Motor won't run.
Old 04-24-2015, 01:11 AM
jpeggy
Default Motor won't run.
Okay I'm new to this I have a TTX650 Tactic transmitter linked to a TR624 RX when I turn everything on the elevator and rudder operate but the motor won't run. I have the motor in channel three and the rudder and elevator in 1 and 2.
jpeggy is offline
Old 04-24-2015, 01:25 AM
Throttle lead plugged in backwards?
Old 04-24-2015, 01:43 AM
jpeggy
Nope rud elev throttle all the same rud and elev work
jpeggy is offline
Old 04-24-2015, 01:51 AM
Beep codes from the ESC continue? That could mean throttle reverse or inadequate throttle range.
Old 04-24-2015, 05:24 AM
I know on my Spektrum DX9 I sometimes have to move the throttle trim all the way down for the esc to see the end point
Old 04-24-2015, 06:56 AM
I've got one ESC that I had to move the low endpoint to 150% in order to arm... prop doesn't turn until stick is centered. Something's wrong with its auto range detection. Hasn't been annoying enough to replace it, but there are many radios that simply wouldn't be able to have the throttle go low enough to arm it.
Old 04-24-2015, 07:25 AM
Sounds like not arming ESC as others mention.
Some ESC's need not only throttle stick range but trim as well - Red Brick ESC's are notorious for this.
If the beeps on start up are not sounding of the cell count - then its not armed properly, also throttle range will need setting since arming is obtained.
First thing to try is 'reverse' throttle ..... quite often the case.
Old 04-24-2015, 10:14 AM
Caution: Remove the prop until you figure it out and then rebind with throttle at 0
Old 04-24-2015, 06:46 PM
Rodneh
You do know that on the Tactic and Futaba, you must have the channel for the throttle set to reverse to have the throttle operate in the proper direction, i.e. low throttle with the stick down and high throttle with stick up (and throttle trim fully down).?
Rodneh is offline
Old 04-24-2015, 07:47 PM
Not trying to be smart ... just commenting ... its debatable which is reversed ... JR or Futaba format ? Trouble is many radios follow one or the other ... same with the daft charger plug ... JR -ve pin, Futaba +ve pin ...
Old 04-24-2015, 07:50 PM
And... some ESCs (Electrifly for sure) you DO NOT reverse the throttle channel of Futaba radio. Because they expect the Futaba default. There have been others but I don't have a list.
Old 04-24-2015, 08:11 PM
Yep - I have odd ESC's that are like that ...
Old 04-25-2015, 03:49 PM
jpeggy
Got it running now had to reverse throttle and arm esc had to reverse all servos. How to turn off the throttle brake?
jpeggy is offline
Old 04-25-2015, 04:12 PM
In the ESC programming. You usually enter ESC programming menu putting the Tx to full throttle then plugging in the flight battery (it should not start but remove prop first).
Exactly how you disable the brake varies according the ESC brand, you really need the manual but most times it's the first set of beeps you hear. When you hear them close the throttle and that most likely will do it, but better off read the manual..
Old 04-25-2015, 06:11 PM
What brand ESC ? Once we know that - we can advise either programming card or use of throttle stick to program it.
Old 04-25-2015, 06:16 PM
Programming differs with ESC maker. Some put brake as first option, some put timing and some put LVC first. (and there could be more as there are more options)
Usually brake is off by default.
You need the manual to know what to do to program the ESC using beep codes.
Its much easier to use a programmer card if you have one. These are usually cheap, but again different makers need different cards and some of them have changed the card needed over the years with old cards not working for new ESCs and new cards not working for old ESCs.
Old 04-25-2015, 09:11 PM
jpeggy
I have the RX/R Electro stick. It has a Electrifly SS45 esc. The throttle brake is on I will try some of the comments. Thanks for all the input.
jpeggy is offline
Old 04-25-2015, 10:31 PM
I just googled your ESC and it immediately popped up lots of sites with the manual ...
Here's a direct download of the PDF file :
https://docs.google.com/viewer?a=v&p...JhNDczYTVhYzIz
and attached :
Old 04-25-2015, 11:07 PM
jpeggy
Hey thanks so much I printed off the manual , had the answers I was looking for. Great help here I really appreciate it.
jpeggy is offline
Old 04-25-2015, 11:54 PM
Personally I like the brake on.
I fly gliders and wings etc but find all my planes (including scale) glide a lot better if the motor is braked.
Only thing I don't have brakes on is the quads.
Old 04-26-2015, 12:08 AM
Brake going on suddenly from high power (slapping the stick from full to 0) can cause the prop nut to unscrew.
The prop will give less drag stopped than windmilling, but sometimes you want the drag so learn where to put the stick for 0 power brake off.
If you don't do much gliding then its usually better to leave brake off. For a heli you definitely want brake off.
Old 04-26-2015, 07:02 AM
Well in over 50 years I have never had a prop nut come loose let alone on an electric.
Maybe I tighten them properly.
Old 04-26-2015, 08:50 AM
I've had it come loose on pushers, brake-on, it can happen.
I've even had a normal adaptor fly of with prop, where nut tightened - all felt good, but thread had a problem and it was gripping enough for me to pull and check - but once in use .... couple flights on ....
fpveric
31
12-02-2013 08:08 PM
CDTheo
07-10-2013 06:28 PM
paul8
03-20-2012 05:48 PM
iflyrc1012
32
07-06-2011 01:43 PM
Humor
17
04-24-2011 10:52 PM
Quick Reply: Motor won't run.
Page generated in 0.11920 seconds with 14 queries
