Pattern aircraft Discuss electric powered pattern aircraft in here
Kaos Electric Konversion
Old 03-08-2014, 06:50 PM
take2flight
Default Kaos Electric Konversion
My electric conversion of the Tower Hobbies Kaos is described in the PDF attached.
Technical details are found in the spreadsheet towards the end before the photos.
This plane's photo appeared in February 2014's Model Aviation.
Ash
take2flight is offline
Old 08-13-2014, 12:55 PM
take2flight
Default Flight video: Kaos electric conversion
Hi-res, blue sky...watch in full screen!
https://www.youtube.com/watch?v=0ZJo...ature=youtu.be
Old 08-13-2014, 01:34 PM
More pictures!
I'm planning to do a King Kobra. Axi 4120/18 and Jeti 60 from about 7 years ago (because I have them) I bought the kit immediately upon hearing Sig planned to discontinue it.
Old 08-13-2014, 02:21 PM
Awesome job!
Old 08-15-2014, 02:07 AM
take2flight
Default Photos of my electric Kaos
Airflow into and out of battery area.
Motor mounting strategy.
ID:	176970   Click image for larger version
Old 02-09-2016, 11:36 PM
KillerChaos
KillerChaos's Avatar
Default Bridi Killer Chaos Electric Conversion
I spent the last 2 weeks converting my trusty old Killer Chaos to electric. For those not familiar with this version of the Chaos line, it has a 62" wingspan, 57" length and 700 sq. in. wing area.
I built this kit (the BlueJay version) about 10 years ago. It had a Super Tigre G.90 with a long tuned muffler, Perry carburetor and Perry fuel pump. 7.5 lbs. empty; 8.25 lbs. fueled. It boogied along pretty good. :-)
For the conversion (my first), I installed a Rimfire .80 brushless motor, Castle Talon 90 ESC, Align 5200 mAh 22.2v 6S 65C LiPo battery, an Arm-Safe port and a 3-blade 12 x 8 propeller. The net weight savings with this combo is 9 oz.
I put the first flights on it this morning and I am ecstatic with the results. The flight performance is every bit as good as the nitro engine, but without the mess and vibrations. And the battery measured 71% capacity remaining after 5 minute flights. In other words, the battery is way too big.
I ordered two 3300 mAh 22.2v 65C batteries which will save another 7 ounces a still give about 6 or 7 minutes of flight.
As to temperatures, the motor, ESC and battery run lukewarm, even during aggressive, high power settings aerobatics.
Photos attached:
File Type: jpg
File Type: jpg
File Type: jpg
KillerChaos is offline
11-14-2021 06:11 PM
11-02-2021 02:03 PM
02-16-2016 01:19 AM
paxskipper
87
07-02-2013 10:29 PM
jed1d
Events, Shows and Fun Fly's - Electric Airplanes
04-23-2011 12:44 AM
Quick Reply: Kaos Electric Konversion
Page generated in 0.10239 seconds with 20 queries
