My new 7.54 ounce motor and 50 amp esc
Old 04-20-2011, 10:18 PM
gone2fly2
Default My new 7.54 ounce motor and 50 amp esc
The G32 (42-50) brushless out-runner motor can replace a .40 - .46 two stroke nitro engines and is equivalent to E-Flite Power 32 / AXI 2826. It is capable of producing up to 6 lb of thrust and generate about 720W of power.
Specifications:
  • KV: Listed as 800, tested to be approx. 810.
  • Weight: 7.54oz (214g) for motor only, not including mounting accessories.
  • Motor Diameter: Approx. 42mm
  • Shaft diameter: 5 mm
  • Max efficiency: Approx. 40A
  • Max Load: Approx. 50A
I also got a new casle ice 50 amp 33.3v esc. I put both in my 55 inch pink foam yak 55 that weighs 45 ounces and has 96 ounces of thrust
gone2fly2 is offline
Page generated in 0.06178 seconds with 13 queries
