Pant repairs
Old 12-13-2011, 03:13 PM
FlyingBrick50
FlyingBrick50
FlyingBrick50's Avatar
Question Pant repairs
Hi Everybody
I have a set of wheel pants (fibergass) and would like to repair the cracks and make them alittle stronger for those hard landings, any ideas, I was thinking about alot of differant angles for this project, gorrilla glue, apiece of aluminum plate, epoxy, hot glue spread out on the inside,..................
Need to keep it as lite as possibe, all the weight of the pant is on one location the alum. gear (struts?) where it connects.
Thanks for your assistance,....
FB50
ID:	155502 Click image for larger version
ID:	155503 Click image for larger version
ID:	155505 Click image for larger version
FlyingBrick50 is offline
Old 12-13-2011, 04:07 PM
If they are GRP (Glass Fibre) ... then you rough up the surface inside ... polyester resin and light finish cloth from local GRP shop .. making sure all air is expelled from under and cloth is pressed to wheel pant.
That will create an extra skin where YOU want it.
Honest answer ? Forget the other ideas you had ...
Old 12-13-2011, 08:25 PM
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
Ditto. You fix glass with glass, the other stuff is no where near as strong.
Use something like .5 or .75 glass sheets, and do a cross hatch pattern with the weave. This will give you a stronger repair.
OK and work on your landings.
Glacier Girl is offline
Old 12-13-2011, 11:54 PM
FlyingBrick50
FlyingBrick50
Thumbs up Damaged Pants
Previous owners did the breaking, she was crashed twice by the orig. owner then passed it to another pilot who crashed her twice as well. When she came too me her wheel pants had already sustained major damage along with the gear ripped from the fuse. She has been rebuilt and flown twice now, shes a real floater. I'm not sure why the other pilots had suce a hard time with her?
ID:	155516 Click image for larger version
ID:	155517 Click image for larger version
Old 12-15-2011, 07:24 PM
E-Challenged
E-Challenged's Avatar
Wheel pants are often the first thing to hit the ground, if thin ABS plastic they become cracked and ugly in no time. I epoxy a layer or two of fibreglass fabric inside the flimsy pants and cowls to make them last longer. BTW, Park Flyer Plastics sells after market replacement ABS plastic pants, and cowls for many brands and types of models:
http://www.parkflyerplastics.com/cart/
E-Challenged is offline
RONALDO_UK
06-17-2011 09:00 AM
RONALDO_UK
06-16-2011 02:58 PM
Thewyzardofdogz
E-Flite Helicopters
04-16-2011 03:33 PM
pattern14
Pusher Park Jets
33
02-21-2011 02:14 PM
Quick Reply: Pant repairs
Page generated in 0.07367 seconds with 14 queries
