Pl6 safety code 96 at low current charge rates
Old 05-10-2014, 03:44 PM
Kaborkian
Default Pl6 safety code 96 at low current charge rates
Charger: powerlab 6, ordered at Lhs and purchased about 3 months ago
Power supply: 2xhp server supplies in series, 24.8v, 1100 watts total
Can charge combinations of 3s to 6s without issue, charge rates vary from 5a to 35a.
When charging small batteries, specifically 2s300 x 3 lipo parallel at 2c, or 600ma per pack, 1.8a total, or a 6s1700 NiMH at 2a or less, I get safety code 96 a few minutes into charge. When charging the NiMH, it will sometimes false peak and go to trickle in just a few minutes.
Any ideas?
Kaborkian is offline
Old 05-12-2014, 03:41 AM
Gregor
From the manual for safety code 96
"PWM ratio too high. Check the power supply and output wiring"
I would look closely at all wiring between the charger and the supplies. Ideally the supply uses good quality 10 AWG to an EC5 connector. No adapters and no 4mm bananas.
With server supplies, DC (not AC) ground should removed from only the second supply in series (supply delivering 24v positive). The connections should be solid.
If another supply is available for testing that would be helpful. Alternatively a 12v car battery can be used to for testing.
For the NiMh packs, they may need several slow forming charges. Slow charge and discharges using a low rate. The charge cycle should take about 10 to 15 hours.
Gregor is offline
propduster8
12-13-2012 02:42 PM
GooberRC
FMA Direct
10-05-2012 06:55 AM
Tim Marks
FMA Direct
63
09-21-2012 06:09 AM
liposucker
Batteries & Chargers
10
09-19-2012 03:58 AM
Jlbrad1
FMA Direct
02-11-2011 11:17 PM
Quick Reply: Pl6 safety code 96 at low current charge rates
Page generated in 0.10228 seconds with 11 queries
