Old 06-12-2014, 10:49 PM   #1
70sflyer
View 70sflyer's Gallery2
Club: Quiet flyers
Default E-flite servo control problem
I have the E-flite Super Cub 25,with e-flite 46 ,670kv motor,E-flite 60a pro switch-mode BEC ESC ,Have Spectrom digital servos.Problem is that occasionally when I power every thing up,one of the controls dont work.Either elv,rud or alron.My receiver is Futaba.I have not had a ESC with a switch before so I am thinking switch may be flaky. or something else.Dont want to fly till Im sure it wont happen in air. Thanks
70sflyer is offline
Old 06-17-2014, 08:22 PM   #2
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
If it was the switch, then nothing would work when it went bad. No way for a bad switch on the esc to effect only one servo.
If its a different channel each time it happens, then it must be either the rx or tx.
If it was the same channel each time then I would suspect a bad connection or a bad servo.
Id try a different rx and see if the same thing happens. My guess is its the rx.
You might also try re-binding if Futaba 2.4 does that.
I just had another thought too. It could be the frame rate on your futaba is not compatible with those digital servos. IF the Futaba is programmable, try a different (probably lower) frame rate.
You might also try some different servos - non-digital - and see if the problem still occurs.
The more testing you do the easier it gets to narrow down the possibilities.
I think I need a signature.
Larry
Larry3215 is offline
Old 06-17-2014, 09:14 PM   #3
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
The 're-binding' fix again! Where is this coming from? Unless there's something I'm not aware of, a tx/rx are either bound or not. There is no bad bind that can cause flaky performance, intermittent signal loss, planes stalling, etc.
Old 06-17-2014, 10:40 PM   #4
Larry3215
Larry3215's Avatar
With spektrum, Id say mostly yes. I have "fixed" problems by going through re-binding proceedure. Granted, it may have well been something else I did while doing that that actually fixed it. Maybe I jiggled a wire or something
In any case, it certainly cant hurt.
I have no idea how Futaba 2.4 works, so was just suggesting checking what ever Futaba's equivalent was.
Larry
Old 06-18-2014, 05:47 AM   #5
Ohm
cursed
Ohm's Avatar
Club: AMA Member
Spektrum recommends rebinding Rx after the Tx has been dialed in (programmed/adjusted) to for the airframe it is in. Doubt that has anything to do with this.
There is nothing so simple it can't be done wrong.
Ohm is offline
Old 06-18-2014, 06:12 AM   #6
Club: CVMRCC, SEFSD
From a well known Spektrum employee that helps us around the forums:
I can't speak for other brands, but for Spektrum binding simply tells the rx which tx to listen to, and the tx how to talk to it properly. Nothing else.
A Spektrum rx will not hear anything other than the tx it is listening to. Everything else just sounds like background noise to it."
If you feel better about it, fine, do it. But I just don't think it should get around as if it's really going to do anything. Might give beginners a wrong idea.
Old 06-18-2014, 05:36 PM   #7
70sflyer
Club: Quiet flyers
Thanks to every one for there responses,going to swap Futaba R617FS receiver first.Will post my findings.Dean
70sflyer is offline
Old 06-18-2014, 06:56 PM   #8
Club: CVMRCC, SEFSD
I forgot to mention, that's so the rx learns it's failsafe servo positions.
Old 06-19-2014, 05:39 PM   #9
Ohm
cursed
Ohm's Avatar
Club: AMA Member
Thanks for explaining why, cuz I did not remember the purpose.
Ohm is offline
The Extreme Flight Edge 540T-EXP ARF-48 x-nitro 3D Flying 16 02-25-2016 02:58 PM
Now I have a servo problem... CrimzonRider ParkFlyers 5 04-05-2011 06:30 AM
Flite Test Videos: Appreciation Thread FlyingMonkey Off Topic Chit Chat 66 04-04-2011 04:58 AM
Unpossible servo problem mclarkson RC Radios, Transmitters, Receivers, Servos, gyros 13 02-13-2011 12:45 PM
servo zero, angle of the dangle, and flight surface equal travel DanWard Beginners 4 02-10-2011 04:57 AM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Page generated in 0.10840 seconds with 34 queries
