Pattern aircraft Discuss electric powered pattern aircraft in here
EPO Formosa II
Old 02-27-2013, 10:18 PM
TopSpin
TopSpin's Avatar
Default EPO Formosa II
I just recieved my Formosa II from HeadsupRC and it is definetly heavier than the old EPP foam version. I ordered it on Saturday and it showed up on Wednesday, not bad and with $2.00 shipping it's hard to beat.
I got the NPS white (stripped down) model and will fit it with my own components that I will describe in a short build thread. My focus will be on a very good perfoming pattern plane without spending a bundle. The Formosa is well known as one of the best flying foam pattern planes ever but I have not tried one in EPO.
So my goal is not to build a rocket, although that is easily doable, but to build a medium high performance pattern plane that is fun to fly and has enough power to do any aerobatics you want without breaking the bank.
So, pictures and ramblings to follow shortly.
TopSpin is offline
Old 02-27-2013, 11:56 PM
Hi Sometimes when a plane is a little heavy, it will help to pull it through Maneovers better, rather than just flopping through them if the plane is to light, so sometimes weight is your friend, build it with a 1000kv motor on 3 cells, and if you want to go faster, the 1000kv motor will normally take a 4 cell lipo with a little smaller prop for more speed, Subrcribed Take care and have fun, Chellie
Old 02-28-2013, 07:15 PM
TopSpin
TopSpin's Avatar
Right you are and this is the motor that is going in it. https://www.leaderhobby.com/product....=9394001224285
I'll be running an APC 11X5E prop and a 3S 40C 2600 Lipo. This should hual it nicely with plenty of pull for knife edges and other maneuvers.
I notice that Leaders motor prices have gone up significantly. I bought mine for $14.00 about six months ago along with five other 480 sized motors of different KV. I hope this is not a permanent trend but for the thread I will recommend this motor from Headsup RC, http://www.headsuprc.com/servlet/the...80-Plus/Detail
It has plenty of power and costs half as much.
TopSpin is offline
Old 02-28-2013, 07:57 PM
Topspin,
I like what I'm reading here. Finally trashed my PZ T-28 and have been looking for a new home for the emax park 450 . Think this will roll on grass ? Or is it a hand launcher ? Have a drawer full of 9g servos. Subscribed.
Old 02-28-2013, 09:10 PM
TopSpin
TopSpin's Avatar
Topspin,
Hey Hawk,,,,You can build it with or without LG, it comes with it and they will roll off of grass if it's not too tall. I never use the landing gear and just toss them. I put a piece of clear tape over the cutout for the landing gear to smooth the wing and I don't ever paint them except the wing tips for visual reference.
Your motor and those servos will work fine. You should be able to use the ESC and receiver as well if they are not damaged. Sounds like all you need is a plane and a battery.
TopSpin is offline
Old 02-28-2013, 09:23 PM
Thanks Spin,
Been looking for reviews and build logs but not that succesful for the II. Seems like there were a few complaints about being able to stuff a 3S 2200 lipo in the compartment. Not sure about this but for $50? Seems too good to be true. Also read and maybe it only applies to the original GWS Formosa , that it will not turn on ailerons alone. Need to coordinate rudder &elevator. That's okay as long as I know this from the beginning. Not too concerned about the LG. I too would remove them.
Did the wite only version come with decals or stickers?
Post pics when you get her built.
-Hawk
Old 02-28-2013, 10:24 PM
-Hawk
Hawk - any pattern plane worth its snuff won't turn with ailerons alone - you simple don't want that when doing precision aerobatics.
You want a plane that does this:
  • Elevator = Pitch
  • Rudder = Yaw
  • Ailerons = Roll
If a pattern plane does something else with the command you will have a hard time flying it through maneuvers. And lets face it 90% of planes I have flow won't turn with just Aileron, or just rudder. Elevator is needed to complete turns.
Back to the Formosa. It turns redily and as you would expect with just aileron and elevator controls - no need for coordinated turns for sure. The rudder only yaw's and no roll is induced. I had the original version - it is a fantastic airplane. You likely could have fit smaller 2200's in that but the v2 is larger. I suspect they would not be an issue. I used a TP 2100 pro lite pack but they are more compact than modern 2200 packs.
Old 02-28-2013, 11:20 PM
Thanks Mike,
Only being back in the hobby for two years, I've not graduated to Pattern or 3D planes for that matter. I can fly the normal loops, axials, inverted but not in any disciplined "pattern" sort of way like maintaining a heading down the centerline, etc. No rhyme or reason, just experimentation. Here, there's rhyme and reason.
My little squadron has consisted mainly of Arf foamy park flyers, some edf's and for an occasional adrenaline rush, the small yet very fast Rare Bear. Sounds like maybe I could use some sim time on basic pattern aerobatic flying maneuvers before I get myself in trouble. Never really understood the AMA classification for Pattern.
$50.00 plus $2.00 shipping is very tempting for something I may be able to load my EMAX 2820/07 into. A little concerned that this motor might be too much for this plane. It weighs 5.4 oz.
http://www.headsuprc.com/servlet/the...ushless/Detail
-Hawk
Old 03-01-2013, 03:48 AM
The EPO Formosa II has a Rudder, But make the rudder Extra Large for nice Knife Edges
http://www.headsuprc.com/servlet/the...OSA--II/Detail
Old 03-01-2013, 04:23 AM
Chellie,
Just curious. How would you go about doing this? How big? Made from what?
Thanks,
Old 03-01-2013, 04:32 AM
Chellie,
Thanks,
You can make it from 6mm depron Foam or 3/16" - 1/4" Balsa wood. just add about 3/4" to the back of the rudder to make it wider, the stock rudder is not very big, so adding to it will really help, do this after you have maiden the plane stock. use 5 min epoxy to add the extra foam or balsa to the original rudder, the original rudder will only allow for a 5 second knife edge.
I took another look at the formosa and formosa 2 the formosa 2 may already have a larger wider rudder, please send me a pic of the rudder on your plane, if its not very wide, then add to it.
Old 03-01-2013, 12:31 PM
Thanks Chellie,
I still haven't decided on this plane but it looks very interesting. Still not 100% sure it's a candidate for my EMAX 2820/07.
Old 03-01-2013, 02:23 PM
LPatrick
Default Formosa II EPO from HeadsUpRC.com
OK Topspin, mine arrived a few days ago, and I'm about halfway with assembly. The battery compartment will not accommodate any 3 cell I have ever seen so a wing mod to poke it thru the wing into the fuselage was made. The foam is very easily cut with a clean new #11 when trimming the control surfaces. Nice bird so far. Will power it with a PZ 480 from a discarded Stinson. I used Shoe Goo for adhesive since there was no GWS glue in the kit. Wing on this EPO version is one piece so no joining/alignment problems. Not certain about installing the LG yet as I need to see if there is enough thrust for hand launch. Let's keep this thread alive.
Lloyd
LPatrick is offline
Old 03-01-2013, 03:49 PM
Sorry I should have been more clear - no question foam removal is necessary for batteries in ALL the GWS planes. They were built in the day of small A is size round cells. Yes they are that old. Can't actually believe GWS is still afloat.
Old 03-01-2013, 04:41 PM
LPatrick,
Can you post a pic of your wing mod to accomodate a 2200 3S ? I don't mind surgery as long as it's not major surgery
-Hawk
Old 03-01-2013, 05:34 PM
CrimzonRider
Fastest PropHead Crasher
CrimzonRider's Avatar
+1 on foam removal The wing attaches from bottom, about 1/4 of the fuse at the saddle is part of the wing.
heres mine...
http://www.wattflyer.com/forums/showthread.php?t=61896
great little plane for the money, easy "build", instructions are lacking but sufficient....IMHO hand launcher for sure.
http://www.rcgroups.com/forums/showthread.php?t=234093
http://www.rcgroups.com/forums/showthread.php?t=510361
@ Hawk, that motor might be just a little too big IMO, but look at this....little bit of glassing to strengthen wing saddle area after cutting battery hatch before gluing halves together, you could get it to work, 500watt formosas are not out of the question!!
http://www.rcgroups.com/forums/showthread.php?t=491709
have a good one
CR
CrimzonRider is offline
Old 03-01-2013, 08:53 PM
Thanks Crimz,
Jesse from Heads Up seems to think the 2820/07 will work though it's 1.8 oz more than they normally recommend with the 480 Powerup that only weighs 3.6 oz. Mentioned that I may need to add weight to the aft to balance but that since this plane needs mods in order to accomodate a decent battery, it should not be too big deal.
Closer to pulling the trigger !
-Hawk
Old 03-01-2013, 09:37 PM
Bub Steve
Bub Steve's Avatar
had mine for four-five years, have flown her with everything from a power 10 to a 2409-18,(whats on her now)4-3 cells, from 40 to 18 ESC's,
Beef up the landing gear, (the only thing that needs a mod) the rudder is huge as are all the control surfaces, Though a aerobatic rascal she's a sweetheart to fly, You can bank and yank to turn without the rudder with no probs, she will turn flat as you like with rudder and opposing ailerons,
I think I did a build tread called Formossa II super lite build years ago,
hope you like her as she's a sweety, by the way, throw he battery hatch away as you'll never get more than a long flat 1300 3-cell (hard to find) in her, I even made a fiberglass one but still the space was to small, helps airflow anyhoo
Name:	petty an red 424.jpg
ID:	166699   Click image for larger version
ID:	166700   Click image for larger version
ID:	166701   Click image for larger version
Name:	petty an red 407.jpg
ID:	166702   Click image for larger version
ID:	166704   Click image for larger version
ID:	166705   Click image for larger version
ID:	166706   Click image for larger version
ID:	166707   Click image for larger version
Bub Steve is offline
Old 03-01-2013, 10:03 PM
Thanks !
Guess I'll have to wait till they're back in stock @ HURC. Sold out. I have plenty to fly and build in the meantime. Will stay tuned for more build and fly info on this thread.
-Hawk
Old 03-02-2013, 12:37 AM
Bub Steve
Bub Steve's Avatar
heres the thread I had, bubsteve
http://www.wattflyer.com/forums/showthread.php?t=28787
Old 03-03-2013, 12:35 AM
Thanks Bubsteve ! Read through the whole thread. Hey, used to live over in Alachua county (Gainesville) Sure do miss Florida.
-Hawk
Old 03-06-2013, 01:32 AM
LPatrick
Default Wing bolt anchors
Looking for suggestions for anchors for the wing bolts. It seems impossible to align the nuts and their flimsy little plastic holders and epoxy them in place.
LPatrick is offline
Old 03-06-2013, 12:51 PM
Slowjohn
Passed on
Slowjohn's Avatar
Thanks !
-Hawk
I may have gotten the last one this time around & the Big Brown truck is due to drop it off today
This will be my 2nd 'Mosa II due to my trading off the first one & I've missed it alot! I'll finish up my NFS build today as well & since the 'Mosa II is such a fast build I'm gonna go ahead and build it next before I start on my Super Aeromaster build
Standing By,
SJ
Update,
It arrived about an hour ago
Slowjohn is offline
Old 03-11-2013, 11:13 PM
TopSpin
TopSpin's Avatar
I was really surprised when mine came. There was an outer box but no inner box, GWS now packages their planes in plastic bags.
I agree with Mike that it's hard to believe that GWS is still around.
ID:	167038   Click image for larger version
TopSpin is offline
Old 03-12-2013, 12:00 AM
Bub Steve
Bub Steve's Avatar
I still have my 5-6 year old box if you need it,
They made some hum dingers though,, E-Starter about the best all around fun plane I ever had, my old tigermoth 400 still rocks, Slow Stick's were GWS as well, pico sticks, there floats are great and at 10$ can't be beat, there big enough for my SuperCub,, they are lagging now but back where they were the "Go-To" guys for foam plane's,, Bet you'll love your's,, Keep it light, bubsteve
ID:	167040   Click image for larger version
Quick Reply: EPO Formosa II
Page generated in 0.13770 seconds with 23 queries
