Guillows Stearman
Old 07-19-2013, 11:42 PM
Bill G
Super Contrubutor
Bill G's Avatar
Default Guillows Stearman
Guess I better start a build thread, so this build may have a chance of progressing, given the rate it's been going at. The build is going pretty much like the Guillows kits in general, which sell pretty well but are almost all stashed and rarely built. The Stearman is near the top of the list of those kits. I got this kit as a steal on Ebay, since the box was completely shot, but everything was shown to be there in the photos, which is what really matters. Bought and stashed a few more old balsa kits from Ebay for the first time ever, figuring they might motivate me to build, since a die-cut kit is like an ARF from what I'm used to.
Figured I'd start with the engine and pilot, since they are made from vacuum molded parts that require trimming, gluing, and then sanding the seams. The pilots are excellent for reducing weight and tail weight, but are a bit testy to put together. The engine requires that all 7 cylinders be assembled, versus two halves for the entire engine, which again is probably one of the reasons this kit isn't built much. Like the Guillows DR1 and Camel builds, this build will have all gear/batt/motor mounted as far forward as possible to reduce or eliminate nose ballast.
ID:	169916   Click image for larger version
ID:	169917   Click image for larger version
ID:	169918   Click image for larger version
Bill G is offline
Old 07-20-2013, 01:49 AM
BradT
Scale Nut Loves Biplanes!
BradT's Avatar
Nice start, Bill. I always enjoy following your builds, even from back in the day, on the "other" forum.
BradT is offline
Old 07-22-2013, 05:25 AM
Bill G
Super Contrubutor
Bill G's Avatar
Thanks Brad.
Made a bit more progress, and pretty much have a complete fuse, with inset planking to be finished in the front. It's nice to have a reasonably scale scheme of sheeted and fabric covered areas, resembling the full scale plane. With that in mind, the formers were scalloped between the stringers so that the fuse formers don't show through the covering job.
Bill G is offline
Old 07-23-2013, 02:30 AM
BroncoSquid
Workin on it...
BroncoSquid's Avatar
I love to see a Bill G build. I will follow this one with intrest.
I did see the build on the Guillows site but I STILL can't figure out why i don't have permission to see the photos.
BroncoSquid is offline
Old 07-23-2013, 02:37 AM
pd1
Still Learning
pd1's Avatar
Watching...
It's fun to watch someone build something with those little tiny stringers.
Must be something wrong with mine, they keep breaking.....
pd1 is offline
Old 07-23-2013, 10:43 PM
zoltron55
looks like another sweet plane.I was up your neck of the woods last month for the mercer grange fair. PM me lets fly some weekend I'll come up
zoltron55 is offline
Old 07-24-2013, 05:07 AM
Bill G
Super Contrubutor
Bill G's Avatar
Thanks for the comments all.
Bronco for some reason I've heard others say that my camera software makes jpegs that aren't viewable. I've had issues with it also, and learned not to delete photos from my camera until saving them into another format, since every once in a while it corrupts the photos and you lose them.
Pd1 my solution to not breaking stringers is to use heavy stringers. My hands are far to heavy to build with contest stringers. That's part of the reason for pushing all the gear as far forward as possible, to account for the added tail weight. After enough Guillows builds you get a really nice collection of strong stringers since they give you a more than ample supply. Some of the stringers are off-grain cut, which get thrown out, but many of them are properly cut from strong wood. I've haven't had good success with contest, or even relatively light weight stringers that are ran across spans longer than 2 inches. Worse than breaking them while building, is breaking them after covering, such as when hand launching the plane. Another reason for heavy stringers is that even light weight coverings will pull them in when shrunk, and ruin the fuse curves. Had that happen to a FW56 that was perfectly shaped before covering. This plane will have Microlite blue covering on the fuse with a light painting of blue paint, necessary to match the lg, cowl and other parts that require painting. The painting will require some reshinking, since it relaxes the covering.
Zoltron a flying meeting would be good. I need to get my out there and fly more as of lately. The large local park is a perfect place for park flying.
Bill G is offline
Old 07-24-2013, 05:51 AM
The only answer to the fragile contest balsa stringers is to be careful to only handle the model at the formers and the heavier longerons.
Lots of experience working with hand split stringers as small as 1/64" square.
Old 07-24-2013, 06:33 AM
DHC Beaver
DHC Beaver's Avatar
1/64" square?I can't even see that,never mind building with it.
I have a Pilatus pc9 kit that is similar to guillows kits.I keep looking at it,then I put it back in the box.One day i will get up the courage to actually start building it.
DHC Beaver is offline
Old 07-26-2013, 04:37 AM
Bill G
Super Contrubutor
Bill G's Avatar
I've never seen it either, in all my years searching the utopian internet world where most all have the Midas touch. I've even managed to build a Guillows 500 series kit using light weight 1/32" formers, but I would definitely break 1/64" stringers, if I could of course see them in the first place.
Hope you get around to the Pilatus build. I built their Beaver, and would like to build the Pilatus also. After gluing the floats back on after an incident, hopefully I'll get around to flying it again one of these years.
That's the obvious textbook answer. There is a real world benefit to building reasonably robust however, while of course not trying to "build to crash". I've had several models where no matter how many times you slap yourself across the face saying, "Darn it, hold it only on the former, or this area", reality is that it's not that easy. The CG happens to sit far ahead of where we commonly hold the model for a hand launch, which makes it difficult to very gently hold and balance a model the size and weight of this subject, during a launch. Factor in the thrust, which makes it even more difficult to hold and release the model while never letting your grip move from the former and fuse keels, and it's even more difficult.
Bill G is offline
Old 07-26-2013, 01:04 PM
pd1
Still Learning
pd1's Avatar
Years ago before I was a teenager I built indoor microfilm models.
My dexterity was better then and rolling 1/64 sheet for fuselage tubes was common. I remember 1/32 square strips but I don't recall 1/64th.
Now I couldn't even hold one without breaking it.
http://www.indoorduration.com/buildingf1d.htm
I solved that problem, I just got a Sterling PT-17 Stearman kit.
60 inch wings and the smallest stringers are 1/8x1/4.
pd1 is offline
Old 07-28-2013, 05:59 AM
Bill G
Super Contrubutor
Bill G's Avatar
That's a really nice Stearman kit. I've wanted one from Ebay if they were cheaper, but then again they really are worth what they generally sell for.
Finished some small details on the Stearman, and need to start on the wings now, after shaping the LEs.
ID:	170036   Click image for larger version
ID:	170037   Click image for larger version
ID:	170038   Click image for larger version
ID:	170039   Click image for larger version
Bill G is offline
Old 07-28-2013, 01:19 PM
pd1
Still Learning
pd1's Avatar
Bill did you make the interior sheets, or were they part of the kit?
You will have more detail on this plane than I will have in the large one.
pd1 is offline
Old 07-28-2013, 02:21 PM
pmullen503
Another great build! Though, I haven't built a Guillows kit in years, it's still fun to watch them come together.
pmullen503 is offline
Old 08-06-2013, 03:27 PM
Bill G
Super Contrubutor
Bill G's Avatar
Thanks Pat. PD1 the interior is Guillows supplied on printed cardstock. I've always used them, since they make it a "Guillows" build, although the printed details aren't exactly 3D scale. Slowly getting somewhere on the build with the bottom wing completed, which by far requires the most build effort of the two wings.
ID:	170145   Click image for larger version
ID:	170146   Click image for larger version
Bill G is offline
Old 08-12-2013, 06:46 PM
MarceloMichelazzo
Hey Bill
What engine and servos did you use on this model?
MarceloMichelazzo is offline
Old 08-12-2013, 11:08 PM
Bill G
Super Contrubutor
Bill G's Avatar
Originally Posted by MarceloMichelazzo View Post
Hey Bill
I believe this is the motor and kv:
http://www.hobbypartz.com/86ma01-2205-1400kv.html
For this plane, the 33gm weight is useful in balancing the plane, although a slightly smaller motor could probably have adequate power. The plane will be using a 7" prop, which is the reason for the kv rating. If it were any larger, I probably would have gone with the lower 1200kv version.
The servos are HS55, I believe around 9 grams. When possible I use even lighter servos in planes this size, but in this case the tail servos are actually used to contribute to needed forward weight, putting their weight to practical use. For the ailerons, the HS55 servos are just small enough to fit into the wing. I had thought about using something more along the 5gm range, such as my favorite GWS Pico. The aileron servos can add undesirable aft weight to the plane, even though they are close to the CG, which is one of the reasons I try to mount them as far forward in the wing as possible. One of my major goals is to use the gear and battery to balance the plane, without needing any added ballast in the nose.
I'll have to put some more photos up soon, as the top wing is now finished with aileron servos mounted, and it's time for me to start finishing this build up already.
Bill G is offline
Old 08-14-2013, 05:22 AM
Bill G
Super Contrubutor
Bill G's Avatar
Getting close to completing this build now. Maybe I'll have to start another one, so I can put off that lovely covering task for a while.
I ended up adding the cardstock sheet behind the rear cocpit to create the correct scale sized sheeted area, versus my slightly smaller balsa inset sheeted area, as the CG still looks good.
Bill G is offline
Old 08-14-2013, 05:42 PM
Very...very nice Bill....!
Out of curiosity....what will be the final ready to fly weight of this awesome Stearman...?
Old 08-15-2013, 06:22 PM
pmullen503
Those Guillows kits sure are cute at this stage. The last Guillows kit I did was a Bearcat I think, and I never did cover it; just assembled it and hung from the ceiling.
Old 08-15-2013, 07:04 PM
MarceloMichelazzo
Looks so great!
Can't wait to see it finished
Amazing job. I hope I can manage to do something like that on my model soon.
Old 08-17-2013, 01:39 AM
Bill G
Super Contrubutor
Bill G's Avatar
The weight with everything framed, batt and all gear on the scale is now approximately 14.5oz. My main concern with radial engined biplanes is avoiding added ballast, as the remainder of the building techniques pretty much set the weight where it will end up. The plane will use Coverite Microlite blue and yellow, but with an added coat of paint to match all the non covered parts, as well as making the covering opaque. I started this build knowing it wouldn't be a feather light, given the interior/pilot, airfoiled tail surfaces, and cardstock, but the final AUW should still be fine given the wing loading.
Bill G is offline
Old 08-27-2013, 05:26 AM
Bill G
Super Contrubutor
Bill G's Avatar
Slowly covering parts. Getting tired of using all my micro screws for securing rigging fittings, this plane will use rigging eyelets formed from .025" music wire. The wire is bent so that it has a 90 degree bend that can be glued flat against the inside of a thin ply or hard balsa mounting plate, after slipping it through a hole. After catching onto the task of forming the small end loops with needle nose and other pliers, they move along pretty quickly. I've been cutting the wire in short lengths, forming the eyelets on both ends, next creating the other bends which create 2 individual eyelets (see photo below) and then cutting the 2 parts apart.
ID:	170493   Click image for larger version
Bill G is offline
Old 09-22-2013, 04:49 PM
Bill G
Super Contrubutor
Bill G's Avatar
One of these days this project will be finished. Not much to go, other than assembly, rigging, and some details. The yellow Coverite Microlite covered parts have been painted with a light coat of TopFlite yellow spray, to reduce transparency and gloss a bit. The fuse and other blue parts will get a coat of Model Masters Blue Angel Blue, to match all the parts as well as reducing the gloss appearance a bit.
Bill G is offline
Old 09-23-2013, 03:25 PM
pmullen503
Those last bits can seem daunting. I'll usually a little sick of looking at a model when I get close to the end but persevere! It's going to look great.
Quick Reply: Guillows Stearman
Page generated in 0.12004 seconds with 27 queries
