connection problems with Durafly T28 Trojan
Old 06-13-2014, 03:54 PM
dordondronne
Default connection problems with Durafly T28 Trojan
Hi
I'm new to this hobby and have only just joined the forum. I started with a 'Champ' flying it aroud our field, and then bought a Supercub, which I have had for about 2 years. I suppose it's not the original one, as almost all the parts have been replaced several times. I wanted to upgrade to an 'aileron' model and it was suggested that the T28 Trojan was a good 'next plane'
This week my new Durafly model arrived (couldn't get a PZ) and I realise it was a bad choice - too complicated for me.
Can anyone help please? I am using a DX6i with an AR6210X receiver.
I've plugged everything in and it works OK but when I plug the flaps into the 'AUX' channel the elevator and flaps work together.
Any ideas please? I've been on it for hours!!!! (no days)
dordondronne is offline
Old 06-13-2014, 09:40 PM
Welcome to Wattflyer, Dordon. The only thing I think could be possible is you have an active mix in the tx. How are you with programming the tx? You should go in and check all your mix pages for this. Or you could reset the current model to start with a blank slate.
Old 06-14-2014, 10:37 AM
dordondronne
Thanks very much for your reply. Must admit that I don't know much about the technical side of programming tx's but will read the instruction book and have a go.
Best Wishes
Old 06-15-2014, 04:30 AM
flydiver
flydiver's Avatar
The plane is irrelevant. You might try in the TX-RX forums. You are simply trying to get some control surfaces to move in a desired way with a specific TX/RX combo.
Unfortunately just about every TX/RX brand is somewhat specific on how they work, so the plane brand is of almost no use at all.
flydiver is offline
Old 06-15-2014, 10:08 PM
dordondronne
Thanks again for the reply.
Have studied the TX instructions in great detail and have now solved the problem.
There was indeed an active mix which I have now deleted.
I didn't realise that the TX was so complicated. Getting there slowly, but at least everything works as it should.
Many thanks
Old 06-15-2014, 10:20 PM
Glad you got it. And if you think the 6i is complicated, I got a new Dx18g2 recently, and it does things I can't even comprehend!
Old 06-15-2014, 11:13 PM
flydiver
flydiver's Avatar
Yes, they are a whole new language, mostly with manuals that initially (sometimes later also) seem to be written by sadists on bad drugs, likely old out of work DOS-manual writers.
They tell you what you can do with nary a hint on why you might actually want to do that or what good it would be. Wait until the first time you do [elevons].
flydiver is offline
Old 06-16-2014, 01:03 AM
zoltron55
put ailerons on your cub. not hard or expensive
zoltron55 is offline
Old 06-16-2014, 01:23 AM
flydiver
flydiver's Avatar
Cub? Where? He's got a T-28 with ailerons and flaps.
flydiver is offline
Old 06-16-2014, 02:35 AM
The Super Cub he's been learning on for the past year+.
Old 06-16-2014, 03:37 AM
flydiver
flydiver's Avatar
Ah...re-read the first post. Cub is there. But, he's got the T-28 to move on. So, it's certainly possible if he wants to go that route.
flydiver is offline
Old 06-16-2014, 05:10 AM
Don't feel bad. I'm guilty of the same thing on several occasions!
Old 06-16-2014, 10:54 AM
dordondronne
Wow, seems like you guys have been up all night, chatting about airplanes, or is it because I live across the pond in SW France?
Flydiver makes the point that I totally agree with. I have found some good information on the net, with detailed instructions on what you can do with the DX6i but nowhere can I find any comments on why I would want to do it.
Am really pleased that the T28 is 'ready to go' but am not going to try without an experienced flyer with me. The 'taking off' bit is OK, it's just the landing, as the retracts look a bit fragile.
In the meantime I'm going to buy a glider with ailerons and folding propeller, so I can land on our field.
Got the bug now, only money (or lack of it) will stop me
Have a nice day
Old 06-16-2014, 01:40 PM
Originally Posted by dordondronne View Post
Wow, seems like you guys have been up all night, chatting about airplanes, or is it because I live across the pond in SW France?...
Yes, I guess we were up all your night. You might want to go into your profile and add your location if you plan on 'sticking around' on this forum. It helps for things like if you're asking for recommendations for where to purchase something, flying locations, and instructors. I'd offer to help, but you'd have to send me a round trip airline ticket. Better make that 2 or I'll come back to find the divorce papers!
Good luck with it. A wise choice to get an instructor's help.
Old 06-16-2014, 04:45 PM
dordon,
Bonjour ! et Bienvenue Wattflyer. Comment Ca va?
Now that you've moved up to a more advanced low winger trainer, make sure to input dual rates and expo on your 6xi. This will make your experience more manageable and enjoyable. Having someone experienced at your side or even on a "buddy-box" is a great plan. You'll need help getting her trimmed out.
A toute a'l'heure !
Salutations,
Old 06-16-2014, 04:56 PM
flydiver
flydiver's Avatar
Landing gear is often the weakest point on many RC planes. For an RTF with retracts I'd be pretty cautious about the viability also.
Take a look at the Parkzone Radian. It's a standout glider.
flydiver is offline
Old 06-16-2014, 08:04 PM
Flydiver, are you ok?
Old 06-16-2014, 09:03 PM
flydiver
flydiver's Avatar
Well, I've got my problems but I was responding to his concerns about the LG retracts in the T-28, and also being interested in a glider.
The response was brief. Apparently not too clear?
flydiver is offline
Old 06-16-2014, 09:32 PM
zoltron55
the point I was trying to make is a high wing is more for giving & he is already comfortable with it.
Old 06-16-2014, 09:56 PM
Sorry Flydiver, I guess you weren't too far off. But he'll need the Radian Pro if he wants ailerons.
Old 05-22-2022, 10:14 AM
Deleted
Ooops! wrong thread
quorneng is offline
Old 05-22-2022, 11:55 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Was your reply intended for this 2014 thread, or even this RC flight forum?
ron_van_sommeren is offline
01-15-2014 08:16 PM
thuribles
Scale E-Powered Aircraft
02-07-2013 12:03 AM
747
10-16-2012 05:42 PM
1987tc
07-23-2012 04:14 AM
747
07-21-2012 10:48 PM
Quick Reply: connection problems with Durafly T28 Trojan
Page generated in 0.16032 seconds with 11 queries
