Out of the three 2100mAh packs I have left, two have about twenty-five flights each, and one is left over from last season, happily puttering away at 98% capacity with well over a hundred flights on it. It was my only LiPo pack for much of last summer, and was used 2-3 times a day for weeks on end while the weather held.
I think I'll buy four more 2100s from commonsenserc.com. I have a hotliner that a pair of these would power perfectly! It will be interesting to see how they compare to the marginal-quality LiPos I bought from rc-dymond.com. Of course, the more packs I own, the less each pack gets flown! Kind of an odd catch-22 there. Maybe I ought to move up to 3S3P to be able to use all the packs regularly...
redgiki is offline
Old 05-06-2006, 03:04 AM
ragbag
I haen't read the whole threadword for word, so I will start with the first post. Not picking an anyone person just noted one thing. Distilled water is a waste, any tap water will do. Distilled water is an insulator and you are waiting for the impurities to get in the water to start the polishing process.
Now as I have said I might be repeating something already said.
I have a pc power supply that I threw a 5 volt tap out of and that is what I run the breakin with.. Alligator clips with work for the break in, no solder, some motors come with internal capacitors, break it in as usual, you cant/shouldn't open the can to get to them anyway. I fill the beaker with tap water and hold the motor, put the power to her.
When the water turns a litle gray I repplace the water and start again, maybe three times each time the water is cleaner. I have seldem run them more than three times 5/8 minutes to a run. The only one that laste for several runs Sig replaced right away. Good People.
When I was racing RC boats the Hitac factoy rep put me on the alcohol trick.
After I run it in I drop it in a container of alcohol for a few minutes, per their instructions, works great on all their servos except the big expesive 700"s .
They have SMT controls and they are dead as soon as he voltage is connected.
Blow out with compressor and lube. Run for a few minutes to remove the alcohol. Bearing and all. Water doesnt get in the sealed bearing.
I do remove the gear box for all this and never run the motor in the opposite direction of the intended use. EDIT(( the gears got my finger one time)))
To reverse it you have now chipped the leading edge ot the brush and wasted all the good work that you have just done.
Many years ago we did slot cars and disassemble the little Mabuchi can motors and trimmed the edges of the brushes and the reassemble them and hand turned them to polish the commutator, dissassembled it and cleaned the commutator with a tooth brush before we ran the motor. Used tooth paste to polish the gears for breakin.
Hand soldered brass frames.
Boca bearings on all axles.
I loved the five window coups.
Some of the guys nickle plated thier frames, coud never get that to work for me.
ragbag is offline
Old 05-08-2006, 07:55 AM
redgiki
redgiki's Avatar
Originally Posted by ragbag View Post
...no solder...
Looking back at it, I realize that I misstated myself. I solder leads onto the motor, not onto the battery. I think I want to set up some leads to run it off the 5V circuit on my converted PC power supply and speed the process up some, if I ever buy a brushed motor again...
redgiki is offline
Old 07-20-2007, 06:04 PM
flydiver
flydiver's Avatar
FWIW I had a Super Cub 480 that was "missing". It had lots of flights on it. Having nothing to lose and having just learned that water break in was a viable option I tried it. The missing went away. Been flying that same motor for months. With that unit I can see the brushes so know if they are worn out and they aren't (yet).
fly
flydiver is offline
Old 06-29-2009, 06:35 PM
Ryan Flyer
K Close's friend
Ryan Flyer's Avatar
I will have to try this.
Ryan
Ryan Flyer is offline
Sniper.308
Warbird Electrics
25
07-12-2007 02:10 PM
Grasshopper
Warbird Electrics
21
04-11-2007 01:48 AM
Sky Sharkster
Warbird Electrics
8
03-23-2006 12:14 PM
n001pa
Scale E-Powered Aircraft
14
12-26-2005 02:57 AM
larrymcg
Batteries & Chargers
12-07-2005 06:19 AM
Quick Reply: Need Juice for a Jug---P-47 That is.
Page generated in 0.14124 seconds with 13 queries
