Binding DX5e to Apprentice 15e
Old 05-22-2015, 12:29 AM
woodmangler
Default Binding DX5e to Apprentice 15e
Hi all
I tried binding my DX5e to my new Pitts - didn't work.
Now I can't get the thing to bind back to my Apprentice.
I simply cannot find the binding plug... since I have never had to use a binding plug there's no telling where this thing went.
Anyway, is there ANY way to bind the DX5e back to the Apprentice without a binding plug?
woodmangler is offline
Old 05-22-2015, 12:37 AM
Bind plug is a loop-back wire connecting the two outside out of the 3 pins.
You can take the pigtail from a broken servo, split the ribbon into 3 separate wires, cut the middle one out and connect the other 2. You now have a bind plug.
Old 05-22-2015, 01:39 AM
woodmangler
OK... that worked great, made my own binding plug
Bound it, but once the plug is removed and I "start over" like I used to, it is not bound.
I am trying to get it back to where it was... turn on the transmitter turn on the plane, go fly.
What am I doing wrong?
Old 05-22-2015, 01:46 AM
I'm niot familiar with the AS3X RXs...
The exact proceedure varies a little with the Spektrum RXs I have. Some you bind, then power down the RX and pull the plug, then cycle the TX power and turn the RX back on and you are good to go.
Some you pull the bind plug before powering down the RX.
Some you do the first method... then to set the failsafes you do the second.
Need to look up the specific instructions for your RX.
If you turn on power with a bind plug installed you will lose bind and the RX will look for a TX in bind mode.
Old 05-22-2015, 01:50 AM
woodmangler
Thanks. I got it now. I had to pull the binding plug first, then power it all down.
Works, now... Thanks!!
All I wanted to do was check the new servo to see if replacing the servo solved the tail flutter problem!
Basically there is LOT of wind right now, so the test must wait.
Thanks again for the save... wonder if I can cancel that $6 binding plug I just ordered...
Old 05-22-2015, 02:05 AM
Ouch. $8 could have been a whole new receiver, and a bind plug.
http://www.headsuphobby.com/Power-Up...iver-A-368.htm
Old 05-22-2015, 02:08 AM
woodmangler
I learn everything the hard way... not my choice, it always seems to work that way
Thanks for the link... another bookmark to help me later!
bcmiles
06-07-2014 09:35 AM
NomaFlyer
02-20-2014 06:33 PM
MX5Seeker
Flight Simulators
08-10-2012 10:01 PM
paxskipper
04-13-2012 10:00 PM
HobbyJumper
11-05-2011 05:46 AM
Quick Reply: Binding DX5e to Apprentice 15e
Page generated in 0.07968 seconds with 12 queries
